*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 224 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #6691 of 7384 Old 03-21-2012, 11:38 AM
phie's Avatar
Thanks! And w.r.t. television broadcasts, 5.1 is always Dolby Digital, am I correct?
phie is offline
post #6692 of 7384 Old 03-21-2012, 09:10 PM
skygremlin's Avatar
I have a Denon AVR-2310CI receiver and would like to run all my media thru it then out to the TV. Right now the only thing I have running thru it is a Samsung blu-ray player.
My goal is to hang our TV above our fireplace and run the cables thru the wall to an outlet along the side. I would like to use a wall plate from Monoprice and run only 1 HDMI cable to the TV.
I have Time Warner Cable and the cable box has a HDMI out which I plugged into my cab/sat HDMI in port on the back of the receiver, but when I select that input option on the menu the receiver tries to connect to Sirius and all I have is a blank screen. I'm not sure if I:
- Have something configured wrong.
- Have the wrong idea and it should be plugged into another port on the receiver.
- The signal out from my cable box will work with my receiver.
- Or if this isn't possible at all.
If I run the HDMI directly to my TV the cable works. Does anybody have any suggestions? I'm kind of a beginner (I've never used a receiver as a hub for my media) and am hoping that there is some config I just don't know about. If not I'll just run another HDMI thru the wall I'm also planning running the USB thru the wall as well so not that big of a deal.
thanx
skygremlin is offline
post #6693 of 7384 Old 03-22-2012, 05:12 AM
jdsmoothie's Avatar
Quoted: 15383 Post(s)
Liked: 7522
Suggest you reset the microprocessor (p. 70) and start the setup from scratch again as the connection you suggest should work correctly without any issues.
jdsmoothie is online now
post #6694 of 7384 Old 03-22-2012, 05:15 AM
jdsmoothie's Avatar
Liked: 7522
Yup.
post #6695 of 7384 Old 03-22-2012, 02:07 PM
skygremlin's Avatar
Thank you that worked..
post #6696 of 7384 Old 03-23-2012, 06:39 AM
mraghvani's Avatar
Hi there,
Im a newbie and found this Denon 2310 thread to be very helpful, but Im not sure if the problem I have, has been mentioned before, can you help ?
I have 5 HDMI sources connected to the Denon 2310 and the HDMI output from the amp connects direct to the TV. Recently Ive noticed that everytime I use the PS3 and switching the amp to the PS3 source, after a few minutes, the sound will disappear or it seems like the Denon has switched sources. I then have to manually switch to a different source on the Denon amp and then back to the PS3 source inorder for the sound and picture to work correctly.
Any ideas and Im sorry if I havent explained it very well.
I have noticed that a while ago (when the amp worked without any glitches) everytime I switched sources, you would hear a sort of clicking sound coming from the amp, but this never happens anymore.
Thanks in advance
eM
mraghvani is offline
post #6697 of 7384 Old 03-23-2012, 06:52 AM
jdsmoothie's Avatar
Liked: 7522
This has been known to happen from time to time on some units and generally requires repair if resetting the microprocessor (p. 70) doesn't resolve the issue. You could also try swapping the PS3 to a different HDMI input.
post #6698 of 7384 Old 03-23-2012, 07:01 AM
mraghvani's Avatar
Wow thanks for replying back so quickly.
I'll check p.70 on resetting the microprocessor, does the resetting wipe all previous setting and config of the amp ? as it took me ages to get it running and sounding the way I like it.
I'll also try the switching into another port.
PS: Is there also a way of having HDMI 1 (DVR) switched to another button on the front of the remote (my presets 1-3 are all being used), so I dont have to keep opening the flap and pressing DVR for one of my sources.
post #6699 of 7384 Old 03-23-2012, 08:23 AM
jdsmoothie's Avatar
Liked: 7522
Yes indeed, resetting the microprocessor will return all settings to their mfr defaults to including wiping out the Audyssey settings so this should be a "last resort" action. The HDMI inputs can be "assigned" to any source name as listed on p. 37.
post #6700 of 7384 Old 03-23-2012, 08:48 AM
mraghvani's Avatar
Thanks for your advice, I'll test with the 2 option first and see what occurs.
Will update with the fix soon
post #6701 of 7384 Old 03-23-2012, 07:45 PM
phie's Avatar
So, I couldn't get sound when I picked Amazon Video on Demand widget from my Sony Bravia TV. My setup is as follows:
Verizon FiOS STB to Denon 2310 to TV via HDMI.
I just kept hearing what TV show was on the STB playing, rather than the sound from the video from the Amazon Video on Demand widget. Do I need to make a new input just for the TV widgets, so I can use Amazon and Netflix (which are on my TV)?
