The "Official" Onkyo TX-SR607 Thread - Page 88 - AVS Forum | Home Theater Discussions And Reviews
post #2611 of 2626 Old 04-10-2015, 07:16 AM
Liked: 0
Initiate Onscreen Display
Its been a while since I looked at my onscreen display. I seem to be missing how to initiate the onscreen display. I think I'm hitting the right buttons? I have my Panasonic TV hooked up by HDMI. Can someone please step by step instructions (including for TV) how to display on screen menu.
Challanged
AVChallangedNJ is offline
post #2612 of 2626 Old 04-10-2015, 11:57 AM
Tesla1856's Avatar
Quoted: 42 Post(s)
Liked: 56
Challanged
Right, must be on HDMI I think.
Pretty sure you just press on remote ... Receiver and then Setup buttons.
Living Room Home-Theater:
Epson 8350 1080p Projector (96") / Panasonic TH-46pz850u 46" 1080p Plasma TV
Onkyo TX-sr607 7.2 HDMI Audio/Video Amplifier/Receiver (630 watts)
Panasonic DMP-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TimeWarner)
Harmony 670 Remote / HTPC (Kodi/Win7-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series II Speakers (Large 6.1 Matched Separates) / PSW505 12-Inch Sub
Tesla1856 is offline
post #2613 of 2626 Old 05-09-2015, 09:41 AM
PRpaulorossi's Avatar
The display in the TX SR607 doesn´t appear ...
The display in the onkyo doesn´t appear anymore ...
But the receiver works just fine, I can get image and sound ... I can´t see the volume, the input sound, the listening mode, etc ...
Can anyone help me ?!!?!??!
Thanks a lot !!!!!!!!!!!!!
PRpaulorossi is offline
post #2614 of 2626 Old 05-09-2015, 10:37 AM
JChin's Avatar
Quoted: 244 Post(s)
Liked: 175
Hi PRpaulorossi, if the receiver is non North American model, possible Pure Audio is enabled.
JChin is offline
post #2615 of 2626 Old 05-09-2015, 11:08 AM
Thanks ...But it´s not the case because the Pure Audio is off ... I´ve already enabled and than disabled but it still doesn´t work ...
It´s european, I´m portuguese.
post #2616 of 2626 Old 05-09-2015, 08:23 PM
JChin's Avatar
Quoted: 244 Post(s)
Liked: 175
If you haven't yet, perform a soft reset by removing power cord for few minutes. Another thing to try is to reset receiver back to factory default.
JChin is offline
post #2617 of 2626 Old 05-10-2015, 07:28 AM
Thanks again ... I´ve already remove the power cord and the problem remains, I still didn´t try to reset to factory default because I would have to program the receiver again and without the display it can become tricky ...
Any other options ?!?!?!
post #2618 of 2626 Old 07-26-2015, 02:58 AM
maxblast72's Avatar
Liked: 0
I have the same problem with my 607. No onscreen display but also no display on the Onkyo itself. The receiver still works but I cannot change any setting.
Soft reset did not solve it.
Factory reset does not work I think (no display).
Wondering if PRpaulorossi was able to solve it.
maxblast72 is offline
post #2619 of 2626 Old 07-26-2015, 04:50 AM
Hi there,
No, I couldn´t solve it. It still works but I don´t have the display. I´m thinking in send it to assistence.
If you solve it, please let me know.
Best regards.
post #2620 of 2626 Old 07-26-2015, 05:52 AM
maxblast72's Avatar
Liked: 0
Hi there,
Best regards.
Ok too bad. There is a fix but it involves replacing some parts on the main board but that is not something I would try.
Thanks for your reply.
post #2621 of 2626 Old 09-12-2015, 10:51 AM
Gary1's Avatar
My 607 sounded like it has been in the rice krispies . I got a loud crackle ( no snap or pop )on the rt front speaker only like you were attempting to connect an amp to a speaker with the volume all the way up. It did it one day and then it stopped quickly as I was trying to turn down the volume which was only like 21 . Then a couple days later it did it again and went to stand by . I unplugged it for a minute and tried it again only to go back to stand by in a few seconds. Is it time for the can , I have owned it since the model came out .
