What does Direct mode do on my Yamaha RX-V465? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-15-2009, 07:20 PM - Thread Starter
gtcroz's Avatar
I recently purchased a Yamaha RX-V465 to complement my new HDTV. It's my first foray into home theater replacing 10 year old and 15 year old RCA TV & Aiwa receiver. This new receiver has me a bit confused with regard to some of the features.
First of all, I've got the audio being fed via HDMI into the receiver via my Motorola DCH3200 cable box. The audio shows up as Dolby Digital on the majority of channels.
I've noticed a difference in sound between the different modes and even after reading the manual I'm at a loss as to what the following modes mean (and yes, I did RTFM)
- Direct
- Straight
- There's a button called "Sur. Decode" which I have no idea what it does
I think that I've figured out the Stereo/7 Channel Enhancer. It seems like that lets me toggle between 2 speaker mode and a version that plays the 2 channel audio through all 5 of my speakers.
Can anybody help a noob out and explain some of these different options and possibly recommend what's the best one to choose for watching sports or movies?
gtcroz is offline
post #2 of 6 Old 05-15-2009, 07:36 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Originally Posted by gtcroz View Post
I
- Direct
- Straight
Direct mode bypasses some processing. Try listening to some favorite songs in Direct mode to see if you like it. You will lose bass management, in other words, your sub won't be used to play bass.
Straight mode is the most obvious mode. If the receiver is getting Dolby Digital, it will play Dolby Digital. If it's getting two channel PCM, say from a CD, it will play two channel stereo. Some processing is done such as bass management, and YPAO.
Sur. Decode will let you apply processing to two channel sources, such as music and get surround sound. Dolby Pro Logic II is the mode I would use if I wanted surround sound from stereo and did not have rear speakers.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 6 Old 05-15-2009, 07:53 PM - Thread Starter
gtcroz's Avatar
Thanks for the quick and helpful response.
So when I'm in "direct" mode, is it still using dolby digital compression and just bypassing sound processing of my receiver, or is it somehow getting the audio via a different higher quality transport? Is this something I would want to use for watching movies?
And it sounds like straight is the mode I want to be in if I'm not in direct mode and I want to bypass all those cheesy "Concert hall in Beirut", "Bomb Shelter" movie/music presets?
This seems to make sense now.
For anyone considering this receiver, I'm quite happy with it. It's not exceptionally loud. I'm using it to power two Polk TSI300s and a Polk CS10. I'm using my old Aiwa fronts as the rear speakers. It sounds absolutely fantastic, especially after using the microphone it comes with to automagically calibrate my speakers. It was a steal at around $300.
gtcroz is offline
post #4 of 6 Old 05-15-2009, 08:07 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
I assumed that in order to use the direct mode you had to have the left and right standard RCA type cables(from the DVD player) hooked up, instead of a digital cable.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #5 of 6 Old 05-15-2009, 08:50 PM
Quoted: 266 Post(s)
Liked: 148
On all my receivers, Direct works for either digital or analog. The signal path differs of course.
For digital, there's no room correction or bass management. Video circuits might be turned off, they are on my receiver.
For analog, it will bypass the digital section.
post #6 of 6 Old 02-14-2010, 08:14 PM
dallastt's Avatar
Quoted: 12 Post(s)
Liked: 45
late into this thread, but on Movies I use straight or straight enhanced.
This is on Blu-ray for %90 of my movies. I notice it sounds quite a bit better than direct. Now for music Direct is like night and day compared to any other mode. It sounds SO much better it blows my mind, and pisses me off because I can't use my sub in this mode. For all my media I use my PS3 w/ bitmapping 3 on and most of the time I use 176khz upconverting.
I'm using this avr w/ Klipsch Towers and a Velodyne sub.
2 ch room
Amp/DAC - Peachtree Nova 125
Speakers - Bowers and Wilkins CM6 S2 on B&W stands.
Desktop
Amp/Dac NAD D 3020
Speakers Bowers and Wilkins DM601S3
dallastt is offline
