**Offical** Yamaha RX-V665 AV Receiver thread - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1561 of 1984 Old 07-20-2010, 12:32 PM
rdgrimes's Avatar
Quoted: 1992 Post(s)
Liked: 1320
Originally Posted by jsb75 View Post
Im thinking about getting this receiver,does it have a manual eq or just different presets,also can you select separate crossover settings or are you stuck with one setting for fronts,rears ect.? thanks for any help
There are 3 available curves for the auto parametric EQ. Crossover setting is global for all "small" speakers.
rdgrimes is offline
post #1562 of 1984 Old 07-20-2010, 12:48 PM
ShooperMAN's Avatar
I apologize in advance for making my first post a question. I've been looking around for a receiver, but I'm completely new to this--the closest I've ever gotten to a real speaker system is the Logitech Z5500 I purchased a few years back.
Originally I was going to buy the Onkyo HT-S5300, but I figured that for a couple more hundred I can have a far superior sound system. I decided to go with the Klipsch HD 1000; while I can probably optimize on this decision (better performance for less), this is probably a decent starter system.
Anyways, here are my questions:
1. How well will this work with the Klipsch HD 1000?
2. I plan on hooking my computer up to this. My GPU has a HDMI output, but the signal carries no sound. My sound card has an optical output. Would it be possible for this receiver to pass through HDMI video, while using the sound from an optical input?
3. I definitely need to read up a lot more on this stuff if I actually want to efficiently and optimally set this system up. Any suggestions?
Thanks in advance!
ShooperMAN is offline
post #1563 of 1984 Old 07-21-2010, 05:30 PM
noah2631's Avatar
Forgive me if this has already been posted....
I just left the "J&R" website and found the Yamaha RX-V665 for $279.99.
You need to enter your Zip Code to get a shipping quote, but still a decent deal.
noah2631 is offline
post #1564 of 1984 Old 07-21-2010, 07:26 PM
ShooperMAN's Avatar
It's the same price on Amazon.
post #1565 of 1984 Old 07-21-2010, 09:54 PM
SpHeRe31459's Avatar
Quoted: 16 Post(s)
Just snagged a 665 at the awesome price from Amazon for my father-in-law. He'll love the 2nd zone for entertaining
A quick question for recent buyers of the receiver: are newer shipments coming with the August 2009 firmware pre-installed or are you finding that you still need to update it out of the box?
SpHeRe31459 is offline
post #1566 of 1984 Old 07-21-2010, 10:03 PM
Quoted: 16 Post(s)
Check out the manual addenum from August 2009 up on Yamaha's site...
The updated manual says if you have the latest firmware you can plug the PC into HDMI 4 and then you can assign it the optical connection from the AV4 block.
Be sure to double-check your firmware version and see if the receiver has rev. 032 or newer, if not, do the update procedure so you can use the optical port for audio with the HDMI for video.
post #1567 of 1984 Old 07-27-2010, 03:26 AM
BOTTLER's Avatar
Hi Folks.
Long time reader, first time poster…
Thinking of buying the Yamaha rxv665 myself today.
I am a total technology novice, and have 3 questions if you’ll all be so kind to enlighten me?
1) I mainly want the 665 to hook up my Technics Turntable. I see it has a PHONO connection, so can I presume I don’t need a pre-amp? Simply plug in my turntable and hook up my speakers and I’ll have nice sound?
2) I would like to hook up my iTOUCH to it. Can I assume the best device for this is the
Yamaha Universal iPod Dock Cradle? Is my understanding correct: That I can operate the iPod with the remote control from the receiver? How is this done? Do I see the iTOUCH menu on my TV or what?
3) That I can hook up my POPCORNHOUR + DVD PLAYER to it?
BOTTLER is offline
post #1568 of 1984 Old 07-27-2010, 06:14 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Originally Posted by BOTTLER View Post
Hi Folks.
1) If it has a phono input, you can connect phonos (I believe it would only work with MM cartridges)
2) Not sure, but I think the iTouch uses the now standard docking connector
3) Sure, why not?
"But this one goes up to 11"
MichaelJHuman is offline
post #1569 of 1984 Old 07-27-2010, 06:38 AM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Thinking of buying the Yamaha rxv665 myself today... I mainly want the 665 to hook up my Technics Turntable. I see it has a PHONO connection, so can I presume I don't need a pre-amp? Simply plug in my turntable and hook up my speakers and I'll have nice sound?
I don't see a phono input on the 665. Where is it located? Maybe I'm overlooking something.
