Onkyo TX-SR507 Owners Thread and First Impressions - Page 18 - AVS Forum | Home Theater Discussions And Reviews
post #511 of 517 Old 08-14-2011, 03:13 PM
jonjay's Avatar
Hello,
I have a SR507, a Panasonic BD60 and Samsung PN550. With everything off I turn only the reciever on and select the cd input, all components, including the DVD, cable box and tv unwantedly turn on.
The dvd cues the cd but no sound is emitted and the tv is blank. If I select the DVD mode on the reciever the CD will play and the playlist will show on the TV. All the connections are HDMI. I get the same results when using my Harmony One or manually. Any advice on rectifying this problem would be appreciated. Thanks, JJ
jonjay is offline
post #512 of 517 Old 08-14-2011, 03:38 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi jonjay, its because your dvd is connected to HDMI-1 (DVD/BD). If you want sound from CD input, connect an optical cable from dvd player to OPT-2 (CD) and keeping dvd player HDMI cable to HDMI-1 (thats if the dvd player allows HDMI and optical audio output at the same time).
The unwanted turn on is possible due to HDMI-CEC feature being turned "ON" (and/or Power Control feature) . Some HDMI-CEC trade names are Samsung - AnyNet+, Onkyo - HDMI Control (RIHD) and Panny - Viera Link. Another possible reason is due to your components connected to a power surge stripe like smart power strip.
JChin is offline
post #513 of 517 Old 08-14-2011, 04:10 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
Turn off the hdmi control and you'll be fine. You can also connect a set of analog cables or optical cable to your dvd player and plug them into the cd input on the receiver. Use that input when you want to listen to music and the dvd input when when watching movies.
Afro GT
afrogt is offline
post #514 of 517 Old 08-18-2011, 04:30 PM
jonjay's Avatar
Thank you both for your replies, I'll give these remedies a shot. JJ
jonjay is offline
post #515 of 517 Old 10-28-2011, 01:00 PM
NetComrade's Avatar
Does the amplifier have multiple fuses?
I dropped a piece of metal into it by accident, there was a spark, and no sound afterwards.
But the receiver still turns on, just doesn't function beyond menus.
NetComrade is offline
post #516 of 517 Old 12-02-2011, 02:00 AM
sas_aaron's Avatar
Anyone here using Onkyo 507 experience any problems like audio dropout or DTS "bomb" on Star Wars Blu-ray set ?
For my bluray player, I am using Sony Bdp-s360
sas_aaron is offline
post #517 of 517 Old 02-17-2014, 05:17 AM
lantis872's Avatar
Just one thing: when you launch the Audyssey 2EQ with the microphone given with the Onkyo, does the subwoofer sound in all the 3 steps or just in the first one?
lantis872 is offline
