*OFFICIAL* Denon AVR 1610/590 owner's thread - Page 176 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #5251 of 5254 Old 02-19-2017, 06:18 AM
oldnavycdr's Avatar
590 with UHD TV?
I have a AVR-590 and will soon upgrade to a 4K TV. While I will like upgrade the Denon to one of the newer models designed for 4K functionality I want to know how to connect the 590 to a 4K TV. Will the 1.3a HDMI's on the 590 function with the newer 2.0 HDMI on say a Samsung UHD set or will I need to go optical for the sound?
oldnavycdr is offline
post #5252 of 5254 Old 02-19-2017, 07:04 AM
jdsmoothie's Avatar
Quoted: 15365 Post(s)
Liked: 7512
The 590 is not ARC capable, so yes, you'll have to connect the TV's optical audio output ---> 590 if you want to pass the TV's smart app audio to the 590. Also, you'll need to connect a dual 4k BDP with one HDMI (video) --> TV and the other HDMI (audio) --> 590.
jdsmoothie is online now
post #5253 of 5254 Old 02-19-2017, 07:27 AM
oldnavycdr's Avatar
Thanks, JD. In the interim (not using any 4K sources) would I still have to set up the optical as a bypass for the ARC?
post #5254 of 5254 Old 02-19-2017, 07:41 AM
jdsmoothie's Avatar
Liked: 7512
HDMI(ARC) = Audio Return Channel
This feature only refers to passing the smart app audio from the TV ---> AVR; however, both the TV and the AVR must be ARC capable for the feature to work. As your AVR is not ARC capable, your only option is to use TV (optical) --> AVR unless of course you don't want to pass any audio from the TV back to the AVR.
Denon Avr1610 5 1 Channel Home Theater Receiver With 1080p Hdmi Connectivity , Denon Avr590 5 1 Channel Home Theater Receiver
