HELP! XBOX & Receiver (Marantz) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-19-2009, 11:55 AM - Thread Starter
mister wiggles's Avatar
I just purchased an Xbox Pro and hooked it up to the receiver via HDMI input. There is video but the sound isn't coming through from 5.1 speakers; only the TV. When i was borrowing my friends Xbox Elite, I had no issues with sound from the get-go. A simple HDMI connection to the receiver and I was immediately immersed in "gaming mode"
Is there some sort of different component in the Pro vs Elite that would make the sound pass through the receiver and output to TV?
Are there some settings in my receiver that i need to tweak? I'm running Marantz SR6003
mister wiggles is offline
post #2 of 15 Old 04-19-2009, 12:09 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Which Elite model.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 15 Old 04-19-2009, 01:57 PM
Steve Carr's Avatar
mister wiggles,
go into (system settings), next click (audio), choose (Dolby Digital 5.1) that should do it....
Steve
Steve Carr is offline
post #4 of 15 Old 04-19-2009, 01:58 PM
DougWinsor's Avatar
Have you gone through the audio/video options on the xbox?
DougWinsor is offline
post #5 of 15 Old 04-20-2009, 05:14 AM - Thread Starter
Originally Posted by MichaelJHuman View Post
Which Elite model.
It should be the newer model. It has the updated GUI.
Originally Posted by Steve Carr View Post
mister wiggles,
Steve
I already did that. It seems as if the xbox is sending out signal for 5.1 into the receiver, but the receiver isn't picking up the signal and its just letting it pass through to the TV which is why the TV has sound and not 5.1. I'm thinking it may be an issue with the AVR setup, but I can't seem to find out the missing link.
Yes I have. I did the setup for xbox from the beginning.
post #6 of 15 Old 04-20-2009, 06:00 AM
BobL's Avatar
Liked: 58
Set the input to HDMI and not auto and under preferences make sure HDMI Audio is set to 'enable' and not 'through'.
Bob
BobL is offline
post #7 of 15 Old 04-21-2009, 06:45 AM - Thread Starter
Bob
Thanks Bob. After reading the manual and taking your advice, I am now experiencing game play in 5.1!
post #8 of 15 Old 07-11-2012, 10:19 AM
danvarello's Avatar
do you do that on the xbox or on the marantz thing. (i am currently having the same problem as mister wiggles)
danvarello is offline
post #9 of 15 Old 07-11-2012, 10:35 AM
SniperZoz's Avatar
on the marantz, or whatever your amp is ... you have to tell it were to get the audio from!
SniperZoz is offline
post #10 of 15 Old 07-11-2012, 10:40 AM
jdsmoothie's Avatar
Quoted: 15074 Post(s)
Liked: 7274
jdsmoothie is offline
post #11 of 15 Old 07-11-2012, 10:54 AM
danvarello's Avatar
im trying to hook my xbox 360 (new slim idition) to my home theater. My audio receiver is a marantz SR7005, everytime i try to hook up my hdmi cable from my xbox to the reciever i can only get the video and no audio. I tried to use different audio imputs but nothing seems to work, not even the "GAME" imput, help please.
post #12 of 15 Old 07-11-2012, 11:08 AM
jdsmoothie's Avatar
Liked: 7274
Then it's likely a setting on the xBox as connecting HDMI to the 7005 should be plug-n-play.
Also note there is a dedicate thread for Marantz SR7005 Owner's as well for future questions.
http://www.avsforum.com/t/1270579/the-official-marantz-sr7005-receiver-page/0_100
post #13 of 15 Old 07-11-2012, 12:09 PM
danvarello's Avatar
yes, i know what your referring to on the xbox. its just that i've tryed every setting on itsuch as the dolby digital 5.1 and the 2 others. both do not work. please tell me how to get audio on the marantz audio reciever from the xbox
post #14 of 15 Old 07-11-2012, 12:12 PM
jdsmoothie's Avatar
Liked: 7274
Ensure the xBox is set to "straight decode" and Dolby Digital 5.1.
post #15 of 15 Old 07-11-2012, 01:38 PM
danvarello's Avatar
how do i do that?
