*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 314 - AVS | Home Theater Discussions And Reviews
post #9391 of 9403 Old 02-12-2015, 06:57 PM
mrnyknicks's Avatar
Thank you
You're not actually "deleting" it, rather simply "hiding" it so the AVR no longer sees it as a source.
Thanks! You saved me from buying a new receiver. Now I can work on my projector
mrnyknicks is offline
post #9392 of 9403 Old 02-13-2015, 05:49 PM
calbearfan's Avatar
Haven't made any changes to my setup for several months, but I just started getting the flashing red power button, fuse-popping signal of death... Is that the end of the line for the receiver?
calbearfan is offline
post #9393 of 9403 Old 02-13-2015, 06:26 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 114
Check all your wiring. Mine did that when I had wires touching.
Soulburner is offline
post #9394 of 9403 Old 02-14-2015, 01:09 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3712 Post(s)
Liked: 2181
A flashing power light indicates a problem which may or may not be easily resolved. Please review the following post ....
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #9395 of 9403 Old 02-22-2015, 12:17 PM
rn865's Avatar
Quoted: 13 Post(s)
What type of DACs are used in the Denon 790?
Are newer DACs appreciably better?
rn865 is offline
post #9396 of 9403 Old 02-23-2015, 06:21 AM
av-novice's Avatar
Most Denon AVRs at that time used the Analog Devices ADAU1328 DAC. Yes, there are some better DACs available, but too many factors influence how they sound to predict performance of one over another.
AVN
av-novice is offline
post #9397 of 9403 Old 02-23-2015, 06:47 AM
rn865's Avatar
Quoted: 13 Post(s)
AVN
rn865 is offline
post #9398 of 9403 Old 02-23-2015, 10:42 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 114
Then there's the double blind testing that has shown people can't tell the difference between DACs.
post #9399 of 9403 Old 02-23-2015, 05:33 PM
av-novice's Avatar
Using high bit rate digital (96k or 192k at 24 bit) might separate some of the men from the boys, but with CD or generic digital just about any DAC can do the job. Speakers are the weak link in just about any audio system.
AVN
post #9400 of 9403 Old 03-16-2015, 08:03 AM
brandt35's Avatar
xbox one and 1910
Just picked up an Xbox one and I have a 1910. Xbox connected to 1910 via hdmi. When I select "multi in" the only audio seems to be coming from my subwoofer and is very poor. If I switch to something like 5 channel surround or game mode the audio will work.
I would like to use the multi in setting as I am sure that would be the best. Can anyone tell me how to get this to work, or what settings may produce optimal audio from the Xbox one?
I am not currently with the system, but I remember in the audio settings of the Xbox one it was set to 5 channel surround. I do know there was a bit stream option but I am not sure what that is.
Thank you
brandt35 is offline
post #9401 of 9403 Old 03-16-2015, 08:08 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
On the Xbox try the "bitstream" option and set Secondary Audio to OFF.
post #9402 of 9403 Old Today, 05:27 AM
Liked: 0
Denon 1910 no sound via TV
I have to do some decorating, and speakers need to come down.
I was hoping to be able to push all my sounds through the TV instead of the speakers, however this doesn't appear to work. I have set the amp from AMP to TV, but no sound (I continue to get sound through the speakers though).
I know it can pass sound to the TV, when I turn the amp onto standby is passes the sound directly to the TV which works fine.
Anyone any ideas?
TIA
Matt Buckey is online now
post #9403 of 9403 Old Today, 05:31 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
That setting only works with HDMI sources. If that is what you are trying to pass, try cycling the setting a few times and if still no joy, try unplugging the power cord for 10 minutes and try again.
For more helpful information, there is a dedicated Denon 1910 Owner's thread .....
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
Gear in this thread - Avr1910 by PriceGrabber.com
