*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #481 of 9516 Old 06-22-2009, 02:28 PM
dpslhr's Avatar
Thank you guys appreciate the quick turnaround.
I am compairing it with my Panasonic all in one system which I am replacing and bass was pretty good on it. Also I have tried watching TV with prologic enagaged and ran some DVD's with dolby 5.1 audio. I don't have HD source currently so cannot test with HD audio.
Yes I have followed Audessey setup guide line by line several times since couple of days ago.
Bass is extremely low when DynEQ is not engaged but when I engage the DynEq it gets little better but still very low. The only thing I think which I couldn't go around was the sub's location, I have it in the corner but about 6inches away from both(back and sidewall) walls, which again in my opinion shouldn't matter that much in having close to no bass at aound 20db of volume level. Do I have to turn the volume up to reference level to really hear the bass??
My room is 15x20 and I have all 5 speakers monted on walls. Sub is sitting beside my TV stand. Hope this helps little in figuring out what else can I try.
dpslhr is offline
post #482 of 9516 Old 06-22-2009, 03:01 PM
lilbat23's Avatar
Hey All - I was hoping to get some help on an issue with my new 1910. I would like to use my HDTV speakers (new speakers haven't arrived yet), but I can't seem to get sound to pass through the receiver via hdmi. I've set the HDMI Audio Out to TV on the receiver's menu but I still get no sound - any ideas? I am using hdmi cables from my cable box -> receiver -> hdtv. Thank you all in advance!
lilbat23 is offline
post #483 of 9516 Old 06-22-2009, 03:07 PM - Thread Starter
batpig's Avatar
Quoted: 3695 Post(s)
Liked: 3547
have you configured your cable box to output HDMI audio?
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #484 of 9516 Old 06-22-2009, 03:10 PM
lilbat23's Avatar
Hi Batpig, thanks for the quick reply. Yes, my cable box is configured. If I take the receiver out of the loop by running an hdmi cable directly to the tv, sound works!
lilbat23 is offline
post #485 of 9516 Old 06-22-2009, 04:02 PM
jdsmoothie's Avatar
Quoted: 14592 Post(s)
Liked: 6924
Do you have the correct HDMI input selected for whatever cable source is being used? What is the front panel display indicating? What speaker input lights are lit on the left side of the display?
jdsmoothie is online now
post #486 of 9516 Old 06-22-2009, 04:21 PM
lilbat23's Avatar
Yes, the correct input is selected...the video works, so I'm pretty sure the input is right.
lilbat23 is offline
post #487 of 9516 Old 06-22-2009, 04:25 PM
jdsmoothie's Avatar
Liked: 6924
And the rest of what I asked? Are you using a HDMI-DVI adapter?
post #488 of 9516 Old 06-22-2009, 04:27 PM
SoundofMind's Avatar
Liked: 166
Originally Posted by troiano View Post
I appreciate the advice, and insite. I reread my post after posting it, and it sounds a bit catty, and I didnt mean that in the least bit, so Im sorry if it came across that way.
Not at all. Hey, if the bouncer at the club does get a little "catty", who's gonna call him on it?
I too have a little hifreq hearing loss from standing in front of my amp in the "old time rocknroll" days. Perhaps that's why I prefer the "Audyssey Flat" curve, which doesn't roll off the highs. Give it a listen if you haven't tried it yet.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #489 of 9516 Old 06-22-2009, 04:31 PM
lilbat23's Avatar
Not using a DVI adapter. The screen shows the following: HDMI Auto, PLII C. I've tried changing the surround mode, but none of them have an effect. Thank you again!
lilbat23 is offline
post #490 of 9516 Old 06-22-2009, 04:48 PM
jdsmoothie's Avatar
Liked: 6924
post #491 of 9516 Old 06-22-2009, 05:19 PM
frankmar's Avatar
Quoted: 84 Post(s)
Turn HDMI Control OFF.
Yesterday wanted to watch a movie from PS3, 1910 and to the tv via HDMI, I was getting the same problem,
I had Video, but no sound.
Switched to Tuner, had sound
Switched to Cable had video and sound
Switched back to PS3 only video and still no sound.
did several things, such as unplugged the hdmi from PS3 and 1910 went into the menu checked severa stuff
switched receiver and Ps3 off and after had Video and Sound from Ps3.
What caused this I don't know and what activated I still don't know.
