*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
Old 03-17-2010, 05:26 AM
jdsmoothie's Avatar
Quoted: 12322 Post(s)
Liked: 5623
gosparky -
1. This could be related to the HDMI-CEC setting (Samsung - Anynet+, Panasonic - Viera Link, Sony - Bravia Link, etc.) on the TV. If it's ON, try turning it OFF. The other possibility is that there is a known problem in that the GUI/volume overlay disappears when there is a resolution change from 1080i to 720p going from one channel to another.
2. This is common and merely the result of the HDMI handshake that occurs when HDMI components are turned ON and OFF.
jdsmoothie is online now
Old 03-17-2010, 07:08 AM
gary_i_w's Avatar
Before I purchased my 2310, I asked Denon customer service the same question: starting at what serial number is the firmware already updated to 69? Their reply: On the AVR-2310CI anything after the serial # ending in -16237 and on the AVR-890, anything after -01007.
gary_i_w is offline
Old 03-17-2010, 08:29 AM
jdsmoothie's Avatar
Liked: 5623
Originally Posted by blushadows View Post
Strangely, the first 6 digits of the serials on both were the same. That was why I was surprised to find this one had the newer firmware version. I figured the serial was somewhat like other products where the first part is the Mfg. date/Batch # with the last digits being the unique SID. To answer the question though, both were 911331. Hope this helps.
Based on Gary's post above, it would seem that some of the "911" models did indeed have the firmware installed at the factory as did apparently all models beginning with "912" as Dec is the last month of mfr'ing what with the 2311 models now in production.
Old 03-17-2010, 09:01 AM
gosparky's Avatar
gosparky -
I'm glad to hear the receiver isn't defective.
Regarding #1 above, I am using separate remotes for the Samsung TV and receiver. So I guess this means HDMI-CEC is off? I couldn't find anything related to that in the TV's menu though. Do you know what the setting might be called? I don't know too much about this.
I don't think the problem would have been the known problem you mentioned. My receiver was set to my PS3 game the entire time when the volume overlay disappeared, so I don't think the output resolution would have changed.
Thank you for your help.
gosparky is offline
Old 03-17-2010, 09:06 AM
jdsmoothie's Avatar
Liked: 5623
If your Sammy has the HDMI-CEC feature, it would be called Anynet+ and the fact that you're using separate remotes shouldn't matter. Although are you sure the volume overlay is coming from the AVR or is it perhaps coming from the Sammy itself?
Old 03-17-2010, 11:54 AM
grommett's Avatar
Originally Posted by christopherswaby View Post
lots to think about. i have seen new 1909 selling for 420 and new 2309 for 550 but compelling arguments have been made for the xx10 versions.
grommett, i am thinking about replacing my AVR 3200 - how are you liking the 2310 as far as sound is concerned?
Brilliant! Better than the 3200 in some ways which I didnt expect. ProLogic II Music is much better than the old 5-channel stereo. Movie dialogue is clearer (using Ruark Dialogue 1). I havent quite worked out how to select basic stereo for music through my main fronts (Castle Howards) but then I have been impressed with the PLII music. I was nervous about the change but I have not been disappointed. I originally changed because I ran out of digital sound inputs and fancied the idea of video switching.
Regards
Grommett
grommett is offline
Old 03-17-2010, 06:48 PM
tsduke's Avatar
I'm having an issue with my 2310 switching to TV/Stereo completely on it's own while watching satellite or BD. It happened a 2 or 3 time in the first couple days I owned it. At that time I updated the firmware and reset the chip.
Well....after a few weeks with no problems it's back again. Once yesterday and twice today.
Do I need to return it?
tsduke is offline
Old 03-17-2010, 07:08 PM
jdsmoothie's Avatar
Liked: 5623
tsduke -
Do you have the HDMI-CEC feature in your HDTV turned ON? If yes, turn it OFF (Samsung - Anynet+, Panasonic - Viera Link, Sony - Bravia Link, etc.).
Old 03-17-2010, 07:12 PM
jdsmoothie's Avatar
Liked: 5623
Press the D/ST (Direct/Stereo) button on the back of the remote which defaults to Front Mains - LARGE, sub - YES, LFE. In Direct mode there is no Audyssey processing.
tsduke's Avatar
tsduke -
I have a Sony. All I see under HDMI is a setting called "control for HDMI". It is off and has been.
tsduke is offline
Old 03-17-2010, 07:17 PM
jdsmoothie's Avatar
Liked: 5623
Then is should be called Bravia Sync (rather than Link) if you have a Sony. What model Sony do you have?
Old 03-17-2010, 07:27 PM
tsduke's Avatar
I have no Bravia sync on/off. Book says "control for HDMI" must be on to use Bravia Sync.
tsduke is offline
Old 03-17-2010, 07:32 PM
jdsmoothie's Avatar
Liked: 5623
That usually resolves the problem when it's turned off in the TV. You could also try making sure HDMI-CEC is OFF on your other components as well .. including the AVR (HDMI Control - OFF).
