I need help with my HK AVR 247 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-15-2009, 03:27 PM - Thread Starter
Medjai's Avatar
If I have my subwoofer connected to the subwoofer pre-out and my tv connected thru ANY (hdmi, composite, component) video output there is a buzzing noise. If the pre-amp'd output is disconnected the hum goes away and if I unplug the video output the hum goes away. Assistance in this matter would be appreciated.
Medjai is offline
post #2 of 3 Old 04-15-2009, 05:24 PM
DougWinsor's Avatar
This sounds like a ground issue with you equipment, you can check your AC outlets to see if the ground wire's are properly connected.
DougWinsor is offline
post #3 of 3 Old 04-15-2009, 07:03 PM - Thread Starter
Medjai's Avatar
Thank you for the response. I ran an extention cord from another part of the house and the hum was still present. I also tryed two different subs and tested all the pre amp'd outs. It seems any combination of pre-amp outs and monitor outs cause the unit to hum.
I bought this unit as a refurb from the HK ebay store. I emailed them and they are suppose to respond withing two days. I am just worried because they state they will not cover the cost of shipping but hopefully they will if it is infact a defective unit.
Medjai is offline
