*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 297 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
Old 01-05-2012, 07:25 AM
natchie's Avatar
Quoted: 27 Post(s)
Liked: 32
Hi, my problem is somewhat peculiar. WhenI quickly powered up all of the devices in this order: Magnavox DVR, DirecTV, then Denon 1910, nothing happened. I had to resort back to the menu, and fix the INPUT Settings. Couple of times, I found different setings than originally placed. This happened at least three times...
What would cause the settings to be changed? I originally had Toshiba TV there but taken by my ex-wife, I am using Acer with DVI for monitor and coaxial for sound.
natchie is offline
Old 01-05-2012, 07:28 AM
jdsmoothie's Avatar
Quoted: 13091 Post(s)
Liked: 6047
In order to mitigate HDMI handshake issues, the recommended start up of your components is TV, then AVR, then source device. If you are using a Quick Select button to power on the AVR or select a particular source, you'll need to re-memorize the Quick Select after making any input changes.
jdsmoothie is online now
Old 01-05-2012, 11:52 AM
animoxiety's Avatar
Correct as well as require you to run AUTO SETUP again.
Alright, thanks. I will keep this option (resetting the microprocessor) as my last resort. Is this actually a common way to fix things or just a shot in the dark?
Anybody got any other ideas?
animoxiety is offline
Old 01-05-2012, 11:57 AM
jdsmoothie's Avatar
Liked: 6047
It's the last resort, however, does resolve some issues which cannot otherwise be resolved.
Old 01-11-2012, 03:13 AM
Jamma's Avatar
Hi there,
I have a little problem with my 1910. I have a Xbox360 hooked up with a HDMI cable to my Denon. For some reason Denon doesn't recognize the DD 5.1 from the Xbox.....it only gives me Stereo sound.
When I go to Xbox settings and manually set the output sound first to stereo and then back to DD 5.1, the Denon changes to DD 5.1.
A suggestions? Thanks.
Jamma is offline
Old 01-11-2012, 03:30 AM
jdsmoothie's Avatar
Liked: 6047
As you learned, you must manually set the xBox to DD 5.1 in order for it to pass DD 5.1 to the AVR. If the xBox won't stay on DD 5.1 for some reason, it's an issue with the xBox as the AVR can only play what it receives.
Old 01-11-2012, 07:42 AM
tezster's Avatar
Quoted: 440 Post(s)
Liked: 310
This isn't a significant issue as I don't really use it, but I'm curious what people's experiences are with the Anchor Bay internal video scaler? I've tried using it, and the results I get are mixed. My HD-DVD player output is limited to 720p/1080i - I set that particular source to output 1080p (via HDMI/digital) on the receiver and it functions normally.
When enabled for my TV source (cable box), which is also connected via HDMI, this is where the results become inconsistent. I will stick to discussing the HD sources for the purposes this post.
The STB is set to output the native broadcast signal of the source channel (which is either 1080i or 720p). Two problems come up: 1080i signals are output as 1080p, but when switching to a channel broadcasting 720p, the signal isn't scaled to 1080p but left untouched at 720p. The other problem is certain channels (such as Discovery) exhibit a lot of display corruption i.e. blocky, artifact-laden video. I don't suppose this is normal behaviour?
tezster is online now
Old 01-11-2012, 09:42 AM - Thread Starter
batpig's Avatar
Quoted: 3643 Post(s)
Liked: 3487
the ABT chip in the 1910 model is really best suited for SD upscaling, it's a less powerful model than the 2010/2015 chip in the 2310 and higher models. Don't expect it to do much with HD signals. Frankly, even with the better chip I wouldn't expect much improvement with HD signals, they are already HD!
anyway, none of the issues you describe have anything to do with the quality of the scaling:
- the blocky artifact-laden video is not caused by the video chip, that's just compression or data rate / signal issues with the cable channel itself.
- the 720p issue is actually a bug that occurs with certain cable boxes, it was fixed with a firmware update. Since you can't update the firmware yourself, I just wouldn't worry about it, I'm sure your TV does just as good a job with 720p>1080p anyway.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 01-11-2012, 10:33 AM
tezster's Avatar
Quoted: 440 Post(s)
Liked: 310
As always, thanks for the info I certainly didn't expect a big difference, but was trying it out of curiosity more than anything else.