Old 03-17-2010, 07:38 PM
tsduke's Avatar
AVR HDMI control is off also.
tsduke is offline
Old 03-17-2010, 07:50 PM
jdsmoothie's Avatar
Liked: 5623
Old 03-17-2010, 07:53 PM
tsduke's Avatar
Can a powered off component with sync on cause issues?
Nevermind...all three of my HDMI components are off. I guess I'll call the store I bought it from and see what the recommend.
tsduke is offline
Old 03-17-2010, 09:39 PM
JackStraw2's Avatar
i am trying to decide between the 1910 and 2310. looks for me the main difference is the video processing/upconversion. my question is, it is going to be mated to a sony z5100. will i get any benefit of the 2310's better processing, or will the tv's processing be superior to either of the av units?
JackStraw2 is offline
Old 03-17-2010, 10:49 PM
gosparky's Avatar
Okay, I searched the menus again, and the TV doesn't have Anynet+.
When the volume overlay appears on the TV, it reads "MASTER VOLUME -XX.XdB." I've never seen the Samsung put out a volume overlay like that, so I assume it's the receiver's volume overlay... I don't even know how the TV would be displaying a volume overlay from me adjusting the receiver volume. None of my remotes are paired or anything so I don't know how the TV would know I was changing the volume on the the receiver. I could be completely wrong here though...
gosparky is offline
Old 03-17-2010, 10:58 PM
EJ
EJ's Avatar
I've got diva swan dipole surrounds. Any clue as to the proper x-over? I can't imagine it goes any lower than 110Hz. I could be wrong.
Former USSB uplink operator.
EJ is offline
Old 03-17-2010, 11:27 PM
jdsmoothie's Avatar
Liked: 5623
Then it's likely from the AVR.
Old 03-17-2010, 11:29 PM
jdsmoothie's Avatar
Liked: 5623
On paper they go down to 60hz, although speaker placement near a wall can change that a bit. What's more important is how the Denon set the crossovers after running AUTO SETUP.
Old 03-18-2010, 05:13 AM
Devin1886's Avatar
Quoted: 27 Post(s)
got a question. I want to use my ipod with my denon 2310ci so that all audio comes through my system and all video goes through my HDTV. What would be the best way to achieve this other than having to buy the denon ipod dock. BTW if I did buy the denon ipod dock, would the reciever upscale the video from my ipod? I appreciate any help. Thanks
Devin1886 is offline
Old 03-18-2010, 05:26 AM
jdsmoothie's Avatar
Liked: 5623
Devin -
The iPod docking station is probably your best bet, although you can probably find some 3rd party docking stations to use as well. The video can be upscaled by either the 2310 or your HDTV itself.
Old 03-18-2010, 09:05 AM
tsduke's Avatar
Well I talked to Denon about my avr switching to TV input by itself. Gave me 2 options....
1. Reset....I'm not doing this every 2-3 weeks on a $900 receiver
2. Make sure remote button isn't sticking....I have never even pushed the tv button and the remote isn't in sight of the avr right now. And from my experience the remote sucks and needs pointed directly at avr to work anyway.
I'm not happy.
tsduke is offline
Old 03-18-2010, 09:22 AM
jdsmoothie's Avatar
Liked: 5623
How do you know it's not an issue with the HDMI-CEC feature in the Sony? Don't be surprised if you swap the 2310 out and it still happens to you.
Old 03-18-2010, 09:24 AM
tsduke's Avatar
Are you referring to me? I have a Sony KDS-52W4100, a Sony BDP-N460. The HDMI control is OFF on all of them.
tsduke is offline
Old 03-18-2010, 09:30 AM
jdsmoothie's Avatar
Liked: 5623
tsduke -
Like I said .. how do you know it's really OFF on the Sony and not malfunctioning? The issue you describe has virtually always been resolved by turning the HDMI-CEC feature on the TV to OFF. As it hasn't worked with your Sony by turning it OFF, the possibility exists that it's not functioning correctly. Swap out the 2310 and if that solves the problem you'll know it's working.
Old 03-18-2010, 09:34 AM
tsduke's Avatar
tsduke -
That seems like a long shot to me. It says it's OFF.
tsduke is offline
Old 03-18-2010, 10:58 AM
degas's Avatar
I just got the 2310 (EU model), and can't find any option for YCbCr output in the HDMI-menu (only RGB Standard or Enhanced).
Is it not possible to change color space on this model?
If not, would it be better to output RGB from my PS3 instead of YCbCr (to avoid conversion), or doesn't it matter?
degas is offline
Old 03-18-2010, 11:16 AM
jdsmoothie's Avatar
Liked: 5623
degas -
YCbCr is the default color space for HDMI output although it was removed from the menu as as redundent due to the vast majority of owners using the HDMI output. Leave the PS3 where it's at and you'll be good to go.
