onkyo HT-R530 "B" speaker output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-16-2009, 05:39 PM - Thread Starter
tacoma7583's Avatar
After reading throught the manual. I couldn't find the answer to this. it says when you use the front B speakers it turns off the surrounds. What is the total output wattage or specs for the B fronts?
tacoma7583 is offline
post #2 of 2 Old 02-06-2014, 11:20 PM
hublez's Avatar
When the "B" speakers are on, it only turns off the back surrounds. and i believe that it puts out the same amount of power that all the other ports do! smile.gif
hublez is offline