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is online now
post #1570 of 1984 Old 07-27-2010, 06:43 AM
Quoted: 266 Post(s)
Liked: 148
I was surprised myself, as I also did not think it had one.
post #1571 of 1984 Old 07-27-2010, 06:58 AM
SoundChex's Avatar
Quoted: 350 Post(s)
Liked: 295
Some national variants of the 665 (and the 667) include a phono amp/connection [example link]; the USA model does not do so.
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #1572 of 1984 Old 07-27-2010, 07:22 AM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Originally Posted by SoundChex View Post
Some national variants of the 665 (and the 667) include a phone amp/connection [example link]; the USA model does not do so.
Interesting... thank you.
post #1573 of 1984 Old 07-28-2010, 04:07 AM
BOTTLER's Avatar
Excellent, thanks for the helpful insight folks!
And if it aids... I live in Europe, and the 665 comes with Phono
BOTTLER is offline
post #1574 of 1984 Old 07-28-2010, 01:02 PM
enasnidx's Avatar
so here's my problem:
When I watch movies on my BR (JVC xv-bp1) I lose video sometimes, but not audio. It doesn't happen in the middle of the movie, it more happens at the beginning: after the last preview has shown, and before the disc menu comes up. All I have to do is turn the AVR off and then back on, and the video reappears. Does this sound like an AVR, HDMI, or BR issue? Thanks!
enasnidx is offline
post #1575 of 1984 Old 07-28-2010, 02:11 PM
rdgrimes's Avatar
Liked: 1320
HDMI handshake issue. Be sure the player and TV are set to explicit video resolution and color space, no "auto" settings.
rdgrimes is offline
post #1576 of 1984 Old 07-28-2010, 06:05 PM
enasnidx's Avatar
Thanks! I'll have to check the settings when I get home.
enasnidx is offline
post #1577 of 1984 Old 08-01-2010, 12:18 PM
DavidOH's Avatar
???? I have a 665 with Take Classic 5.1. Just picked up a pair of Pioneer HPM-500 speakers. I put them in the front and moved the two Takes to the back for 7.1. Both of the HPMs have a cross-over dial. I currently have them set to zero and ran YPAO on flat. Will moving these change the sound much?
DavidOH is offline
post #1578 of 1984 Old 08-01-2010, 07:41 PM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Hey guys, so I am trying to narrow down the problem. Had the 665 for about 10 months, has been great for me, however the other night we had a storm and the power blinked, which is nothing new. However now, my video passthrough seesm to not be working.
I have my HD Cable box plugged into the 665 HDMI 1, and then the HDMI out to my TV. I can get the audio to come through, but no video for some reason. If I bypass the receiver, and run the cable box directly to the TV, then its fine. Anyone have any thoughts?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #1579 of 1984 Old 08-01-2010, 08:10 PM
Liked: 1319
I notice too, my Samsung SMT-H3260 HD Cable Box shows this message when I turn everything on, "E007".
post #1580 of 1984 Old 08-01-2010, 10:33 PM
rugdocta's Avatar
Hi, I bought the yahmaha rx-v665 and have a Wii connected to one of the component inputs and think that the picture quality is somewhat degraded and looks better just hooking it straight into my HDTV. I am assuming this is due to upscaling. Is it possible to just pass the signal thru without being upscaled?
rugdocta is offline
post #1581 of 1984 Old 08-02-2010, 06:15 AM
rdgrimes's Avatar
Liked: 1320
Converting from analog to digital is "processing". You can pass the signal via component to the TV, or bypass the AVR completely.
rdgrimes is offline
post #1582 of 1984 Old 08-02-2010, 07:08 AM
Liked: 1319
Well I think I have narrowed down the problem. My HDMI 1 on my TV gives me the E007 error message when plugged into the Cable box. And I can not get any video/audio passthrough with my receiver. I think when the power blinked, it may have damaged my HDMI ports on my receiver and TV. I can get my cable to work fine on the TVs HDMI 2, but I feel the HDMI output and HDMI 1 and 2 on my receiver have been damaged...
Luckily it has a 2 year warranty, so I will contact Yamaha and see about getting it fixed. On a related note, I realized when they came to install my HD Cable box the guy plugged the box directly into the wall, instead of my surge protector, and I did not realize this until recently. It sounds odd but it seems that whatever was connected at this time, was damaged by that interruption...
post #1583 of 1984 Old 08-02-2010, 07:38 AM
ttorski's Avatar
I have this receiver for some time now, but I don't like how center speaker works in movies after YAPO. I`m using Polk Audio CS1. All dialogues are very week. I don't wanna adjust it manually because YAPO setup works perfect for live music.
