*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 313 - AVS Forum
post #9361 of 9390 Old 10-22-2014, 09:26 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2604 Post(s)
Liked: 1894
Correct. Both devices must feature HDMI(ARC) in order for it to work. Also note that a TV is not going to pass HD audio using HDMI (ARC). In fact many TVs can only pass PCM 2.0 over HDMI(ARC) which is why in those cases the optical output is the better option as it can also pass DD 5.1 in addition to the PCM 2.0.
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and dealer for AVRs and Speakers
Daily 8am – 8pm EST
Call for info on Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #9362 of 9390 Old 10-29-2014, 08:45 PM
frankmar's Avatar
I had to do a reset of my AVR and redid the ODYSEE set up
When I listen to tuner I have it at -30 but when I switch it to MPV( tv ) I have to put it at -13
Before the reset I had my AVR volume at -26 and the volume was good for Tuner, tv and PS3
last time I did the odysee was 4 years ago. I did the 6 positions microphone as stipulated. Can some one tell where I went wrong. tia
PRESENTLY:    TCP55VT60               PREVIOUSLY:    TH46PZ80
PS3 80G
IR 2 BT RE-BL
DENON AVR1910
FIBETV MOTOROLA VIP-1232
PARADIGM MONITOR 7 v6 front speakers
KLIPSCH SUBWOOFER KSW10
kLIPSCH SATELITE SS-1
kLIPSCH CENTER SC-1
HARMONY ONE
frankmar is offline
post #9363 of 9390 Old 10-29-2014, 09:00 PM
JChin's Avatar
Quoted: 125 Post(s)
Liked: 140
Hi frankmar, maybe you selected "no" to Dynamic Volume at end of setup. Try changing Dynamic Volume to Evening and set Reference Level Offset to 10dB.
JChin is offline
post #9364 of 9390 Old 10-30-2014, 02:47 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Although running Audyssey will set the level of each of your speakers/sub in relation to each other, it's possible there can be a difference in volume between sources. First check to see if Dynamic Volume is ON for all sources as JChin suggests, otherwise, you may have also used the Source Level setting in the past to adjust the difference in volume between sources.
Daily 8am – 8pm EST
post #9365 of 9390 Old 10-30-2014, 07:05 AM
frankmar's Avatar
yes my dynamic volume was off, put as suggested, -26 is good for tv, but a little loud for tuner,
I forgot there is a dynamic volume for each of the input, I had it on for tuner but not for PVR.
Also the Source level can be ajdusted
Also, some times since this reset I get a video but sound from tv then shut the avr off and then on and its ok
tia
PS3 80G
IR 2 BT RE-BL
DENON AVR1910
kLIPSCH CENTER SC-1
HARMONY ONE
frankmar is offline
post #9366 of 9390 Old 11-11-2014, 03:03 PM
jbrady3324's Avatar
Headphone Amp
My set up is as follows:
PS4/Wii/Comcast (hdmi) -> Denon AVR1910 (hdmi) -> Speakers
http://content.abt.com/documents/223...910_manual.pdf
Headphones: Denon 770 600 ohm and Grado SR325i
Amp: Little Dot Mkiii
I want to achieve a set up where i can hook up a headphone amp to the Denon AVR that allows me to bypass the headphone out jack. At the same time, I want it to be be as simple as possible so I don't have to disconnect/reconnect anything when I want to use my speakers. The last requirement, if possible, is to have surround sound output to the headphones like the headphone out jack provides
Or is it possible to buy a switch to put between the sources and the receiver?
John
Pioneer KRP-500m
Panasonic 65VT50
M&K LCR-750s Fronts and Center
M&K M-4T Surrounds
X-Rite i1pro
jbrady3324 is offline
post #9367 of 9390 Old 11-11-2014, 06:06 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Connect the MKIII to the Zone 2 pre-outs and you'll be able to pass any audio connected with analog cables to the AVR, otherwise no can do on HDMI or digital sources as there are no main zone pre-outs on this model.
Daily 8am – 8pm EST
post #9368 of 9390 Old 11-11-2014, 07:59 PM
jbrady3324's Avatar
I had a feeling that would be the case. I am thinking my best option would be to get a separate dac (i.e Astro mixamp) and connect it to the optical/usb source of the PS4/Wii as needed.
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #9369 of 9390 Old 11-14-2014, 07:38 AM
jbrady3324's Avatar
Does this amp support Dolby Headphone? If yes, does it only work with Dolby Digital in or does it work with other input signals like DTS and LPCM?
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #9370 of 9390 Old 11-14-2014, 09:28 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
No, that was dropped on Denon AVRs about 5 years ago and then only on the upper level models.
Daily 8am – 8pm EST
post #9371 of 9390 Old 11-14-2014, 09:34 AM
jbrady3324's Avatar
Thanks. Does it do any kind of surround processing for headphones?
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #9372 of 9390 Old 11-14-2014, 09:41 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
It has a specialised Denon DSP - VIRTUAL mode that is supposed to provide a surround sound effect, but not certain how much of a difference you would notice.
Daily 8am – 8pm EST
post #9373 of 9390 Old 11-17-2014, 08:02 PM
jbrady3324's Avatar
I have been playing with the avr today and notice a few more modes when headphones are plugged in:
Virtual
Direct
5CH Stereo
Are these all surround modes as well?
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #9374 of 9390 Old 11-18-2014, 06:34 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Yes.
Daily 8am – 8pm EST
post #9375 of 9390 Old 11-18-2014, 07:14 AM
jbrady3324's Avatar
Yes.
Is there any information about these modes? I can't find anything in the manual
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #9376 of 9390 Old 11-18-2014, 08:07 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Simply use the one you prefer.
