*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 312 - AVS Forum
post #9331 of 9350 Old 07-29-2014, 02:28 PM
jasguild's Avatar
What kind of UPS do I need?
After losing my HDMI board two times in my Denon, I am thinking about using a UPS instead of just a surge protector.
I will have on it my cable box, lcd tv, dvd player and my denon receiver. HOwever in researching UPS, I am reading about Pure Sine UPS versus simulated sine UPS and I am confused.
Do I need Pure Sine UPS for my intended use?
Sincerely
If you ain't a Gator, then you must be GATOR BAIT!!!!
jasguild is offline
post #9332 of 9350 Old 07-29-2014, 02:43 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 1110 Post(s)
Liked: 1525
Consider instead a whole house surge protector installed by an electrician on the outside of the house.
"JD" –
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Mon - Fri: 10am – 10pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Def Tech, Atlantic Tech, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #9333 of 9350 Old 07-29-2014, 03:43 PM
jasguild's Avatar
Apparently it does not address brown outs or other sources of surges such as through coax cables
jasguild is offline
post #9334 of 9350 Old 08-02-2014, 09:28 PM
thecoffeeguy's Avatar
Hello everyone.
Well, after a good solid 3+ years of running my 1910 receiver, I had a very odd thing start just in the past few days.
Real quick my setup: everything runs through my receiver (DVR, Blu-Ray...)
Now, for some odd reason, i started to hear this low muffled almost popping sound coming from my speakers (center channel, front left and right it seems.)
The really odd thing is, its very erratic. There are times it starts as soon as i turn on the TV or Blu-ray player. There are other times, it doesnt do it at all for a few hours. Or, im watching a movie, it starts out great, then there are short 'periods' where i hear the popping sound. At no point does the receiver ever shut off. Its very bizarre.
Any ideas?
My plan tomorrow is to take it down, unplug everything and give it a look over. The plan is to try and narrow down the issue.
Thanks for the help.
TCG
thecoffeeguy is offline
post #9335 of 9350 Old 08-03-2014, 07:07 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1525
You may want to try a microprocessor reset and run Audyssey again as well.
"JD" –
post #9336 of 9350 Old 08-03-2014, 12:08 PM
Thanks jdsmoothie.
I did try it (googled how), but so far, no luck.
Think i will try it again as well as pull out the receiver and give it a look over.
Trying to figure out what it could be, but i am drawing a blank here.
Receiver potentially dying perhaps?
TCG
post #9337 of 9350 Old 08-03-2014, 12:16 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1525
If you have more than just 3 speakers, try swapping them to see if the noise follows the speaker or the amp. Also, if you have lost the Owner's manual, you can download one from Denon's website ....
http://usa.denon.com/us/downloads/productdownloads
"JD" –
post #9338 of 9350 Old 08-04-2014, 05:28 PM
av-novice's Avatar
Originally Posted by thecoffeeguy View Post
Thanks jdsmoothie.
TCG
When new my -1910 had very loud pops and such. Finally fixed via Denon factory repair (think they replaced the HDMI board). If your problem turns out to be this, the cost of replacing that board would probably surpass getting a newer AVR.
AV-N
av-novice is offline
post #9339 of 9350 Old 08-14-2014, 03:53 PM
jertronic's Avatar
Just discovered a new music mode on my 1910 by using the buttons behind the secret door on back of remote.
While switching from tv to music I hit the "music" button when I usually just Listen in 5 channel stereo. It gave me the mode of Dolby PL2 Music or DTS NEO Music.
I'm not familiar with these formats but glad to discover new capabilities on the receiver after 4 years of usage.
Jertronic -Denon Convert...long time Yamaha-head
jertronic is offline
post #9340 of 9350 Old 09-06-2014, 03:16 PM
Liked: 0
avr1910 IR Repeater help
I have an AVR1910 which the ir sensor on the front panel speed working. So I bought an ir repeater to plug into the back as recommended by the manual and their customer service.
When I plugged the ir repeater in it didn't work, so I took it over to my 3910 elsewhere and had the same issue. It doesn't appear to be transmitting via the 1/8" to 1/8" cable to the Remote In on the back of the receiver. I tested via the provided ir output cable and it worked fine on the 3910, confirming the repeater works.
Any thoughts on why the 1/8:1/8 wouldn't work like it's supposed to? I've tried via stereo and mono cables, so that isn't it. Here's the repeater I'm using uniqueproductsonline.com/irresyhiirco.html
invictadiv3r is offline
post #9341 of 9350 Old 09-06-2014, 04:04 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1525
Some work ... others don't. Try a different brand.
"JD" –
post #9342 of 9350 Old 09-07-2014, 10:34 AM
Liked: 0
Any brand or models that you'd recommend for using with the Remote In input on the back?
post #9343 of 9350 Old 09-07-2014, 11:08 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1525
Sorry, but no. Just ensure whatever you try can be returned.
"JD" –
post #9344 of 9350 Old 09-14-2014, 07:21 AM
mrnyknicks's Avatar
Is there a way to have the input at the begining screen come on to SAT/CABLE?
I am having a hard time getting my Harmony Touch remote to switch the reciever to Sat/cable. Is there a way to make the INPUT SAT/CABLE on the opening screen? Once the receiver comes on it shows TV for the input. This question may be in the wrong section but I was hoping someone has had this problem before and can be of help.
My set up:
LG 55 LM7600
Denon-1910
sony s5100 blue ray
verizon cable box
All going thru the reciever
This is getting so frustating that i am considering buying a new reciever just because of this problem.
mrnyknicks is offline
post #9345 of 9350 Old 09-14-2014, 07:30 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1525
This is common on the XX11 and newer models with HDMI 1.4, however, should not occur with an HDMI 1.3 model like the 1910. Regardless, the solution is to turn HDMI-CEC (SimpLink) on the TV to OFF and if still no joy, ensure HDMI Control on the 1910 is set to OFF as well.
The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread
"JD" –
post #9346 of 9350 Old 09-14-2014, 07:50 AM
mrnyknicks's Avatar
Thanks jdsmoothie I will try that as soon as I get home
post #9347 of 9350 Old 09-14-2014, 08:16 AM
JChin's Avatar
Quoted: 87 Post(s)
Liked: 134
Hi mrnyknicks, one option is delete TV input if you're not using the TV smart feature and passing audio to Denon receiver.
Manual Setup -> Option Setup => Source Delete
JChin is offline
post #9348 of 9350 Old 09-14-2014, 08:34 AM
mrnyknicks's Avatar
So just so I am understanding you correct, there is an option to just delete the TV INPUT on the 1910?
post #9349 of 9350 Old 09-14-2014, 08:54 AM
JChin's Avatar
Quoted: 87 Post(s)
Liked: 134
Yep
JChin is offline
post #9350 of 9350 Old 09-14-2014, 08:56 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1525
You're not actually "deleting" it, rather simply "hiding" it so the AVR no longer sees it as a source.
"JD" –
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
Gear in this thread - Avr1910 by PriceGrabber.com