I think I've got the rest of the receiver settings dialed-in exactly how I want it. Reading (and re-reading) this, and the other 'official' Denon threads has helped *immensely*. Re-adjusting my subwoofer settings last night by lowering the gain on the subwoofer back to the 12 o'clock position used during calibration and increasing the LFE channel level instead has made a noticeable audible improvement in terms of smoothing out the bass response.
BTW, I think it was a smart idea consolidating all the Denon threads for the XX12 models, as many issues encountered are relevant between model types.
Old 01-11-2012, 09:02 PM
stir fry a lot's Avatar
I just added 2 rear speakers to my existing 5.1 setup but no sound is coming from them. Is there a setting in the AVR that I am overlooking?
stir fry a lot is offline
Old 01-11-2012, 09:06 PM - Thread Starter
batpig's Avatar
Liked: 3487
have you recalibrated successfully yet? if not, have you changed anything in the menus to let the receiver "know" you have 2 more speakers?
more details = easier for us to help... don't make me drag it out of you
Setup Guide and FAQ
batpig is offline
Old 01-11-2012, 09:13 PM
I haven't recalibrated it yet and haven't seen anything within the menus to activate the rears manually.
edit: Found the solution after going through the dictionary by changing it from Zone2 to normal. Thanks 'Pig. What is AFDM btw?
Old 01-12-2012, 03:23 AM
Jamma's Avatar
Thanks for reply.
But somehow I feel that the problem is actually with the AVR not recognizing the Xbox's DD 5.1 signal correctly...until I sort of refresh the setting on Xbox. Could this be some kind of HDMI handshake problem?
Jamma is offline
Old 01-12-2012, 03:25 AM
jdsmoothie's Avatar
Liked: 6047
Not likely, especially if that is the only source you're having this issue with. Do you have another AVR you can test with or perhaps take it over to a neighbor's house to test on his/her AVR.
Old 01-12-2012, 03:36 AM
Jamma's Avatar
OK. SO it seems that it is a common problem with Xbox...as you said. Just found another thread about it... HERE
Jamma is offline
Old 01-12-2012, 10:03 AM - Thread Starter
batpig's Avatar
Liked: 3487
you should re-run Audyssey ASAP so it calibrates the full 7.1 layout, but yes changing AMP ASSIGN was the correct solution as a first step
AFDM = Auto Flag Detect Mode
Audio tracks are encoded with a "flag" to alert the decoder that there are additional channels beyond 5.1. When the AFDM setting is ON, the receiver will only play the back surrounds when it detects the proper flag (e.g. EX for Dolby, ES for DTS) or if the track is native 7.1.
Most people turn this OFF and then engage PLIIx CINEMA to matrix any 5.1 signal into 7.1, regardless of the flag.
Setup Guide and FAQ
batpig is offline
Old 01-12-2012, 10:08 AM
Yeah, I was able to run Audyssey after the wife and kid fell asleep last night. I was just anxious to get some sound out of them. Thanks for all your hard work. You'll have a small donation to your Paypal account in a minute or two.
Old 01-14-2012, 08:59 AM
ninedulkar's Avatar
Hi,
I need some help from experts in this forum.
I've owned my AVR 790 for over 2 years now and it has been working fine so far. I have my DVR, Blu Ray player and Apple TV connected to the Denon. SO far all devices are working just fine.
Yesterday Denon just stopped Audio output to my 6.1 speakers. Video from all 3 sources comes out fine. Just the audio to the speakers. I went through all the menu settings and they look fine. However some odd things I cannot understand:
1) If I press STD on the back of the remote, the display says "Not available". Earlier this would show me various Dolby/DTS options.
2) Audio is hosed for all sources. Video works for all sources.
Any help debugging this problem will be appreciated.
Thanks very much!
ninedulkar is offline
Old 01-14-2012, 09:53 AM
jdsmoothie's Avatar
Liked: 6047
There is likely dust on the headphone jack so take a can of compressed air and blow into the jack a few times or take a headphone plug and insert/remove it a few times. This should restore your audio.
Old 01-15-2012, 11:02 AM
ninedulkar's Avatar
Thanks JD.
Turned out I was able to find the solution by Googling the symptoms. The problem was exactly what you said
I can't tell you how much this problem stumped me!
