*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #6301 of 7384 Old 08-20-2011, 10:27 AM
jdsmoothie's Avatar
Quoted: 15333 Post(s)
Liked: 7489
Originally Posted by radar5 View Post
I did all that, and still the "ANA" light keep s coming on, no audio and I forgot to mention it did the same thing with another samsung DVD player I tried.
Have you tried a different set of HDMI cables? Make sure to try every HDMI jack on the 890 as well. Do other HDMI sources work? That unit has not had any firmware updates, although you can review post #2013 to see what BPD's have problems.
jdsmoothie is online now
post #6302 of 7384 Old 08-20-2011, 11:15 AM
radar5's Avatar
yes I have tries diffrent cables, directv works fine through hdmi.
radar5 is offline
post #6303 of 7384 Old 08-20-2011, 02:32 PM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
^^Check your Blu-Ray player settings. Make sure HDMI audio is set to 'ON' with video.
80sGuy is offline
post #6304 of 7384 Old 08-21-2011, 04:00 AM
BankZ's Avatar
I just got a Roku2 and I am having problems. If I pause the sound goes out. Anyone else using a Roku2 with this receiver?
I also started to have problems with my BR player last week. It seems to be having HDMI handshake issues.
Any ideas?
BankZ is offline
post #6305 of 7384 Old 08-21-2011, 04:57 PM
BankZ's Avatar
This is really driving me nuts. Whats the best way to resolve HDMI handshake issues?
BankZ is offline
post #6306 of 7384 Old 08-21-2011, 05:02 PM
jdsmoothie's Avatar
Liked: 7489
Give the HDCP HDMI reset a try as listed in this post. Also, power on TV, then AVR, then source device. And lastly you can try replacing the HDMI cables.
post #6307 of 7384 Old 08-24-2011, 07:37 PM
mphfrom77's Avatar
Quoted: 477 Post(s)
Liked: 345
If you use AUTO SETUP to set the speakers up and then plug the few components your parent's likely have into the same labeled HDMI jacks, the setup should pretty much be plug 'n play. The GUI set menu should make it even easier. If they have multiple rooms in the house, those speaker sets would likely need to be connected to an impedance matching speaker switch which would then be connected to the surround back/Zone 2 speaker posts with a 5.1 setup in the main zone.
JD, (or anybody) can you elaborate on this in regards to the 2310. As far as zone two on my parents 2310, there are basically four pairs of speakers being run off of zone 2. Kitchen, library, office and patio. I have it set up right now using an old Radio Shack one in / four out (A, B, C & D) small speaker selector box (but only have the kitchen and patio speakers set up...getting ready to set up the library and office). The rat shack speaker selector box really doesn't have any info about it on the box itself.
I guess I am asking what a "impedence matching speaker switch" is, and if you or anybody else had any good suggestions for where I could get a good one. Thanks.
mphfrom77 is offline
post #6308 of 7384 Old 08-24-2011, 07:49 PM
jdsmoothie's Avatar
Liked: 7489
Assuming each set of Zone 2 speakers are 8Ω speakers, if you only plan on turning on 1 set of speakers at a time (eg. A), then there's no issue as the AVR will simply see an 8Ω load. However, if you add another room (eg. A+B), the AVR now sees a 4Ω load from 4 speakers and likely still no issue. Then as you add a 3rd set (eg. A+B+C), the AVR sees a 2.6Ω load from 6 speakers which will likely shut down the AVR in protection mode. The lower the impedance gets, the more power is required from the AVR, which at some point it won't be able to provide and simply shuts down to protect itself. An impedance matching speaker selector will have switches that can be set so the AVR generally sees nothing lower than a 5Ω load regardless of whether you have all 4 sets of speakers on or not. Simply google "impedance matching speaker selector" and you will find numerous models available including this one.
post #6309 of 7384 Old 08-26-2011, 11:36 AM
KeithOz's Avatar
Hi all!
When was the last firmware update for the 2310?
KeithOz is offline
post #6310 of 7384 Old 08-26-2011, 02:52 PM
jdsmoothie's Avatar
Liked: 7489
post #6311 of 7384 Old 08-26-2011, 04:46 PM
bwilless's Avatar
Any ideas?
