*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 02-18-2010, 03:12 PM - Thread Starter
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
what do you mean by "output over HDMI" -- do you mean decoding and then sending OUT multich PCM audio to another device? then the answer is no.
Both can of course decode and PLAY and type of audio. But they can't send decoded audio out via the HDMI -- if the HDMI audio is set to TV it will simply pass the audio through to the sink (e.g. display).
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 02-18-2010, 03:25 PM
hexcode99's Avatar
Quoted: 45 Post(s)
Yeah, that is kind of what I mean. Just decode the bitstream input and send it as LPCM v.i HDMI output. If it already decodes the already, seems like it shouldn't be asking too much for it to send out over HDMI output.
hexcode99 is offline
Old 02-18-2010, 03:26 PM - Thread Starter
batpig's Avatar
Liked: 3420
seems like it, but that's not what AVR's do you will not find any receiver that can do what you want, the point is to decode the audio and then PLAY IT, not send it to another device for more processing. I would imagine it could only be done with a fancy (expensive) professional surround decoder/processor.
if you get an AVR with pre-outs then of course you can take out the decoded signal as analog multichannel.
you have some strange requirements and don't seem to want to explain what exactly you are trying to do....
Setup Guide and FAQ
batpig is offline
Old 02-18-2010, 05:09 PM
Kenj1's Avatar
I just tried to play a Blu-ray disk that was supposedly recorded in dolby digital and only very faint sound would come out. I have an LG BD390 Blu-ray player with audio set to primary pass thru. If I set the blue-ray player to PCM, the sound is fine. I know there have been problems of compatibility issues with the 2310 model and LG players, but I've listened to other disks in dolby digital, and DTS-master audio before without any problems. Do you think this is just a bad disk or is there a bigger problem? FYI, the serial number starts with 912 (year month), and according to Denon, the compatibiltiy issues were supposed to be corrected by them.
Kenj1 is offline
Old 02-18-2010, 05:14 PM - Thread Starter
batpig's Avatar
Liked: 3420
well, the way to confirm is to try another movie that has a confirmed TrueHD or DTS-MASTER track, and make sure you get the "blue light" indicated bitstream HD audio. do you hear normal sound? then it is probably just that one disc. But you need to do some more tests to establish whether this is an isolated problem or not.
Setup Guide and FAQ
batpig is offline
Old 02-18-2010, 05:21 PM
Kenj1's Avatar
I have a disk in now that says DTS HD 5.1 master lossless and that works with the blue light on.
Kenj1 is offline
Old 02-18-2010, 06:09 PM
Kenj1's Avatar
Just tried several TruHD movies and DTS-HD master and all is working. Still, is a little concerning given the past issues.
Kenj1 is offline
Old 02-18-2010, 08:33 PM
EJ
EJ's Avatar
After about 18 months of turning my back on Denon to get lossless audio on the cheap with a brand I will not mention, I'm glad to be back with Denon.
Former USSB uplink operator.
EJ is offline
Old 02-18-2010, 08:53 PM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Originally Posted by the_abbot View Post
My 2310 is having a sporadic problem. While watching a BD on my PS3(at a random point in the movie), the movie audio drops out and I start hearing thumps and pops through the sub/speakers (almost sounds like a record player being bumped), then a snap, and the receiver goes into safe mode (blinking every .5 sec). I've checked the speaker wiring, and everything seems fine. This problem never occurs while watching cable/dvr. So I assume it's related to the ps3. (The ps3 is connected via hdmi). The ps3 is set to bitstreaming, and is connected directly to the avr.
Any advice?
Now I'm getting static coming through the speakers every now and then. What in the heck can be going on? A bad unit maybe?
Current setup: JVC RS55 - Marantz 7008 - Dune Solo 4K - Kodi/Chromebox - Cinema 10's LCR - Volt 10 Surrounds - Polk in wall rear & ceiling - eD A7-450
the_abbot is offline
Old 02-18-2010, 09:11 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi the_abbot, I don't have a clue but try to isolate the problem by using a different HDMI cable first on the PS3.
