CONNECTING EQUALIZER TO RECEIVER..look what I did - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 56 Old 04-07-2009, 06:12 PM - Thread Starter
AudioBeginner's Avatar
Originally Posted by Kal Rubinson View Post
Note the pairs along the bottom are marked as in or out and that each pair consists of a R and L connector. Use the Tape PB/Rec Out pair.
These are two L/R pairs. Use the line in/out pair.
If this does not work, something's wrong. I'd just look elsewhere such as changing the speakers or the room acoustics.
exactly what I did... but low was the sound that was emitting from the speakers
AudioBeginner is offline
post #32 of 56 Old 04-07-2009, 06:14 PM - Thread Starter
Kal, were you talking about these receivers right here:
http://hometheater.about.com/od/avre...atpmidavra.htm
post #33 of 56 Old 04-07-2009, 06:20 PM
Lordoftherings's Avatar
AudioBeginner, did you read post #27?
Bob
Lordoftherings is offline
post #34 of 56 Old 04-07-2009, 06:38 PM
whoaru99's Avatar
Liked: 69
I think you have the connections right, but just in case, it should be
Receiver Rec Out > EQ Line In and EQ Line Out > Receiver Tape PB
The Tape Monitor on the receiver will have to be engaged, as will as the source you want to route through the EQ.
Be sure you have the EQ powered up, but also be sure the tape monitor on the EQ itself is turned OFF.
The only time the tape monitor on the EQ is used is if you have a source connected to the Tape jacks on the EQ, and want to listen to that source.
If there is further confusion, post a picture of the EQ controls (not the sliders, the other stuff).
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #35 of 56 Old 04-07-2009, 06:43 PM - Thread Starter
Originally Posted by Lordoftherings View Post
Yep, like Kal said, throw a shall over them.
Just kidding, I will not used an equaliser for the reasons I said before.
But if you really insist...
The tape out of your Yamaha goes to the input of your EQ; the tape in of your Yamaha goes to the output of your EQ. The tape in of your EQ goes to the tape out of your tape deck or CD-R; the tape out of your EQ goes to the tape in of your tape deck or your CD-R. Now push the tape monitor on your Yamaha, choose a source you like to listen to.
Set your EQ to Pre EQ for playback of the equalized sound. Set your EQ to Post EQ for recording the equalized sound. Set your EQ to Source for any other source that you play from your receiver.
Set the EQ switch of your EQ to the IN position for the equalized sound.
Set the EQ switch to the OUT position for the original stereo sound.
Let me know how things goes.
Bob
There's no Line OUT on my cd player. Just 1 white knob and 1 red knob(Line In) So what I did was put that cable in there and connect it to the tape out of my equalizer. Then I connected the Rec Out of my equalizer to the Tape PB of my receiver. And I connected the Tape PB of my equalizer to the Rec-Out of my Yamaha receiver.
When I pressed the Tape Monitor, Finally I could actually hear the music LOUD! BUT the equalizer had NO effect on the sound (unlike what I did the first time, the output level of the equalizer was affecting the sound of the speakers)
post #36 of 56 Old 04-07-2009, 06:46 PM
Not your CD player, you need a CD-R recorder or a cassette tape deck.
I told you so, EQ = BAD.
Bob
post #37 of 56 Old 04-07-2009, 06:54 PM - Thread Starter
Bob
oh. the only thing I have was the yamaha cdc 655 5 disc player. I don't have any recording components. I thought that was only meant for producers or audio engineers
post #38 of 56 Old 04-07-2009, 06:55 PM - Thread Starter
If I use the Line in and Line out for the receiver connections, where do I put the cd player then??
post #39 of 56 Old 04-07-2009, 06:57 PM
whoaru99's Avatar
Liked: 69
To the CD inputs on the receiver, if I understand the question properly.
whoaru99 is offline
post #40 of 56 Old 04-07-2009, 06:59 PM
Post #27 have all the answers.
If you cannot do, don't try. Forget about equalizer and concentrate on good music. If your Yamaha is not performing to your taste, time for new speakers.
Bob
post #41 of 56 Old 04-07-2009, 07:01 PM - Thread Starter
that's the first thing I did... all I got was low sound.
I think Lord is right, I should just forget about this
post #42 of 56 Old 04-07-2009, 07:02 PM
whoaru99's Avatar
Liked: 69
Post 27 may have the answers, I didn't check it 100%. But the terms used are going to be confusing because they're generally what you'd see on a pro audio setup, not a home EQ.
whoaru99 is offline
post #43 of 56 Old 04-07-2009, 07:04 PM
whoaru99's Avatar
Liked: 69
So then you pushed the CD button on the receiver, and the Tape Monitor button the receiver, and was sure the EQ was powered on, and the Tape Monitor button on the EQ was off?
Why don't you post us a picture of those EQ controls (again, not the sliders, the other controls).
whoaru99 is offline
post #44 of 56 Old 04-07-2009, 07:16 PM - Thread Starter
wait... i'm getting a response..hold
post #45 of 56 Old 04-07-2009, 07:17 PM
Kal Rubinson's Avatar
Quoted: 677 Post(s)
Liked: 460
I wasn't talking about any receivers.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #46 of 56 Old 04-07-2009, 07:42 PM
Nope, same for Pro or home.
Bob
post #47 of 56 Old 04-07-2009, 07:52 PM
whoaru99's Avatar
Liked: 69
Sorry, I disagree.
I've never seen a "home" EQ with buttons labeled as described.
Mine (from days past) have all been labeled with terms like EQ Bypass, EQ Record, Tape Mon 1, Tape Mon 2, Dubbing 1>2, Dubbing 2>1, etc.
None of the post EQ, pre EQ sort of thing like I've seen on pro gear. Of course, I have not seen all EQs, but I have seen quite a few.
Anyway, it's minor quibbling over terms. Hopefully AudioBeginner is off listening to his equalized tunes.
whoaru99 is offline
post #48 of 56 Old 04-07-2009, 08:03 PM
Sorry, I disagree.
Means exactly the same thing. But anyway like you said.
Bob
post #49 of 56 Old 04-07-2009, 08:06 PM - Thread Starter
I am listening to my equalized tunes alright...but it seems like they are just sounding all muffled lol. I think I might need an audio engineer to help me out and simulate the sound of the Bose Wave System
post #50 of 56 Old 04-07-2009, 08:12 PM - Thread Starter
thanks you guys for helping me connect the cables though What would I do without you
post #51 of 56 Old 04-07-2009, 08:13 PM
Quoted: 677 Post(s)
Liked: 460
That's pretty funny.
Kal Rubinson
post #52 of 56 Old 04-07-2009, 10:20 PM
It is indeed.
Bob
post #53 of 56 Old 04-08-2009, 06:13 AM
penngray's Avatar
Liked: 43
You guys are aware of his previous BOSE thread? This is just an extension of that thread.
penngray is offline
post #54 of 56 Old 04-08-2009, 06:20 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
No, I was not aware, but this is the first post for me in this thread. I didn't post because I couldn't understand why someone would want to add an equalizer to a receiver that already problably has one built into it. Lets eq an eq'd receiver. Sounds like the ticket to me.
phantom52 is offline
post #55 of 56 Old 04-08-2009, 06:48 AM
whoaru99's Avatar
Liked: 69
OP's receiver does not have GEQ/PEQ built-in. It has bass and treble controls.
whoaru99 is offline
post #56 of 56 Old 04-08-2009, 09:44 PM
Hey phantomas,
The OP have a Yamaha RX-V490, 10 years old A/V receiver.
Bob
