Op Amp Gain - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-05-2009, 02:48 PM - Thread Starter
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I have a question on op amp gain. For a non inverting circuit where R2 is the resistor connected to ground, and R1 is the resistor between the output and positive input, the gain is roughly 1 + (R1 / R2) when open loop gain is large.
What if there's also a capacitor in parallel with R1? What's it's purpose, and does it effect gain?
"But this one goes up to 11"
MichaelJHuman is offline
post #2 of 8 Old 05-05-2009, 03:40 PM
duvetyne's Avatar
It forms a low pass filter. The capacitive reactance decreases as the frequency increases resulting in low gain at high frequencies, high gain at low frequencies.
duvetyne is offline
post #3 of 8 Old 05-05-2009, 04:18 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 148
Ok, that makes sense. It's a very small cap I think? 100pf?
post #4 of 8 Old 05-05-2009, 04:22 PM
duvetyne's Avatar
Xc = 1/(2*Pi*F*C)
You can figure out the gain at a certain frequency.
If this is on the output of a DAC, it could be part of the reconstruction filter, or it's rolling off the very high frequencies in order to be FCC compliant.
duvetyne is offline
post #5 of 8 Old 05-05-2009, 05:13 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 148
Originally Posted by duvetyne View Post
Xc = 1/(2*Pi*F*C)
Thanks a bunch. I will take a look.
I am looking for a book on electronics to learn some of this stuff, but I am on a budget. I might check the library tomorrow.
post #6 of 8 Old 05-05-2009, 06:53 PM
duvetyne's Avatar
Check out used textbook stores, if there's any nearby.
What is this circuit from?
duvetyne is offline
post #7 of 8 Old 05-05-2009, 08:10 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 148
It's from a receiver service manual. It's the op amp after the 8-channel DAC in the subwoofer stage.
I was curious as to whether the subwoofer signal path was different. The op amp used on other channels are setup for no gain. The subwoofer op amp has gain, and I was curious as to how much.
post #8 of 8 Old 05-06-2009, 03:21 PM
catapult's Avatar
Small caps are often added parallel to the feedback resistor in audio circuits to make sure the circuit doesn't oscillate at very high frequencies due to stray capacitance on the circuit board. The gain drops to unity up high where the cap shorts the signal around the resistor so I guess you'd call it a shelving lowpass filter with a corner frequency well above the audio band.
Check out Siegfried Linkwitz's active crossover pages. He shows the theoretical circuits he's using with no parallel cap but his actual circuit board uses a 220pF cap in parallel with the feedback resistor.
http://www.linkwitzlab.com/filters.htm
http://www.linkwitzlab.com/xo_eq.htm
Edit: okay, here's a pic where SL shows the math for a shelving lowpass. f1 = 1/(2pi*R2*C) for a non-inverting circuit.
Dennis H
catapult is offline
