*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 316 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #9451 of 9463 Old 05-03-2016, 05:55 AM
frankmar's Avatar
Quoted: 52 Post(s)
I think I may have found the problem.
Bell Fibe control would open only PVR and TV and I had to open the AVR.(I can only enter the TV code)
So this morning I opened AVR first, then PVR and TV and seem the sound to be stable.
Now I have find a way to program the slim control to open AVR, PVR and TV
Also noticed volume works only with AVR, PVR control not working. any idea. thanks
PRESENTLY:    TCP55VT60               PS3 SLIMIR 2 BT RE-BL DENON X2200W [B] FIBETV
MOTOROLA PVR VIP-2262
PARADIGM MONITOR 7 v6 front speakersKLIPSCH SUBWOOFER
KSW10
kLIPSCH SATELITE SS-1kLIPSCH CENTER SC-1HARMONY ONE
frankmar is offline
post #9452 of 9463 Old 07-17-2016, 08:58 AM
FlyinMN's Avatar
Unhappy My 1910 may be toast.
Hi All,
I thought I'd ask here before I buy a new receiver.
I've had excellent performance from my 1910 for just over 6 years but this morning it was completely silent. Worked fine last night but no sound at all from any input.
Video is passing through just fine in all inputs but no sound. The other strange behavior is that the panel shows it's reading the proper signal but only displaying "Stereo" for output. If I try to select the a multichannel mode, it says "not available". Also, the speaker selections to not display and nothing happens if I try to switch the A/B selector.
I've powered off and even did a full factory reset but still the same result. It seems as if something has fried inside. I still here he "click" when turning off and on each zone but no sound. Finally, the second zone doesn't work either and it did last night.
Any ideas? If not, I'll be looking for a replacement Denon as I really like this receiver.
FlyinMN is offline
post #9453 of 9463 Old 07-17-2016, 09:30 AM
ela-tsiki-tsiki's Avatar
Disregard my post... You did a reset.. Didn't read right the first time.
Why don't you try reseting it?
Sometimes you get surprised by the glitches electronics face out of nowhere.
Sent from my A0001 using Tapatalk
ela-tsiki-tsiki is online now
post #9454 of 9463 Old 07-17-2016, 09:33 AM
FlyinMN's Avatar
Hi, I did a factory reset per the owners manual by hitting the power on button plus the surround mode buttons at the same time. This set everything back to the original settings but still no joy. Is there another reset method?
thanks
FlyinMN is offline
post #9455 of 9463 Old 07-17-2016, 11:37 AM
bearcatscott's Avatar
No sound fix
Originally Posted by FlyinMN View Post
Hi All,
This has happened to me a couple of times. Dust will get into the headphones jack on the front of the unit. This causes the unit to think that headphones are plugged into the jack. Blow into the jack input or used canned air to blow into the jack input to get the dust out. This has worked for me.
bearcatscott is offline
post #9456 of 9463 Old 07-17-2016, 12:06 PM
FlyinMN's Avatar
THANK YOU!! That worked! Crazy blowing into the jack can turn the headphone on and off. Must be some sensitive switch it there.
Thanks, great save. Gotta love this forum!
FlyinMN is offline
post #9457 of 9463 Old 07-17-2016, 12:16 PM
Glad it worked!
post #9458 of 9463 Old 07-17-2016, 12:37 PM
billrininger's Avatar
I stuck a piece of black electrical tape over mine after having the same problem a couple of times. I can't see it from across the room and it hasn't been a problem since.
billrininger is offline
post #9459 of 9463 Old 07-18-2016, 06:04 AM
DaMutha1's Avatar
LOL, I just logged in for the first time in a long time to say the same thing. Glad you got it sorted.
DaMutha1 is offline
post #9460 of 9463 Old 07-18-2016, 06:46 AM
av-novice's Avatar
Concerning lost audio, if you are really adventurous AND never use the headphone output, you can remove the cover of the receiver and disconnect the wires from the headphone jack.
AVN
av-novice is offline
post #9461 of 9463 Old 08-10-2016, 08:03 AM
Liked: 0
Hello,
I'm having an issue with my Denon AVR-1910.
I only have connected my laptop via hdmi with the receiver.
When i am playing music (or other sound from youtube etc.) from my pc, it sounds good with decent amount of volume (about -30 dB is enough), but when a next song comes up, you can't hear the audio anymore.
Then you have to switch the volume up to max (+18 dB) and then you can hear it again. If i switch the dynamic volume off or tweak with some settings, while the the audio isn't loud, it will (sometimes) get loud again.
I have tried several possible solutions:
-switching hdmi inputs
-running audyssey again
-turning the dynamic volume setting to 'evening' and making the ref level to +10 dB.
-turning dynamic volume and/or dynamic eq off
i do not know what i have to do know, so maybe one of you can help me?
Zazakra is offline
post #9462 of 9463 Old 08-10-2016, 09:03 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 9739 Post(s)
Liked: 4521
Originally Posted by Zazakra View Post
Hello,
Refer to p. 64 in the Owner's manual and reset the micoprocessor back to factory default settings.
Zazakra likes this.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #9463 of 9463 Old 08-10-2016, 10:41 AM
Liked: 0
I have done this before when i was redoing the auto setup with the setup mic.
I have noticed that it only happens when the volume of my laptop drops to zero, because when i play another sound track in the background, the sound level does not drop.
Also, when the sound level is dropped, the speakers rustle a bit.
Zazakra is offline
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
