Onkyo 805 HELP needed, only sound from fronts and sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-03-2009, 03:22 PM - Thread Starter
Ron D239's Avatar
Hello ladies and gents, I need some help. I had new flooring installed yesterday which means I had to unhook all of my electronics and reinstall everthing once they were done. I have an onkyo 805 running 7.1. After hooking everything back up I am only able to get sound out of the front left and right and the sub. I can't get sound out of my center or any of my surround speakers. I have tried everything. All of the wires are hooked up correctly and the settings are the same from before I disconnected everything. I have tried the test tone's, nothing, tried audyssey, nothing, tried everything I could think of and still nothing. I'm hoping that it is some stupid setting that I'm missing and you can help me figure it out because it doesn't make any sense to me. Thanks in advance
Ron D239 is offline
post #2 of 7 Old 03-03-2009, 04:07 PM - Thread Starter
Ron D239's Avatar
Help, please
Ron D239 is offline
post #3 of 7 Old 03-03-2009, 05:29 PM
oztech's Avatar
Liked: 101
Rerun the set-up with the mic had the same thing happen to a friend after Ike that
storm was brutal but anyway we hooked the mic up and reran setup and all the channels returned then we made adjustments.
oztech is offline
post #4 of 7 Old 03-03-2009, 05:32 PM
Jakeman02's Avatar
If you didn't duplicate threads it would be easier to follow your status. As I posted in your other one, what oztech said.
Jakeman02 is offline
post #5 of 7 Old 03-03-2009, 05:41 PM - Thread Starter
Ron D239's Avatar
Sorry about that(double post). I'm gonna rerun the setup once my girl gets done watching biggest loser. She won't let me run it while its on. I'll check back in with results after I'm done. Thanks again.
Ron D239 is offline
post #6 of 7 Old 03-03-2009, 06:02 PM - Thread Starter
Ron D239's Avatar
Ok, just reran the speaker setup and it is not recognizing any speakers except the sub and front left and right. I am going nuts with this. What do you think my next step should be? Is there a hard reset or something or do I call someone to come check this out?
Ron D239 is offline
post #7 of 7 Old 03-03-2009, 07:35 PM
oztech's Avatar
Liked: 101
If you hooked the mic up and let it run setup and you don't have bad connections to the
speakers or pure or direct ingaged time to call Onkyo.
oztech is offline