PRESENTLY:    TCP55VT60               PS3 SLIMIR 2 BT RE-BL DENON X2200W [B] FIBETV
MOTOROLA PVR VIP-2262
PARADIGM MONITOR 7 v6 front speakersKLIPSCH SUBWOOFER
KSW10
kLIPSCH SATELITE SS-1kLIPSCH CENTER SC-1HARMONY ONE
PARADIGM ATOMS V6 (front height) NOW SYSTEM IS 5.1.2
frankmar is offline
post #492 of 9516 Old 06-22-2009, 05:30 PM
jdsmoothie's Avatar
Liked: 6924
Your particular issue sounds more HDMI handshake related which can be resolved sometimes by powering up each of the components in a different order. His could be as well, although more than likely HDMI Control related.
post #493 of 9516 Old 06-22-2009, 05:47 PM
lilbat23's Avatar
Yes, I've tried with this setting both on and off, still no luck. If order of operations is important, what order do you suggest?
lilbat23 is offline
post #494 of 9516 Old 06-22-2009, 06:06 PM
jdsmoothie's Avatar
Liked: 6924
Try both ways ... Sat--->1910--->TV and TV--->1910--->SAT
post #495 of 9516 Old 06-22-2009, 06:33 PM
lilbat23's Avatar
Still no luck! Any other ideas? Do any other settings affect the audio out?
lilbat23 is offline
post #496 of 9516 Old 06-22-2009, 07:00 PM
jdsmoothei's Avatar
You should try and reset the microprocessor. I have found that this will help a lot of the unknown problems. It might just help in your case, who knows!
jdsmoothei is offline
post #497 of 9516 Old 06-22-2009, 07:05 PM
Asb-123's Avatar
does anyone know how much power this thing uses when in standby
Asb-123 is offline
post #498 of 9516 Old 06-22-2009, 07:24 PM
Splicer010's Avatar
Liked: 40
What speaker icons are showing up on the left side of the front of the AVR display? That tells you what is being received. If you've only got 2 lights FL and FR, then the xBox is only sending a 2.0 signal.
The 790/1910 has this feature still??? I thought the 789/1909 were the last models to utilize that feature???
Splicer010 is offline
post #499 of 9516 Old 06-22-2009, 07:30 PM
Asb-123's Avatar
yea.
Asb-123 is offline
post #500 of 9516 Old 06-22-2009, 07:47 PM
Splicer010's Avatar
Liked: 40
Originally Posted by Asb-123 View Post
yea.
Yea??? Yea what???
To answer your watts used question...if the 1910 is like the 1909 standby only uses 3 watts...Standby HDMI on uses 30 watts...
post #501 of 9516 Old 06-22-2009, 07:50 PM
Asb-123's Avatar
are you talking about light indicators to show which channels are being used. if so then yea.
Asb-123 is offline
post #502 of 9516 Old 06-22-2009, 08:04 PM
Splicer010's Avatar
Liked: 40
Yeah what then??? The 7790/1910 does or does not have the lights???
post #503 of 9516 Old 06-22-2009, 08:06 PM
Asb-123's Avatar
if its the lights i think it is, then yea it had the lights.
Asb-123 is offline
post #504 of 9516 Old 06-22-2009, 08:14 PM
Splicer010's Avatar
Liked: 40
OK thanks...The pictures don't show that on the 1910 but do on the 890...
http://www.usa.denon.com/ProductDeta...Zone+Receiver#
Weird cause they are 2 different display panels...Are you sure the 1910 has the speaker icons???
post #505 of 9516 Old 06-22-2009, 08:36 PM
lilbat23's Avatar
Thanks, yeah I tried that too hoping it would work, but still no audio! Looks like I have to return this unit and get a replacement...crappy! Thanks for everyone's help!
lilbat23 is offline
post #506 of 9516 Old 06-22-2009, 08:37 PM
Asb-123's Avatar
my 1910 is still in the mail. I cant check for sure. I cannot see why it wouldn't have it. Even my other cheap $300 HTIB has them.
Asb-123 is offline
post #507 of 9516 Old 06-22-2009, 08:42 PM
Splicer010's Avatar
Liked: 40
Denon cut costs on the 1910 and I suppose one of the things that got cut were the icons...If the 1910 had them I would imagine the picture of the unit would show as much...and it doesn't show any...
post #508 of 9516 Old 06-23-2009, 01:46 AM
jdsmoothie's Avatar
Liked: 6924
Ahh finally! My new assistant has arrived.
post #509 of 9516 Old 06-23-2009, 01:51 AM
jdsmoothie's Avatar
Liked: 6924
Good catch! Probably why lilbat23 never answered my question. The input and output speaker icons aren't there on the 1910!
What a shame though as those little buggers are quite helpful IMHO, especially when troubleshooting. Although they are still present on the higher 2010 models (2310/890, 3310, 4310).
post #510 of 9516 Old 06-23-2009, 02:11 AM
jdsmoothie's Avatar
Liked: 6924
Yea??? Yea what???
Standby (HDMI Control - OFF) = 0.3 watt
Standby (HDMI Control - ON) = 30 watts
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