Gary1 is offline
post #2622 of 2626 Old 11-20-2015, 04:47 AM
maxblast72's Avatar
Liked: 0
Hi there,
Best regards.
I opened the receiver and took out the HDMI board. I replaced the 5 capacitors 100uF which should fix the problems with some HDMI inputs and it should also fix my OSD which was not working anymore.
With these new capacitors;
My Cable/Sat HDMI input works again
My OSD is also working again
Now for the dead display.
Under the HDMI board there is another board. According to the service manual, it is a video pc board U0032 (BAVD-0038).
On this board there should be a resistor for the display. A dead display is often caused by this resistor R9010 being blown.
Some owners mention a resistor R9010 but other mention R9001.
Sadly, my video pc board is a bit different from the board in the service manual. I have a European model so perhaps that is the reason.
My board is a BCVD 0038 25140038 and acc to the service manual, the R9010 should be between the D9001 and connector JL8001A but it is not.
On my board this is a D9001 so no resistor I guess.
However, there is a R9001 close to this area but not on the same spot. I replaced it anyway but no luck; no display.
The R9001 resisitor that came out of the Onkyo has these marks on it 221J 1W *91.
So perhaps I replaced the wrong resistor
For now, everything seems to work, except the display.
Perhaps I will give it another try when I can get my hands on of a service manual for my European model.
post #2623 of 2626 Old 11-24-2015, 02:58 AM
maxblast72's Avatar
Liked: 0
Update
Replaced the D9001 on the board, where the R9010 should be and my display works again.
post #2624 of 2626 Old 11-28-2015, 11:40 PM
Tesla1856's Avatar
Quoted: 42 Post(s)
Liked: 56
Challanged
Now MY OnScreen Display (OSD) on HDTV has quit working. I can only see it on Onkyo 607's little led display.
Everything is connected by HDMI. I'm pressing Receiver and then Setup buttons on Remote like always. Everything else is working but I can't imagine using the little LED display for everything, much less a Audyssey calibration.
I tried the "soft reset" (un-plug from wall for 15 minutes), but no help.
post #2625 of 2626 Old 01-07-2016, 02:45 PM
Guy Scharf's Avatar
I have a new Vizio M55-C2 TV. It has an HDMI connector for ARC so that a receiver can handle audio and speakers.
My desire is to have the TV handle all video directly (OTA TV, netflix, amazon, DVD, etc.) and have the receiver drive the speakers. I want to use the TV's HDMI connection rather than their audio out (RCA or optical) because I want to connect headphones to the TV's audio out connectors. My hope is to control everything, including volume, with the TV's remote and not have to use the Onkyo's remote at all.
One person has told me that won't work because the Onkyo's HDMI is 1.3a rather than 2.0.
Can anyone confirm whether HDMI audio can be made to work, or am I out of luck with this receiver?
Guy Scharf is offline
post #2626 of 2626 Old 01-07-2016, 03:27 PM
Tesla1856's Avatar
Quoted: 42 Post(s)
Liked: 56
Pretty Close. I don't think 607 has HDMI 1.4 (so no ARC or Ethernet over HDMI). But go ahead and try enabling ARC on HDTV and turn on HDMI-CEC and see if you can get it to work anyway.
I think all ARC does is eliminate the extra SPDIF cable (optical or coax) that brings audio (for internal tuners like ATSC and Smart-Apps) back to Amp. Usually, you can just use SPDIF cable, program Amp for it, and it works just like ARC would.
I would try both of the above before writing-off Amp (unless you are ready for an upgrade anyway).
You can connect headphones at 607-Amp.
Onkyo Tx Sr607 Receiver
