Official Onkyo TX-SR707 Thread [No Price Talk] - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1561 of 3627 Old 12-28-2009, 08:54 AM
DarthAVS's Avatar
Originally Posted by WilliamG View Post
lol.
Sorry, but lol. No wonder you're having issues. AMP is the worst thing to happen to TVs since lightning storms. Turn AMP off and then try it. Why would you even care about 24fps if you're running at 120fps anyway?! Do you understand how AMP works? It INSERTS frames that AREN'T THERE to smooth out the picture. Blu-rays at 24p are running at 24fps natively on your TV with AMP set to OFF by invoking 5:5 pulldown (120hz divided by 5). By turning AMP on, you're completely undermining the point of 24p.
I understand exactly how AMP works. I tried it with AMP off. This receiver does not pass 1080p/24 correctly. That is the problem, not my TV. Since 24 does not divide in to 60 correctly, the AMP feature is smoothing this out. Maybe you didn't understand my post. That is probably why I don't see the advantage of 1080p/24 no AMP vs 1080p/60 with AMP on. Is that a little clearer?
DarthAVS is offline
post #1562 of 3627 Old 12-28-2009, 09:12 AM
scionracing's Avatar
I would think that most all AVRs support 24p. For a receiver that is HDMI pass-through, they should just pass on the signal untouched to your display.
For AVRs like the SR707 with HDMI repeating architecture (HDMI-audio), the same should be true. The 24p output from a Blu-ray player should be transmitted to the display untouched.
Further, this Onkyo (and many other mid-range to high-end AVRs), have a Pure Mode or Direct Mode. This is a great feature, as it allows you to send the unadulterated signal to your display in order to evaulate your display and not your AVR. Has anyone tried engaging this mode and see if telecine judder is present?
This is an absolute dealbreaker for many people if 2:3 pulldown is introduced somewhere along the chain.
scionracing is offline
post #1563 of 3627 Old 12-28-2009, 10:19 AM
embit's Avatar
AMP does NOT "smooth" 24 frames into 60 frames. If you have a 120hz (or 240hz) samsung and you disable all AMP features, the set will still display the 24hz source correctly without a 2:3 pulldown.
5:5 (or 10:10) pulldown is a feature of the 120(240)hz sets, not of AMP.
anway, I believe you said you set the reciever to pass-through, have you tried setting "Direct Mode" as scionracing mentions? I believe this is described on page 26 of the manual:
Originally Posted by Onkyo 707 Manual pg 26 View Post
It is also recommended that you press the [VCR/DVR] and [RETURN] buttons on the AV receiver at the same
time. Select Skip in the VideoProcessor setting on the display.
not sure if this is the same thing as DirectMode, as I don't yet have a 707 to try this on
finally, have you tried contacting Onkyo?
embit is offline
post #1564 of 3627 Old 12-28-2009, 11:17 AM
milosch's Avatar
I've enjoyed reading most of this thread AFTER having selected and purchased a 707 myself. I received it on the Friday before Christmas from Newegg at $599.
I'm finding my way through the options and doing well so far. Except that every time I power up the system it switches to TV/TAPE mode. I have to select CBL/SAT, which is where I had left it before. This is the Cable box, connected only via HDMI. Other source is an old sony changer using optical, and a PS/3. Any idea what I did to it?
EDIT: By the way, this replaced a JVC RX-8000. It still works quite well except that all of the digital audio inputs died about 2004 or so. I swapped it out mainly to get around the source switching hassles since it had no HDMI or component, etc. Man, I am really happy so far with the Onkyo sound quality.
milosch is offline
post #1565 of 3627 Old 12-28-2009, 11:47 AM
davewe's Avatar
I'm loving my 707 but have a question. I've input my HTMI connections into the receiver (Satellite, Blu-ray, Apple TV) and then output to HDMI in my Sony TV. All great. However by only using 1 HDMI input into the TV for everything, I no longer have the ability to tweak the TV based on the input. I use to use this for Cinemotion and Motion Enhancement, having different settings for Satellite TV vs. Blu-Ray. Any idea how I could do this now?
davewe is offline
post #1566 of 3627 Old 12-28-2009, 12:04 PM
milosch's Avatar
I am not sure when this price drop occurred, but I noticed today on Amazon.com . It is now listed as 499.00. Seems like it was higher when I added it to my cart back in October (forgot about it and Amazon gave me a reminder of the cart item and price drop when I logged in today to order something else)
Ouch. I wish I had looked there. I paid $599, and Newegg won't match, but they did credit $25 to me after pointing this out to them. Beats $90 for the restocking fee, I guess...
milosch is offline
post #1567 of 3627 Old 12-28-2009, 01:29 PM
DarthAVS's Avatar
OK....The procedure on page 26 resolved the issue. However, the lip sync is pretty bad now. I know there is an A/V adjust, but the lip sync is not always off by the same amount of time. If I fix it for one scene, sooner or later it is off again. I found going back to 1080p/60, enabling the lip sync in the receiver and setting AMP on my TV gives me the best picture and sound combination.
