Best Receiver for music? Video less important - Page 2 - AVS | Home Theater Discussions And Reviews
post #31 of 35 Old 04-08-2009, 10:10 AM
penngray's Avatar
Liked: 31
are going to be inherently contradictory.
you better readjust your expectations about the quality of the sound and "impact" of the kick drum if you are aiming for a tiny sub/sat setup. that's going to be a tough one to reconcile.
you can't take some tiny speakers and pair them with a "musical" receiver and suddenly have full bodied smack-you-in-the-face-awesome music performance. there is going to be a hole in the upper bass in almost any sub/sat setup...
__________________
I agree, my first post above attempted to explain what speakers are needed. Your post is exact to the point....small speakers will not equal the performance he wants. Its a pure physics thing.
penngray is offline
post #32 of 35 Old 04-08-2009, 10:28 AM
batpig's Avatar
Quoted: 1651 Post(s)
Liked: 1904
that is not to say there aren't some really, really good sounding "little" speakers out there. it's just about aligning/reconciling his EXPECTATIONS with the reality of what little speakers can do.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #33 of 35 Old 04-08-2009, 01:16 PM
bigbare's Avatar
ccotenj -- if you looked at the design of the speaker befor posting you would see they are designed in such a way that you mount them above 7' upside down and they work. I think you would understand if you saw the design.
"Sometimes you get shown the light in the strangest of places if you look at it right"
bigbare is offline
post #34 of 35 Old 04-08-2009, 01:24 PM
bigbare's Avatar
You are both right about his exectations.
bigbare is offline
post #35 of 35 Old 05-03-2009, 01:18 AM - Thread Starter
dhensley's Avatar
I ended up taking Russdawg's advice and found a used Arcam AVR300 (I got it for $600 and have seen it for a bit less on ebay recently). I really like it so far, but I am currently running it on some inadequate speakers. I am currently looking into getting a set of Paradigm Studio 20s and will then build up my remaining speakers over the next few months.
Thanks for your help.
dhensley is offline