Lately I see the same problem from my Tivo. If you change the audio mode to something else say "SIMU" the audio comes back. It seems like the input audio changes and the receiver does not handle the switch.
bwilless is offline
post #6312 of 7384 Old 08-26-2011, 05:59 PM
bwilless's Avatar
I think I figured this problem out. Make sure the input is not set to Auto. Go to Menu --> Input Setup --> Input Mode (my input mode was set to Auto), I changed this to HDMI and I could not reproduce the no audio issue. Hope this works for your roku2.
Brian
Edit: Nevermind, I still have the issue.
bwilless is offline
post #6313 of 7384 Old 08-27-2011, 09:53 AM
jonny_ns's Avatar
I've been seeing that issue ever since the previous Tivo update. Obviously, something changed on their side. It only happens after trick play (fast forward/rewind/replay) on a streaming source, e.g. Netflix and Hulu.
jonny_ns is offline
post #6314 of 7384 Old 08-27-2011, 10:13 AM
bwilless's Avatar
Ya you may have something there. I mostly see it watching Hulu when the programming switches between commercials and the show I'm trying to watch. We've also seen it just watching the Tivo as well. It's gotten to the point where I had to add a new button (to switch audio mode) to our programmable remote so the wife can get the audio back without pausing, turning everything off, then back on.
bwilless is offline
post #6315 of 7384 Old 08-27-2011, 11:53 PM
mphfrom77's Avatar
Quoted: 477 Post(s)
Liked: 345
Thanks again jd. I will be purchasing one shortly.
post #6316 of 7384 Old 08-29-2011, 05:22 AM
SoundofMind's Avatar
Liked: 166
^mph, I had no idea you were still using that sig. Cracks me up. It's true, though-gotta get back to work now...
Yes, I still like playing with Dalis.
SoundofMind is offline
post #6317 of 7384 Old 08-29-2011, 05:57 AM
mphfrom77's Avatar
Quoted: 477 Post(s)
Liked: 345
Dude, it is hilarious. I was kind of joking when I asked if I could use it. But I put it in there and every time I read it I kind of laugh to myself and I just can't take it down yet. It just has not gotten old for me yet. It just seems so perfect for this site!
post #6318 of 7384 Old 08-30-2011, 07:38 AM
carter840's Avatar
Can someone explain the whole "Preamp" option. I hear a lot about preamps, but don't fully understand them. I have the 2310CI and from reading this thread it seems that it does have an option for preamps or am I misreading/failing to understand what's actually going on?
carter840 is offline
post #6319 of 7384 Old 08-30-2011, 07:45 AM
jdsmoothie's Avatar
Liked: 7489
Some AVRs have a full set of speaker preouts (eg. 7.1) that can pass the audio for the speakers to an external amp for more power/volume. The 3310CI is the lowest model that has this feature (unless you own a European 2310 which also has a full set of preouts). Unless you have really difficult speakers to drive (eg. 4Ω), you don't likely need an external amp for your main zone speakers.
Lower models like the 2310 generally will have Zone 2 preouts which can pass analog only source audio to an external amp to power Zone 2 speakers when you want to have a 7.1 setup in your main zone. If you only have a 5.1 setup in the main zone you can use the Surr Back/Amp Assign speaker posts to power Zone 2.
post #6320 of 7384 Old 09-08-2011, 11:51 AM
moolala's Avatar
just some casual observations over and above all the other lovely good things already packed into it.
1. sadly...right out of the box, no subwoofer output...have tried everything under the sun including full reset and even a different subwoofer. (I saw some people post about problems of their own earlier but did not see any followup resolutions...not sure how common it is or isn't. Likely going into shop before week is out)
2. would have been nice to amend channel levels unique to each surround mode (like my ancient HK)
3. would have been really really nice to have channel level changes unique to each source input (like my ancient HK)
4. surprised how slow video conversions take...switching to a source that requires upconverting takes 6-8 seconds before I see picture. Seems to me that DirecTV receivers, TV's, streaming software, etc (for example) can almost do this on the fly...yes ?
