Pioneer SC-05 too tall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-25-2009, 06:49 PM - Thread Starter
Tech Marmot's Avatar
Hey all I'm having trouble finding a Entertainment unit I like that has shelves that will fit that massive SC-05. The trouble is the feet bring up the height about half an inch or more, and for a couple of them all I need is 1/4 more clearance. Anyone know if there are thinner feet that are nice you can change out for receivers ???? Thanks.
Tech Marmot is offline
post #2 of 2 Old 06-25-2009, 08:14 PM
RoboRay's Avatar
You may want to check the SC-05's manual and see how much space you need above the unit. Most receiver manufacturers recommend 4-8" of breathing room on top for passive cooling.
In general, cramming a receiver into a space barely big enough to hold it is a very bad idea.
RoboRay is offline
