CONNECTING EQUALIZER TO RECEIVER..look what I did - AVS Forum | Home Theater Discussions And Reviews
post #1 of 56 Old 04-07-2009, 11:01 AM - Thread Starter
AudioBeginner's Avatar
So I got my equalizer today and this is what I did: I connected the RCA cable to the Tape PB of my equalizer and onto the Tape PB of my yamaha v490 and the Rec Out of my equalizer to the Rec Out of my yamaha v490. Pressed "Tape Monitor" on the receiver,pressed "Tape On" and "Equalizer On" on my equalizer and it didn't work! So then I tried to switch the cables around, TAPE PB of equalizer to REC OUT of receiver and REC OUT of equalizer to TAPE PB of receiver, and STILL no luck! :sighs: Any suggestions??
AudioBeginner is offline
post #2 of 56 Old 04-07-2009, 11:07 AM
Kal Rubinson's Avatar
Quoted: 802 Post(s)
Liked: 567
Rec OUT (Tap OUT?) of the Yamaha to the Rec IN of the EQ.
Rec OUT of the EQ to the Rec IN (Tape PB?) of the Yamaha
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 56 Old 04-07-2009, 11:32 AM - Thread Starter
yes i tried that too^ and still got no effect from my equalizer
post #4 of 56 Old 04-07-2009, 12:23 PM
JOHNnDENVER's Avatar
You have L/R analog hookups as your audio source? I believe that's the only way this works.
The only other way is to use it between your pre-outs (if this avr has them) and an external amp on the front L/R channels
EQ's such as this do not integrate well at all with 5.1 systems.
JOHNnDENVER is offline
post #5 of 56 Old 04-07-2009, 01:06 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Yet another reason EQs are not popular with modern AVRs I think I mentioned this limitation in the original thread.
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 56 Old 04-07-2009, 01:15 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
But hteoretically, you should be able to run a device in the tape loop and listen to the device-ified sound, right? I have thought off and on about putting a decent compressor in the tape loop for quiet music times, so I could increase overall level but keep those pesky peaks down. I think it's the same theory, just a different device in the tape loop. Not gonna work (even for 2 channel?) It's clear to me that the processor's compressor settings don't work on CD input . . .
JHAz is offline
post #7 of 56 Old 04-07-2009, 01:16 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
LOOK! THe dyslexic guy posted again! "theoretically" would be more correct. Theoretically.
JHAz is offline
post #8 of 56 Old 04-07-2009, 01:48 PM
DannyMan67's Avatar
I have my old EQ hooked up strictly for the, as my daughter says, "bouncy lights" on my older Denon AVR 5700 ;-) Sure is pretty at night.
DannyMan67 is offline
post #9 of 56 Old 04-07-2009, 02:04 PM
Quoted: 802 Post(s)
Liked: 567
Using the L/R analog connections?
Kal Rubinson
post #10 of 56 Old 04-07-2009, 02:27 PM
penngray's Avatar
Liked: 47
Is that a general term? Because I love that I have complete control with the DCX2496.
penngray is offline
post #11 of 56 Old 04-07-2009, 02:42 PM - Thread Starter
Hey guys, I don't see anything on the back of my receiver that says L/R or "analog" there. I see "Phono" "LD/TV" "TAPE" and "VCR"
post #12 of 56 Old 04-07-2009, 02:59 PM
Lordoftherings's Avatar
I connect an equalizer in the past to my old Pioneer receiver, guess what, I burn out my expensive tweeters.
Since then, no more separate equalizer with any of my receivers.
Audyssey or an integrated Parametric EQ in the receiver is better. You have to be very careful with separate equalisers, never boost the high frequencies more than a couple dbs.
Equalisers are for bad recordings, even then it will make them worst sounding.
That's my opinion about separate equalizers.
Bob
Lordoftherings is offline
post #13 of 56 Old 04-07-2009, 03:03 PM
penngray's Avatar
Liked: 47
Bob
You do realize that active setups inherently have separate equalizers and that active setups are higher up the food chain in the audio world.
Audyssey is not better either (only Pro might be) but ask some PhDs in the audio world and they will explain why Audyssey is a crude fix to problems that people/rooms create.
Sucks you burned out you tweeter though.
penngray is offline
post #14 of 56 Old 04-07-2009, 03:12 PM - Thread Starter
Does anyone know if Marantz SR-92 mk have a pre-amp out where I could connect an equalizer to it?
post #15 of 56 Old 04-07-2009, 03:36 PM
Audyssey is a much better solution anyway, even if it's not perfect.
