Newb here need help - AVS Forum | Home Theater Discussions And Reviews
Old 04-09-2009, 06:35 PM - Thread Starter
trusaleen1's Avatar
Ok so i just got my new set up, I have no clue what settings I should set on the receiver and the sub. Here is my new set up
HK 247 receiver
PA 120 sub
Fronts Infinity 252 towers
Center Infinity 250
Using my ceiling JBL speakers as rears
Please help
trusaleen1 is offline
Old 04-09-2009, 08:16 PM
MLKstudios's Avatar
Good choices. Set the sub to a middle level setting, turn the 247 on and run EzSet/EQ.
Then sit back and enjoy.
MLKstudios is offline
Old 04-09-2009, 08:52 PM - Thread Starter
trusaleen1's Avatar
What should I set the crossover and the phase at on the sub?
Old 04-09-2009, 08:57 PM
Sirquack's Avatar
Your receiver will handle the bass management, so you don't want to use the sub crossover setting. If it has a "bypass" option use that, or just turn it to the highest setting to get it out of the way. Setting the phase to 0 will normally be just fine.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
Old 04-09-2009, 11:39 PM
adam856's Avatar
I have the same receiver, Killzone 2 sounds so nice in 7.1
adam856 is offline
