upscale through dvd or denon avr? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-06-2009, 01:42 PM - Thread Starter
ericos's Avatar
I'm looking for a cheapie dvd player to tied me over. I have the denon 2809ci which does nice upscaling. My question is... should I get a standard dvd player and run component and toslink into the denon and let the denon upscale it, or should I get an inexpensive upscaling dvd player with hdmi.
I like the simpler install of the single hdmi cable, but are any of these units with the hdmi outputs capable of sending a 480 signal over the hdmi cable so I can allow the denon to do the upscaling, or... if I use the hdmi out, am I forced to allow the inexpensive dvd player to do the upscaling?
Eric
ericos is offline
post #2 of 5 Old 05-06-2009, 01:49 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
There is one way to find out. Get a test disc like HQV.
The stickied AVR FAQ may help.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 5 Old 05-06-2009, 01:51 PM
SkiSmuggs's Avatar
An HDMI DVD player will still have settings for output resolution. However, I don't believe HDMI sources are upscaled in the AVR, only analog, so you should verify. There are some fine upscaling DVD players in the $100 range. I'm not sure saving $40 over a $60 one is worth it. Avoid Sony for upscaling and check the DVD forums for recommendations.
SkiSmuggs is offline
post #4 of 5 Old 05-06-2009, 02:17 PM - Thread Starter
ericos's Avatar
you are right... the avr doesn't upscale through the hdmi inputs... good point.
Thanks for the advice.
ericos is offline
post #5 of 5 Old 05-07-2009, 03:12 PM
samsurd2's Avatar
Not sure why you say this. I have a 2 year old Sony DVP-NC85H (5 disc carousel) that does the job very nicely. JMO
samsurd2 is offline