Any suggestions for the new issue?
BTW I was using Hangover as my source material.
DarthAVS is offline
post #1568 of 3627 Old 12-28-2009, 02:33 PM
nixonrsx's Avatar
Blaaahhh, just got a call from 6ave.com today to tell me the Onkyo 707 I ordered yesterday is not available at this time, and it should be 4-6 weeks before they get any. I dont really wanna wait, cause it only $30 more dollars on Amazon. Oh well...
nixonrsx is offline
post #1569 of 3627 Old 12-28-2009, 04:16 PM
realbaddog's Avatar
Wow, I ordered mine on Christmas eve, and just got a email today that it was shipped. I almost waited until after Christmas to order it........ Glad I didn't....
By the way, I bought the Onkyo HT-RC160 (really liked the sound quality/features) a couple of weeks ago at Costco for $300.... then I saw the deal online (via Slickdeals.net) for the 707, and after reading this forum thread and other reviews.... I really didn't want to settle for less......So when I get the 707 in, back to Costco goes the RC160...........
-realbaddog
realbaddog is offline
post #1570 of 3627 Old 12-28-2009, 04:55 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
Just got my 707 in today. First impressions are that of irritation. Bitstreaming PCM and DTS HD MA required over 100ms of audio/video sync adjustment from my slim PS3, whereas I never had to do that on my 705.... :|
WilliamG is online now
post #1571 of 3627 Old 12-28-2009, 04:57 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
No, sadly you don't understand how AMP works. This receiver passes 24p perfectly.
post #1572 of 3627 Old 12-28-2009, 05:21 PM
DarthAVS's Avatar
I see the 1080p/24 is passing perfectly. Having to adjust the audio this much is not perfect. Now I know what "special" member means.
DarthAVS is offline
post #1573 of 3627 Old 12-28-2009, 05:47 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
It's hardly a big deal, but something I definitely noticed. I've adjusted it once for my PS3 and everything else is flawless. Obviously not every player plays nice with Bitstreaming, so having this option SOLVES the issue.
I've done some more testing, and 24p definitely works. And thanks for the personal attack.
post #1574 of 3627 Old 12-28-2009, 05:49 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
On a different note, is there a point to the Audyssey setup? I just plugged in all my speakers and adjusted the DB level based on how far they are away from me... Not sure there's any point to the setup mic?
post #1575 of 3627 Old 12-28-2009, 06:00 PM
embit's Avatar
audyssey does more than just adjust dB based on distance to the listener, it also does time+frequency based EQing in order to limit the interference caused by the room.
I haven't heard it myself (still waiting!!) but considering there's more than a handful of people buying the 707 (with MultiEQ) over lesser versions of Audyssey, I'd guess it's worth it.
edit: oh, and the results of the Audyssey setup also play into the Dynamic EQ feature as well, so if you sometimes need to listen at low volumes this should help you with a better experience in these situations.
embit is offline
post #1576 of 3627 Old 12-28-2009, 06:04 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
Thanks for the info. I guess I'll give it a try..!
post #1577 of 3627 Old 12-28-2009, 06:10 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
OK, so I plugged the mic in, it went through its zapping sounds, and then that's it. Done? Nothing else to mess with?
post #1578 of 3627 Old 12-28-2009, 06:54 PM
Alex A's Avatar
That's it. Just make sure Audyssey Dynamic EQ is turned ON. See pages 82 and 86 in the manual.
Alex A is offline
post #1579 of 3627 Old 12-28-2009, 07:09 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
It's on. I just wish I understood crossovers etc better than I do. I've no idea if any of them are set correctly by the mic's pickup. I'm running a Klipsch C-2, 2x Klipsch B-3s for the front left/right, and 4x Klipsch S1 for the rear surrounds (7.1 total) with a Klipsch Sub-12 as my subwoofer.
e.g. here's the link to my center channel:
http://www.klipsch.com/na-en/product...pecifications/
So how do I know what to set the ohms to and the crossover? It says in the receiver setup that I can pick 4 ohms or 6 ohms. But not 8 ohms which I believe my C-2 is!
All help greatly appreciated!
post #1580 of 3627 Old 12-28-2009, 07:20 PM
embit's Avatar
can't really help you with the crossover freq, as I'm new to all of this too. Try checking out the Audyssey sticky, has a lot of details about that sort of thing.