Any ideas, maybe using DRC?
thanks
ttorski is offline
post #1584 of 1984 Old 08-02-2010, 08:58 AM
rdgrimes's Avatar
Liked: 1320
thanks
It only takes a few remote clicks to adjust the center level manually. Odds are good that the real problem is that your center speaker is not up to the task. 2-way centers are almost always lacking in the mid-range. Most HD movie audio is mixed with a wide dynamic range so levels need to be higher, making the sound effects too loud and dialog too soft for some folks.
DRC will lessen this effect.
rdgrimes is offline
post #1585 of 1984 Old 08-02-2010, 10:17 AM
MadBoris's Avatar
Thanks in advance!
I also wanted to chime in since I recently did this.
Since I recently ran into the same issue, I also wanted to confirm you can assign different inputs to go with the HDMI, including an optical out (which I did a few days ago).
There are several things like this that can be done, the manual isn't too clear on some of them.
You can setup four HDMI configurations (1-4) to be able to be recalled from the remote, with custom inputs. This includes additional remote codes for each HDMI setting individually, etc.
In order to use the scene buttons, if you so desire, the easiest way I found was to first setup an HDMI preset the way I liked it with inputs and control codes according to the manual. Then you can transfer it all to one of the white scene buttons by holding down the scene button, then the HDMI button, until the receiver shows scene set. This was the only way I could figure out to ad/set custom remote codes to the individual scenes (BD/DVD, TV, CD, Radio).
P.S. I just realized I have the 565 and this is the 665 thread, but the above should still be true for the 665.
MadBoris is offline
post #1586 of 1984 Old 08-02-2010, 11:25 AM
Displaced Husker's Avatar
Quoted: 13 Post(s)
5.1 or 7.1?
I currently have a rectangular room running 5.1 (30' X 15') with two Cambridge 300 surrounds about 2' behind my seating area on the left and right. There is approximately 15' to the wall behind my listening area. It sounds pretty good. My question is will I be happier putting two more speakers on the back wall?
Displaced Husker is offline
post #1587 of 1984 Old 08-02-2010, 11:45 AM
rdgrimes's Avatar
Liked: 1320
Originally Posted by Displaced Husker View Post
5.1 or 7.1?
Perfect setup for 7.1. The main use for 7.1 would be to expand your sound field. Gives it a bigger stage in the rear. I use PLIIx matrixing on all 5.1 to expand it to 7.1 and it's very effective. Hard to describe, but it just sounds bigger and gives you a rear stage that's more like the front..
rdgrimes is offline
post #1588 of 1984 Old 08-02-2010, 12:07 PM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Originally Posted by MadBoris View Post
I also wanted to chime in since I recently did this... P.S. I just realized I have the 565 and this is the 665 thread, but the above should still be true for the 665.
Is there a 565 thread? I post here eventhough I too have the 565, as I couldn't find any other thread that seemed more appropriate.
Some years ago (maybe over a decade ago) an electrical surge smoked the surge suppressor that had the TV plugged in to it. Thank heaven - that saved me mucho dollars, as it was easy to replace the power strip but the TV would have cost much more. Nowadays EVERYTHING electronic goes on a surge suppressor. Well worth the small additional cost!
post #1589 of 1984 Old 08-03-2010, 07:16 AM
Liked: 1319
I had it on a surge protector, however the electrical surge came down my cable wire (not on the surge but will be now...) and jumped to the HDMI. I talked to a local audio repair shop and he told me with the newer receivers, all the circuitry is on a single board, and so if the HDMI was damaged, its likely the processor inside was too, and this usually means a whole new board. Luckily I only purchased it in October, and it has a 2 year warranty, so I sent it to Georgia (closest service center) to be fixed. They told me its about a month turnaround so I won't have any surround sound for a little while , but it's better than buying a whole new unit...
post #1590 of 1984 Old 08-03-2010, 01:49 PM
RobLee's Avatar
Quoted: 261 Post(s)
Liked: 268
Yeah, I gathered that from your original post. And my point (perhaps not so well made) was that, given the way everything is so interconnected these days, it has become extremely important that everything that is not truly "stand alone" should be on a surge suppressor... and not just some cheap MOV power strip, but something with actual electronics inside.
I can tolerate it of my cheap V-Tech cordless phone gets zapped, but since it is plugged into the cable modem (for internet phone) it is therefore also connected to my Blu-Ray player by way of the ethernet cable and therefore everything else in the HT setup. As in your case, since the HDMI cable is technically a low-voltage signal then there should not be any way for an electrical surge to harm any other equipment - and yet it happened. Something I learned a long time ago: if it happens, it MUST be possible.
Yamaha Rx V665bl 630 Watt 7 Channel Home Theater Receiver