(must have something to do with factoring in the overlay capability maybe)
5. ability to change volume increase increments would also have been nice...with it only increasing by .5db, you have to hold button down to really get anywhere...and then it roars past target once it takes off.
Not complaining (other than the sub !!) just things I noticed thus far, some of which I could really have used.
If I find out anything useful or interesting re the subwoofer output, I'll post followup...I'm guessing it's going to be pre-amp or jack or solder or some such thing.
-moo
ps...indirectly related, as wonderful as the streamlined connectivity and single output to TV is, I really miss being able to tweak all the video settings on the TV for each source (when outputs were routed individually to it)....oh well, what can ya do ?!?!
moolala is offline
post #6321 of 7384 Old 09-14-2011, 01:37 PM
jleduc's Avatar
Hey everyone,
Just wanted to say thanks for all of the posts, it's really helped in set-up and enjoyment.
I have the AVR-890 (Canada) and I have it connected to my computer via HDMI. My LG tv is connected directly to the receiver via HDMI as well.
I have a newer video card in my computer, ASUS HD 6850 (model #EAH6850). If I were to install a blu ray player in my computer, will I be able to play blu ray movies and get it in real HD?
The only reason I'm asking is because I read something about linear limitations- LPCM??? and that systems can't play 8-channel ??
Thanks very much everyone.
jleduc is offline
post #6322 of 7384 Old 09-14-2011, 01:40 PM - Thread Starter
batpig's Avatar
Quoted: 3720 Post(s)
Liked: 3592
The only possible limitation would be the PC. The 2310/890 can play any current audio format.
If the card is capable of either bitsreaming hi-rez or decoding it to multich PCM then you are good to go.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #6323 of 7384 Old 09-14-2011, 02:32 PM
jleduc's Avatar
Thanks very much - btw, excellent guides. Seriously!
jleduc is offline
post #6324 of 7384 Old 09-15-2011, 10:06 PM
kev999's Avatar
i just purchased a Sony 3D LED tv, does my 2310CI work with the 3D tv?
kev999 is offline
post #6325 of 7384 Old 09-15-2011, 10:41 PM - Thread Starter
batpig's Avatar
Liked: 3592
depends what you mean by "work".
It will NOT pass through 3D video, but in all other respects it is perfectly compatible. IF you are going to do 3D, you can just get a 3D blu-ray player with dual HDMI outs and run one to the TV for 3D Video and one to the AVR for hi-def audio.
Setup Guide and FAQ
batpig is offline
post #6326 of 7384 Old 09-16-2011, 04:00 AM
jdsmoothie's Avatar
Liked: 7489
Depends on the 3D format and resolution (as there are several) ... at least one format will pass through the 2310 via a BDP (although forget which one), cable/sat box 3D channels (only 720p), and a HTPC with a 3D BD drive can be used with the "EDID override procedure" mentioned previously in this thread to pass 3D as well, but in general, as batpig indicates, you would need to update to an HDMI 1.4 AVR to guarantee all 3D formats/resolutions would pass through the AVR to your Sony 3D LED TV.
post #6327 of 7384 Old 09-16-2011, 06:46 AM
Lagwagon's Avatar
Fired up Netflix on my LG390-got video fine but no sound. Tried switching to other HDMI ports but same thing.The only thing that fixes it is to power cycle the 890.Then everything is fine. I might try another HDMI cable.The 890 had the first firmware change already installed.Also tried altering the power on sequence but still no sound.
Lagwagon is offline
post #6328 of 7384 Old 09-16-2011, 03:53 PM
jdsmoothie's Avatar
Liked: 7489
Are you certain the 1st firmware was installed? What are the main/sub firmware version #? Do you get audio if you set the BDP to PCM (ie. not bitstream)?
post #6329 of 7384 Old 09-16-2011, 07:07 PM
Lagwagon's Avatar
Main Ver = 00.69 and Sub Ver = 00.30.Setting to PCM also gives no sound.
Lagwagon is offline
post #6330 of 7384 Old 09-17-2011, 06:11 AM
jtiner's Avatar
Can anyone using the new Roku 2 confirm that the Dolby Digital Plus output is working with their AVR? The 2310 specs. indicate DD+ capable; I'm considering the Roku 2.....
jtiner is offline