Daily 8am – 8pm EST
post #9377 of 9390 Old 11-29-2014, 05:38 AM
Soulburner's Avatar
Quoted: 143 Post(s)
Long time user of the 1910 here. This has been a very solid piece of equipment for me in the 5 years I've owned it.
Looking at current offerings, I see the S700W is $299 recertified. That's a great deal if you were looking to get something with more modern features. The question is, would you make the change?
Soulburner is online now
post #9378 of 9390 Old 11-29-2014, 09:45 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Audio quality should be the same, so change if you want more features. Upgrade to the X1100 or X2100 for the better Audyssey MultEQ XT.
Soulburner likes this.
Daily 8am – 8pm EST
post #9379 of 9390 Old 12-18-2014, 12:03 PM
srinath.the.man's Avatar
radio search and presets
How to search radio stations and manually set them.
I have a few channels that are iffy but I still like to listen even if there is a bit of static.
How to lock onto those.
Srinath.
srinath.the.man is offline
post #9380 of 9390 Old 12-18-2014, 12:32 PM
Liked: 0
With reference to the postby BubbaT55 about driving headphones as well as speakers (not enough posts to quote apparently).
A solution that I am using is an Atlona AT-HD-M2C audio converter which can accept most multichannel audio formats via HDMI and emit a stereo downmix to line-level analogue output. I listen to the 5.1 speaker system and my wife listens on Senheisser cordless headphones.
The only downside is that, although the AT-HD-M2C has a HDMI out, the sound on this is stereo only so you can't just put it into an HDMI chain between the source and the receiver. I have to use a HDMI splitter with one output going to the 1910 and the other to the Atlona. The splitter is a bit flaky, you have to turn everything on in just the right order for it to work. Atlona do sell a much better (and much more expensive ) splitter, the AT-HDDA-2, which I'm sure will work just fine.
While this works fine, the need for all the extra boxes, HDMI cables and PSUs irritates me a bit so I am going to try replacing the splitter, audio converter and headphones with a pair of Sony MDR-HW700DS surround headphones, which if the manual is to be believed can be put in the chain between source and receiver.
quartermain is offline
post #9381 of 9390 Old 12-18-2014, 01:34 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Srinath.
Have the AM/FM antennas connected to the AVR and refer to TUNER instructions .. pp. 39-40.
Daily 8am – 8pm EST
post #9382 of 9390 Old 12-18-2014, 08:21 PM
No manual but I'll try to find one
I dont have a manual, but I'll locate one.
I managed to get all the stations into the thing by spreading the antenna across the room and hitting search, so - just not in the prefered order for my liking. Pretty much OK though, I can recognize them by ear.
Cool.
Srinath.
post #9383 of 9390 Old 12-19-2014, 02:26 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Manuals are available for download at ....
http://usa.denon.com/us/downloads/manuals-and-downloads
Daily 8am – 8pm EST
post #9384 of 9390 Old 12-19-2014, 07:55 AM
Link isn't working
That link hasn't worked for me.
Srinath.
post #9385 of 9390 Old 12-19-2014, 08:02 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Works for me. Just copy and paste the URL into your browser search window or simply google Denon Downloads.
Daily 8am – 8pm EST
post #9386 of 9390 Old 01-06-2015, 03:18 PM
new2790's Avatar
790 with video that cuts out
I haven't posted here in several years because my 790 had been working flawlessly (or so I thought) until recently. I moved and after reconnecting my 790 to the same Samsung BDP 3600, it looks like I have an issue very similar to what GOVOLS posted on #8530 , 5/22/2011 (with updates on #8550 and #8626 ). Before I go out and either send in my receiver for a repair or buy a new one, I wanted to double check with the folks on this thread to see if there's something I've missed.
"Use Cases I've tried"
I have new speakers, but I don't think these are the issue.
The issue persists even after trying new HDMI cables, different HDMI input ports and a different BluRay player.
When either the Apple TV or BluRay Player are connected directly to the TV, the issue goes away.
Set-up
The receiver is connected to a Samsung UN55HU6950 via HDMI.
The rest of the input devices are connected via HDMI or Component:
HDMI connected devices:
1. Apple TV: Video will cut out every now and then when watching any content.
2. Samsung BDP 3600: Video cuts out every two seconds or so.
Component connected device:
1. Xfinity cable box: I've only seen the video cut out once or twice while watching TV over the past few months.
Thanks for everyone's input. Apologies if this is something simple that I have overlooked.
new2790 is offline
post #9387 of 9390 Old Today, 01:22 PM
Selvos's Avatar
Hi Good to see the forum still going strong.
Anyways, astonishly I have never used the headphone jack on my avr...until recently.
However, the sound out of the headphones are crackly, like the headphones can't handle the sound coming through.
This happens on certain frequencies. The headphones are high quality, over ear. They are wired.
Any solutions to this? Am I missing a setting?
Selvos is offline
post #9388 of 9390 Old Today, 01:26 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1894
Some of the XX10 models had defective headphone jacks. You could try resetting the microprocessor (p. 64 Owner's manual), but doing so will reset all settings back to factory defaults and wipe out Audyssey as well.
Daily 8am – 8pm EST
post #9389 of 9390 Old Today, 01:28 PM
Selvos's Avatar
Wow, thanks for the quick reply.
I guess I'll try doing that. I do need to recalibrate audyssey anyway.
Selvos is offline
post #9390 of 9390 Old Today, 09:26 PM
new2790's Avatar
Update: problem solved
Quick Update: Problem seems to have solved, after I triple-checked the existing HDMI cable the previous owner of our home installed in the wall. It's bad and was replaced.
Set-up
new2790 is offline
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
Gear in this thread - Avr1910 by PriceGrabber.com