My tweeters cost $200 a piece. I burn 4 of them over the years, which is not that bad ($800). But you do learn how to respect them and not to go overboard with the treble control or any type of EQ.
Bob
post #16 of 56 Old 04-07-2009, 03:38 PM
Sirquack's Avatar
Beginner, why are you wasting your time with an EQ.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #17 of 56 Old 04-07-2009, 03:45 PM - Thread Starter
Okay, I tried something else. I connected the cable to the Line In of my equalizer to the Rec Out of my receiver and Line Out of my equalizer to the Tape PB of my receiver. There was sound emanating from the speaker but it was VERY low, even when I turn it up And I was playing around with the Output Level of my equalizer and it seems like it had an effect on the speakers... but like I said, the sound was barely hearable!
post #18 of 56 Old 04-07-2009, 03:46 PM - Thread Starter
I wanted to roll off the screeching highs of my Boston Acoustics cr6s
post #19 of 56 Old 04-07-2009, 03:49 PM
No treble control on your receiver?
Your Yamaha 490 does have a treble control, just lower it by about 3db or so.
Bob
post #20 of 56 Old 04-07-2009, 04:12 PM - Thread Starter
Bob
I did....But not enough and the more I lower the treble, I less I could hear vocals. I still want vocals to remain pretty prominent
post #21 of 56 Old 04-07-2009, 04:12 PM
Quoted: 802 Post(s)
Liked: 567
Those are inputs. Are they paired (e.g., L and R)? Do you have a manual? Is there a picture of the back panel?
Kal Rubinson
post #22 of 56 Old 04-07-2009, 04:13 PM - Thread Starter
I guess I could take a pic of the back of my eq and my yamaha v490 for you then...hold on
post #23 of 56 Old 04-07-2009, 04:14 PM
Quoted: 802 Post(s)
Liked: 567
Throw a shawl over them.
Kal Rubinson
post #24 of 56 Old 04-07-2009, 04:44 PM
post #25 of 56 Old 04-07-2009, 04:47 PM - Thread Starter
Here is the back of my receiver:
http://i44.tinypic.com/wcjt42.jpg
And the back of my equalizer:
http://i40.tinypic.com/2eoy0hs.jpg
post #26 of 56 Old 04-07-2009, 04:48 PM
How old is your 490?
Vocals are more concentred aound the midrange area (from about 300hz to 2khz). No midrange control on your Yamaha?
Maybe a new receiver is in your dreams?
Bob
post #27 of 56 Old 04-07-2009, 04:52 PM
Yep, like Kal said, throw a shall over them.
Just kidding, I will not used an equaliser for the reasons I said before.
But if you really insist...
The tape out of your Yamaha goes to the input of your EQ; the tape in of your Yamaha goes to the output of your EQ. The tape in of your EQ goes to the tape out of your tape deck or CD-R; the tape out of your EQ goes to the tape in of your tape deck or your CD-R. Now push the tape monitor on your Yamaha, choose a source you like to listen to.
Set your EQ to Pre EQ for playback of the equalized sound. Set your EQ to Post EQ for recording the equalized sound. Set your EQ to Source for any other source that you play from your receiver.
Set the EQ switch of your EQ to the IN position for the equalized sound.
Set the EQ switch to the OUT position for the original stereo sound.
Let me know how things goes.
Bob
post #28 of 56 Old 04-07-2009, 04:55 PM - Thread Starter
Bob
My yamaha is about 10 years old.. still in very nice condition though
and whaaaatt?? there's actually a receiver out there that has a "Midrange Control" knob like there is a Treble/Bass control on my v490??
post #29 of 56 Old 04-07-2009, 04:58 PM - Thread Starter
my receiver of my dreams would DEFINITELY consist that of a Midrange Control! And IF there is one existing already, please show me a link/pic!!
post #30 of 56 Old 04-07-2009, 05:00 PM
Quoted: 802 Post(s)
Liked: 567
Note the pairs along the bottom are marked as in or out and that each pair consists of a R and L connector. Use the Tape PB/Rec Out pair.
These are two L/R pairs. Use the line in/out pair.
If this does not work, something's wrong. I'd just look elsewhere such as changing the speakers or the room acoustics.
Kal Rubinson