JChin is offline
Old 02-18-2010, 09:15 PM
thatwilsonguy's Avatar
Demo the C/L/R 2002 while you're at BB to compare it to the Pro Cinema 1000. It's considerably larger to be sure, but for movies/TV there's no comparison to the quality difference between the two.
I'm actually going to see if the BP1XBLA is going to be too much surround sound for me. I already have some older BP2004 floor standers I'm trying to compliment. I'm also having a problem deciding if I really wan't to go 7.1. I hear a lot against it and a lot for it.
thatwilsonguy is offline
Old 02-19-2010, 01:48 AM
EJ
EJ's Avatar
Is there something like a chart that shows what features ae enabled on the ancho ay chip in various equipment? Is it a closely guarded secret for some reason?
EJ is offline
Old 02-19-2010, 02:22 AM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
EJ-This guys thread might help you.
http://www.avsforum.com/avs-vb/showthread.php?t=1173185
Or these links might help you but they can be confusing/misleading (like no PReP on denon 2310)
http://www.anchorbaytech.com/vrs_tec...turing_vrs.php
http://www.anchorbaytech.com/products/semiconductors/
mphfrom77 is offline
Old 02-19-2010, 01:54 PM
EJ
EJ's Avatar
thank you.
EJ is offline
Old 02-19-2010, 02:03 PM
jdsmoothie's Avatar
Quoted: 12181 Post(s)
Liked: 5549
We do know at a minimum the following are NOT implemented: PreP, edge enhancement, detail enhancement, mosquito noise reduction
jdsmoothie is offline
Old 02-19-2010, 02:27 PM
bxconst's Avatar
Originally Posted by crbaldwin View Post
Yes, I submitted a support request/complaint about this but we need everyone to act like it's a big deal or they won't fix it. I told them you're one of the biggest Denon supporters on Avsforum and this problem is really getting under your skin (well, not really but I thought about saying that) .
The Denon CSR I talked with still looked interested in fixing this issue. So I have to give him credit where credit is due . Since I was able to reproduce the issue using PVR'd content, he is going to load a 8300 with different content and ship it to Japan. So, keep your fingers crossed, maybe this time we will have better luck ...
bxconst is offline
Old 02-19-2010, 04:07 PM
Plex's Avatar
Does anyone have a example of the GUi between the models?
Audyssey setup guide
Plex is offline
Old 02-19-2010, 04:16 PM
jdsmoothie's Avatar
Liked: 5549
If you use the Search This Thread button, the GUI display has been posted a few times in each of the threads.
Old 02-19-2010, 04:51 PM - Thread Starter
batpig's Avatar
Liked: 3420
here is a youtube video of the "basic" GUI on the 2310/3310 models:
http://www.youtube.com/watch?v=nnoANxXLOgQ
and here is a video review of the 4310 model which shows the "advanced" GUI on the 4310/4810 (although beware the reviewer is BRUTAL you may want to mute it ):
http://www.youtube.com/watch?v=qbfXI...rom=PL&index=8
Setup Guide and FAQ
batpig is offline
Old 02-19-2010, 09:47 PM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
I have never purchased form Electronics Expo http://www.electronics-expo.com/, but I can't stop using them to compare prices. Code "receiversale" is something that always seems to work for a price reduction. But you must click through all the way to the Amazon checkout review page to see the fully discounted, shipped price. The code seems to work on a lot of items. Today the Denon 2310 came out to $580.19, which is the lowest I've seen since watching it the past month or so. Just thought I'd post that here.
Old 02-20-2010, 06:32 AM
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
That sounds promising. Please let us know if you hear anything. Thanks.
crbaldwin is offline
Old 02-20-2010, 04:49 PM
gary_i_w's Avatar
Now I know the problem must be me but I am having difficulty with my zone 2. I can get output in zone 2 only when the source is set to tuner. When I select any other source - nada, zippo - despite the fact that those sources are working fine in the main zone. Any ideas?
