Lexicon MC1 diagnostics faults - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-16-2009, 02:15 PM - Thread Starter
scott jensen's Avatar
My Lexicon MC1 decided to go through diagnostics checks again and again instead of starting up.
I have just shut off power to it for a while...hope that resets it.
anyone know what to look for?
Scot
scott jensen is offline
post #2 of 8 Old 05-16-2009, 02:25 PM
MLKstudios's Avatar
Pull all the connections before you "reboot".
MLKstudios is offline
post #3 of 8 Old 05-17-2009, 08:07 AM - Thread Starter
I will try this today.
as of last night, I did not even get the diagnostics message...its black, and no lights regardless of which button i press.
post #4 of 8 Old 05-17-2009, 01:06 PM
MLKstudios's Avatar
Sounds like my Vizio.
post #5 of 8 Old 05-18-2009, 01:56 PM - Thread Starter
DEAD!
Rats!
oh well...anyone want to break it open to see whats inside?
post #6 of 8 Old 06-18-2009, 12:22 PM
Ed Rogers's Avatar
Scot
Mine just started doing the same thing. I recently replaced the power supply, so I don't think that is the issue.
Is there a hardware reset of some sort that might help?
Is there a battery in the unit that might be dying?
Ed Rogers is offline
post #7 of 8 Old 06-18-2009, 12:38 PM
duvetyne's Avatar
sure
duvetyne is offline
post #8 of 8 Old 07-30-2012, 09:16 PM - Thread Starter
well it happened again...
now if i can just remember where I brought it to get it fixed last time.
Scott