As for ohms, you'll want to set the Onkyo to be 6ohm. This setting is actually "6 or more ohms", and allows for more power to go to your speakers. The details of this are stated somewhere earlier in this thread
embit is offline
post #1581 of 3627 Old 12-28-2009, 07:57 PM
nateg20's Avatar
I just got my 707. It seems to sound great. But its really hard to tell because everytime I change anything (even go into setup or change channels IE resolution change) it trips my emotiva xpa-3 and sends it into protection mode. I'm using the emotiva for the front three speakers. Everything else stays on. I didn't have any problems with my old Yamaha feeding it. Any ideas? Thanks!
nateg20 is offline
post #1582 of 3627 Old 12-28-2009, 08:15 PM
hand-filer's Avatar
What type of interconnects are you using?
hand-filer is offline
post #1583 of 3627 Old 12-28-2009, 08:18 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
Thanks again. I also run all my 5.1 movies, including TrueHD and DTS HD MA movies in Pro Logic IIx to matrix my rear surrounds. I assume there's no "better" sound mode than this to matrix the rears and leave the rest of the audio "untouched."
post #1584 of 3627 Old 12-28-2009, 08:23 PM
nateg20's Avatar
They are some older AR rca cables. Fat blue things, gold plated. I can try to some standard plugs I have a lot of those laying around.
nateg20 is offline
post #1585 of 3627 Old 12-28-2009, 08:29 PM
nateg20's Avatar
Standard interconnects fixed the problem. Odd. Thanks for the great reply. Any interconnects you recommend using?
nateg20 is offline
post #1586 of 3627 Old 12-28-2009, 08:42 PM
hand-filer's Avatar
I'm running Energy Reference cables. 5m lengths.
All I had to work with at first was one Monster Cable paired interconnect and a single interconnect. For whatever reason the paired interconnect did not play nice with the amp.
Call me biased but this is one great sounding amp for the money.
post #1587 of 3627 Old 12-28-2009, 09:06 PM
garnuts's Avatar
Quoted: 86 Post(s)
Liked: 60
I have 9.1 speakers connected, regular 7.1 plus front wides for Audyessy DSX.
After running Audyssey setup using this guide: (The Audyssey thread is 730 pgs if you really want to know more about it !)
http://www.avsforum.com/avs-vb/showp...postcount=5701
I use the 'THX Cinema' listening mode (pg 78 in manual) to matrix the SB speakers or 'Audyessy DSX' to engage the front wide speakers, which does not use the SB speakers.
For most TV and Bluray viewing I usually use the DSX listening mode which really enhances the front sound stage. The DSX feature is the main reason I upgraded from the 706.
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, OWM3, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is offline
post #1588 of 3627 Old 12-28-2009, 10:06 PM
WilliamG's Avatar
Quoted: 472 Post(s)
Liked: 220
Thanks for the info. Do you use THX Cinema or THX Select2 Cinema?
post #1589 of 3627 Old 12-28-2009, 10:55 PM
enphenate's Avatar
Quoted: 16 Post(s)
Dear ,
We are writing to inform you that the item you ordered is on order with the manufacturer. We apologize for any inconvenience this delay may cause you.
Our current status shows that:
Order# xxxxxxxxx will ship within the next 21 days. You will receive an email confirmation when your order has shipped.
Sincerely,
Sixth Avenue Electronics
Customer Service
Ordered right before Christmas, glad i snagged one.
i returned the 607 that i bought for $340 and shelled out $130 more for he 707 as i figured his would be he most future proof purchase or me! bummer though because i have this full speaker set up in my new room, but now i gotta wait a few weeks.. oh well
enphenate is offline
post #1590 of 3627 Old 12-29-2009, 08:01 AM
dsiebenh's Avatar
So last night I got my Win XP SP3 PC running ITunes to pass audio via HDMI to the Onkyo, along with 1080P video. Looks and sounds great.
The issue now is that the Onkyo does not pass this audio to Zone2, since it is digital.
I have 2 questions:
1) The solution I plan to implement is to use Virtual Audio Cable to clone the ATI HDMI output to the Realtek analog Audio output. With both HDMI and RCA cables plugged into the PC and Onkyo, I should get the same audio in both Zone 1 and 2, just that Zone 1 will be digital and Zone 2 analog, correct? And there will be a slight delay in Zone 2 due to the cloning, which is fine. Is this a good solution, or is there a better solution to clone digital PC audio to an analog port?
2) Just to make sure I understand the DACs... For my signal that arrives via digital HDMI, the audio is being decoded on the Onkyo via the Burr-Brown codecs? In my limited test last night it sounded great. And the analog audio is being decoded on the PC, via whatever codec Itunes is using?
dsiebenh is offline
Onkyo Tx Sr707 7 2 Channel A V Surround Home Theater Receiver , Receivers Amplifiers , Onkyo Tx Sr606 Receiver