What do I do to fix this?
phie is offline
post #6702 of 7384 Old 03-23-2012, 09:07 PM - Thread Starter
batpig's Avatar
Quoted: 3729 Post(s)
Liked: 3607
well, if the audio is being created by the TV, it needs a way to get OUT of the TV and BACK to the receiver, right? so run an audio cable from the TV's audio output back to the receiver.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #6703 of 7384 Old 03-23-2012, 09:18 PM
phie's Avatar
Would an optical cable be okay? And I can keep it on the TV source or do I have to make a new source/input for it? Do I need to assign the audio cable input in the source select?
phie is offline
post #6704 of 7384 Old 03-24-2012, 02:33 AM
jdsmoothie's Avatar
Liked: 7522
post #6705 of 7384 Old 03-26-2012, 08:21 PM
skygremlin's Avatar
OK so after reseting the receiver some TV shows the audio and video are way off, others are fine. I double checked and the Auto LipSync is "On"
Anybody have thoughts?
thank you
post #6706 of 7384 Old 03-26-2012, 08:52 PM
Splicer010's Avatar
Liked: 40
What TV shows and what network are they on that give you this issue?
Splicer010 is offline
post #6707 of 7384 Old 03-26-2012, 09:16 PM
skygremlin's Avatar
KTLA - I think I might have noticed this on something like TNT or FX. The thing is I watch CNN every morning and don't notice anything wrong... But it's definitely noticeable when it's off.
It really stood out the other night some channel had "The International" on.. The audio and video were way off while the receiver was powered on. When I powered off the receiver, and the audio was generated via the TV they same movie was spot on, no issues.
post #6708 of 7384 Old 04-03-2012, 05:47 PM
Blackcat2950's Avatar
Wow - thanks guys. Bought my 2310CI a little over 2 years ago, came home tonight, no sound at all from any source. Double checked everything in the menu - fine. Tried running the Audessey setup just to see if it would generate a tone - no dice, wouldn't go into that screen.
Long story short, after about 60 minutes of fussing with it, reading the manual, checking connections & many 4 letter words uttered, I was about this " " close to ripping the AVR out and kicking it. Luckily, I decided to check this thread before doing that...
Add another +1 to the "dust in the headphone jack". Geez.
Blackcat2950 is offline
post #6709 of 7384 Old 04-03-2012, 11:56 PM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
^^Denon ships all their 2310s with a Gremlin egg, it takes about a year or two for it hatch and wreak havoc inside your system.
80sGuy is offline
post #6710 of 7384 Old 04-05-2012, 08:05 PM
bruce73's Avatar
Could someone please remind me -- are the Dynamic Volume settings input-specific or global?
bruce73 is offline
post #6711 of 7384 Old 04-05-2012, 08:46 PM - Thread Starter
batpig's Avatar
Liked: 3607
All the Audyssey settings are input specific.
Setup Guide and FAQ
post #6712 of 7384 Old 04-05-2012, 09:38 PM
bruce73's Avatar
Thanks. My ears were deceiving me. ;-)
bruce73 is offline
post #6713 of 7384 Old 04-05-2012, 10:17 PM
Splicer010's Avatar
Liked: 40
Not your ears...look for the little green LED in the bottom right of the display panel. Dynamic On = green LED. Dynamic vol off = red or no LED. I generally leave the DV on for the TV setting and off on all other inputs.
post #6714 of 7384 Old 04-06-2012, 06:06 AM
bruce73's Avatar
No, I wasn't referring to whether DV is on or off. I meant the specific modes (Day, Evening, Night). When I set that with my remote to Day for the TV input, does that setting persist when I change to another input (e.g. Bluray), or does it change back to Evening (which is where I generally have it for BRs).
bruce73 is offline
post #6715 of 7384 Old 04-06-2012, 08:25 AM
jdsmoothie's Avatar
Liked: 7522
As batpig already noted, the DV (D,E,M) setting is specific for each input.
post #6716 of 7384 Old 04-06-2012, 09:02 AM
bruce73's Avatar
Got it. Thanks, guys.
bruce73 is offline
post #6717 of 7384 Old 04-06-2012, 11:19 AM - Thread Starter
batpig's Avatar
Liked: 3607
FYI - open the GUI and go to AUDIO ADJUST and then AUDYSSEY SETTINGS
*everything* in that menu is set individually per input
Setup Guide and FAQ
post #6718 of 7384 Old 04-06-2012, 12:15 PM
bruce73's Avatar
I *think* once upon a time I knew that, but thanks for confirming.
bruce73 is offline
post #6719 of 7384 Old 04-06-2012, 02:12 PM
80sGuy's Avatar
Quoted: 194 Post(s)
Liked: 37
Pretty much most things are input specific EXCEPT for the 'audio' parts (bass & treble, etc.) and all the Surround Level settings. These all run across the board no matter which input.
80sGuy is offline
post #6720 of 7384 Old 04-14-2012, 07:47 AM
phie's Avatar
Can I install an IR receiver so I can put my Denon 2310 in a media cabinet out of the way, but have the IR receiver next to the TV, so I can control it without having to get up and point the remote at the TV?
If the technology isn't an "IR receiver" and it's something else, can you let me know? Sorry for the ignorant question but if this is possible, my life will be so much easier (my wife is worried that our infant is going to hurt herself near all the AVR wires)...
Thanks!!!
NB: To be clear, I want this for Zone 1, not Zone 2 (I do not use Zone 2 nor plan to for the foreseeable future, if that matters...)
phie is offline