Old 01-15-2012, 12:28 PM
RobLee's Avatar
Quoted: 282 Post(s)
Liked: 285
Originally Posted by ninedulkar View Post
Turned out the problem was exactly what you said ... I can't tell you how much this problem stumped me!
You should read this thread more often, as that particular remedy comes up at least once a month!
Denon AVR-4520ci, Polk LsiM703's, 704c, Rti4 surrounds, some Klipsch subs. Bedroom: Lsi9's, Onkyo TX-8050
RobLee is offline
Old 01-22-2012, 12:07 PM
tezster's Avatar
Quoted: 440 Post(s)
Liked: 310
Question regarding the LPF for LFE setting under the Bass settings: if the crossover settings for my L/C/R are set to 80hz, and my surrounds are set to 100hz, does it still make sense to manually set the LPF for LFE setting to 120hz? Or will 100hz be ok?
FYI the setting after running Audyssey was 80hz (not sure if this is simply the unchanged factory default, or if it was in fact set by Audyssey calibration)
Old 01-22-2012, 02:44 PM
RobLee's Avatar
Quoted: 282 Post(s)
Liked: 285
Leave the LPF for LFE set at its maximum, 120Hz and verify that your speaker type is set to SMALL.
Also, Audyssey sets each speaker's crossovers at the lowest allowable for each speaker or pair. You may raise that but never lower it. For example, it typically sets my center channel to 40Hz and I raise it to 80.
RobLee is offline
Old 01-22-2012, 03:56 PM
jdsmoothie's Avatar
Liked: 6047
The LPF for LFE only affects the "LFE" channel (ie. the .1 in DD/DTS X.1) and the the lower frequency audio that is sent to the speakers. Although the factory default setting is 80hz, raise it to 120hz which is what the newer Denon AVRs all default to now.
Old 01-22-2012, 04:38 PM
tezster's Avatar
Quoted: 440 Post(s)
Liked: 310
Thanks for the quick response - I'll go ahead and raise the LPF. All other speaker settings I've already set as suggested
Old 01-27-2012, 03:04 PM
KingDaveRa's Avatar
Hi, I'm hoping somebody can help.
I've got a Pioneer DVD-696 DVD player running through my AVR-1910. It's set to upscale to 1080i. If I play some 16:9 DVDs through it, the picture on the TV (a Panasonic Viera) is often letterboxed, AND pillarboxed. I've fiddled around with the scaler settings, although as I understand they're only relevant to analogue inputs; this is all connected via HDMI.
I'm a bit confused as to why this is happening. If the DVD player is plugged direct to the TV I don't get this. My Bluray player (a panasonic) does the same thing. I'm guessing it is only certain aspect ratio DVDs that are causing it, but I don't see why the Denon is messing with the aspect when everything else just shows it full screen. Is there anything I can do to tell the receiver to just pass through the HDMI and not mess with it? My TiVO and XBMC box both run through it and run full 16:9 res, with no bars. I've reset to defaults but it's still the same. I've played around with settings but I can't figure it out.
Anybody else experienced this?
TIA
KingDaveRa is offline
Old 01-27-2012, 08:08 PM
jdsmoothie's Avatar
Liked: 6047
Although the i/p Scaler setting can apply to HDMI as well as analog inputs, in it's default setting it only applies to Analog; however, you can try setting it to OFF as well.
Old 01-28-2012, 03:32 PM
KingDaveRa's Avatar
This is what I did (just to check I'm doing the right thing):
  1. Press Menu
  2. Go to 5. Input Setup
  3. Go to 2. Video
  4. Press Right to go to DVD
  5. Go down to i/p Scaler
  6. Press right to select OFF
  7. Press Rtn, then Menu to exit
But... it seems some of the DVDs are 4:3 letterboxed (I hadn't noticed). I'll play around some more, and let you know.
Old 01-28-2012, 07:08 PM
I have a living room table where the 4th, 5th, and 6th Audyssesy positions are listed. Since they are not a listening position should I just run the first three and call it good?
Old 01-28-2012, 08:31 PM - Thread Starter
batpig's Avatar
Liked: 3487
always run the max number of positions when possible. It's not about measuring places where you literally will be sitting, the point is to feed the system as much data about the distribution of acoustic problems in your room as possible.
the spacing in the guide is approximate, just measure a cluster of points around the "sweet spot" and don't stress about exact spacing.
Setup Guide and FAQ
batpig is offline
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