Setup:
denon: 2310
samsung: series 8
samsung: bluray
cable/sat: comcast woth a motorola box
gary_i_w is offline
Old 02-20-2010, 05:40 PM
jdsmoothie's Avatar
Liked: 5549
Sure ... Only analog audio can be sent to Zone2 (eg TUNER). In order to send your other sources there, you'll have to connect an RCA cable to the AVR as well as the HDMI cable.
Old 02-21-2010, 02:02 PM
Welshdog's Avatar
Originally Posted by batpig View Post
yes EJ, as matbl says it will allow it, however there are some intricacies to getting it to work perfectly. the most important thing will be getting a transport that can output DVD's in raw 480i digital (over HDMI) format. unless you have a player that can do "source direct" output (e.g. 480i for SD DVD, 1080p/24 for Blu-ray) over HDMI, you aren't going to get the full benefit of the ABT chip in the 2310.
many players cannot output 480i over HDMI, and will first do a deinterlacing step (480i > 480p) before outputting, which basically defeats most of the benefit of the ABT scaler.
If your primary concern is DVD upscaling, and you don't really need all the other features of the 2310, you may get better "bang for your buck" with a lower-priced AVR (e.g. the 1610 or 1910 model) and spending the difference on a nice BDP with top-notch scaling like the Oppo BDP-80.
I'm not super clear on this. I have a 2310 and want to get a BDP-80. My understanding is that the BDP-80 does not have the ABT chip and the 2310 does. This seems like a perfect match - why duplicate functions? The chip is only needed in one device. Am I right about this? Plus "Source Direct" mode would output the native video from the BDP allowing the ABT to do the processing with the best possible source material.
Also, all DVDs are 480i on the disc natively? Is this always the case? I thought it was possible to have 23.98 video on the disc.
"Nobody looks good in high-def"
Doug Wilson - Weeds
Welshdog is offline
Old 02-21-2010, 05:06 PM
Kenj1's Avatar
Do you have to manually assign the inputs?. I have a DVR, and a Blu-ray player and I have an HDMI cable for both of these as well a third HDMI cable for the TV Monitor. Everything seems to be working fine.
Kenj1 is offline
ryrbb's Avatar
The good news is that I have removed those Bose speakers I've had for 7 years and UPGRADED to a Denon 2310 reciever and DT speakers. The tv I have is a Sony kv-34XBR910 Trinitron which has a DVI, RCA & component connections. I want to connect DirecTV HD and PS3. I have gone through the setup and I know the speakers work because I can play the radio.
I have tried to connect the Denon via HDMI to DVI as well as through RCA cables but neither gives video or audio. I apologize for being a knucklehead but is there something I am missing.
ryrbb
Front LR- ProMonitor 1000
Center - ProCenter 1000
Surround - ProMonitor 800
Sub - Energy
Receiver - Denon 2310
ryrbb is offline
Old 02-21-2010, 05:29 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Kenj1, its more plug-n-play so your are good to go.
JChin is offline
Old 02-21-2010, 05:36 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
ryrbb
HDMI-DVI combinations does not sit to well with Denon. Do a search "DVI" and you will find post with this issue. Have you try the other HDMI jacks?
JChin is offline
Old 02-21-2010, 05:56 PM
Kenj1's Avatar
Thank you
Kenj1 is offline
Old 02-22-2010, 06:12 AM
jdsmoothie's Avatar
Liked: 5549
AFAIK, the ABT 2010 chip in the BDP-83 is fully implemented whereas in the Denon 2310 it's only 1/2 implemented, to include not having PReP implemented (which is why a 480i input signal to the 2310 vice upscaled 480p provides the best picture quality improvement). The full implementation in the BDP-83 allows it to provide additional picture adjustment features the ABT 2010 is capable of providing, although the basic deinterlacing and upscaling in both the BDP-83 and Denon 2310 are likely to be the same. If you're not interested in the additional fine tuning picture adjustment features offered by the BDP-83, then you should be good to go with just setting the BDP-80 to "source direct" mode and letting the Denon 2310 do the deinterlacing and upscaling.
