*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 242 - AVS | Home Theater Discussions And Reviews
 2Likes
post #7231 of 7252 Old 10-12-2014, 07:06 PM
biglen's Avatar
Quoted: 52 Post(s)
Originally Posted by jonny_ns View Post
I just got a Samsung 8550 set. I connected the optical out from the TV to the receiver. It usually works, but I'm getting some of the audio drop outs like with the Blu-Ray players in the past. It's very annoying. I guess I should get around to updating the firmware.
Just out of curiosity, why do people run an optical cable, from the TV, to the receiver?
biglen is online now
post #7232 of 7252 Old 10-13-2014, 04:35 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2656 Post(s)
Liked: 1903
Modern smart TVs generally have a bunch of available streaming applications (eg. Netflix, Hulu, Vudu, Pandora, etc.). Connecting an optical cable allows the application's audio to transfer to the AVR in order to use the surround speakers. More current HDMI 1.4 or HDMI 2.0 can also use the HDMI(ARC) feature to pass the audio over the HDMI cable that connects the AVR to the TV.
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and dealer for AVRs and Speakers
Daily 8am – 8pm EST
Call for info on Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #7233 of 7252 Old 10-18-2014, 09:25 AM
jonny_ns's Avatar
Speaking of the optical from the TV to the 2310, I just noticed that my subwoofer isn't working for music when the TV is outputting PCM and the AVR is set to "Direct." (I didn't notice earlier because I usually have the sub turned way down so that I don't wake my toddler.) It works when switching to a different surround mode, e.g. stereo.
I was under the impression that I should have it set to "Direct" to allow the source to set the appropriate mode automatically. Is there a way to get this automatic surround behavior and have the sub to work with stereo content?
SOLUTION: Settings > Manual Setup > Speaker Setup > Bass Setting > Mode: LFE+Main
jonny_ns is offline
post #7234 of 7252 Old 10-18-2014, 10:17 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1903
Solution - Never use DIRECT as it disables both Audyssey and bass management.
Daily 8am – 8pm EST
post #7235 of 7252 Old 10-18-2014, 02:27 PM
80sGuy's Avatar
Quoted: 30 Post(s)
Although 'pure', Direct is never a good sounding in any environment.
80sGuy is offline
post #7236 of 7252 Old 10-18-2014, 03:04 PM
80sGuy's Avatar
Quoted: 30 Post(s)
When doing this (at least on my Panasonic Plasma+2310) it will not decode 5.1 surround but only in stereo. The receiver will output to 5.1 'Pro-Logic' but the source routed is only two-channel.
I use the same connection: cat5 to TV, Cable Box to 2310ci SAT/CABLE, then 'MONITOR' OUT via HDMI to my plasma. Correct me if there's a way but I haven't been able to do so, or maybe if there is ethernet connection on the 2310 this will process 5.1?
The 'Viera' menu on my TV shows Netflix contents in HD but no description on sound. My solution was to use a digital media player such as the WD Live HUB and then I get full 5.1 Surround Audio.
80sGuy is offline
post #7237 of 7252 Old 10-18-2014, 06:30 PM
jonny_ns's Avatar
Don't know why that's happening for you. Maybe it's the Panny Plasma? My 2310 processes 5.1 just fine.
jonny_ns is offline
post #7238 of 7252 Old 10-18-2014, 06:39 PM
jonny_ns's Avatar
Haha, I did not know this. That explains why dynamic volume was "NOT AVAILABLE."
jonny_ns is offline
post #7239 of 7252 Old 10-18-2014, 11:19 PM
80sGuy's Avatar
Quoted: 30 Post(s)
I believe due to the ethernet cable connected directly into the TV, there's no way for the receiver to process since there isn't an ethernet connection for the 2310ci - therefore it couldn't decode.
80sGuy is offline
post #7240 of 7252 Old 10-20-2014, 05:06 AM
whipit's Avatar
Quoted: 41 Post(s)
Liked: 71
The Panasonic tv's will decode 5.1 properly from the internal apps and tuner. Everything else will be 2.0. It works the same if you Have the ARC option.
whipit is offline
post #7241 of 7252 Old 10-20-2014, 05:38 AM
80sGuy's Avatar
Quoted: 30 Post(s)
^^Yes that's right, the Panasonic 42-inch VIERA TC-P42G25 Plasma HDTV is decoding 5.1 correctly in/out/ from my 2310ci EXCEPT for Netflix. So basically you're saying this is normal when Netflix is only available in 2.0 Stereo when viewed through VIERAlink apps and no other way of getting 5.1?
Connection:
Ethernet: from router to TV
TV: HDMI IN from Cable Box>HDMI OUT to 2310ci SAT/CAB IN
2310ci: OUTPUT to TV
Notice ethernet cable is only connected directly to the TV? I'm using a WDTV Live Hub media player - connected to one of its HDMI ports (HDP) on the 2310ci for 5.1 surround. If I use the VIERA Netflix app from my TV, it automatically switches to 'TV' mode on the receiver with only 2.0 Stereo sound.
80sGuy is offline
post #7242 of 7252 Old 10-20-2014, 04:12 PM
80sGuy's Avatar
Quoted: 30 Post(s)
^^Found the exact question to my answer here. Reasons why it couldn't export 5.1 surround sound to receivers was due to copyright laws. Doesn't make any sense.
http://www.highdefforum.com/flat-pan...ers-aware.html
80sGuy is offline
post #7243 of 7252 Old 10-21-2014, 06:06 AM
whipit's Avatar
Quoted: 41 Post(s)
Liked: 71
True, the tv can't upscale audio, it just passes through or downscales. Best bet is to use another source besides the tv for Netflix since they kind of gimp the app in tv's.
Connection:
Interesting that you use the HDMI out to the tv, negating the need for ARC on both devices. I should try that with my VT60>2310ci.
So Netflix works fine from your WDTV(if I'm reading this right) and the Denon works well with it. When it's playing in stereo mode from the tv can you change a setting on the Denon at that time? Not sure if there's anything in there that can do that and it might need to be changed back for other sessions.
whipit is offline
post #7244 of 7252 Old 10-21-2014, 04:29 PM
80sGuy's Avatar
Quoted: 30 Post(s)
^^How do you connect yours? From my understanding, this is the only way to connect w/o having to switch sources on the TV - leaving it only on HDMI 1 and SAT/CAB mode.
As for Netflix, it works fine from TV except I can't get 5.1 out to the 2310ci, it only plays in 2-channel stereo, but if I switch to the WD LIVE HUB Media player (connected to receiver's HDMI in 'HDP') then I get full surround if available.
Look at my screenshot configuration below.
80sGuy is offline
post #7245 of 7252 Old 10-22-2014, 05:31 AM
whipit's Avatar
Quoted: 41 Post(s)
Liked: 71
I'm not using Netflix and have no experience with it. Due to the copyright that Panasonic is following you won't get 5.1 from the tv with Netflix. The only fix would be a different brand tv such as Sony or Samsung. Here's a thread with the same question.
Panasonic G25 audio out
You may also want to post in the TV's Owners Thread or start a new one in the Plasma section.
Official Panasonic GT20/25 Owner's Thread!
whipit is offline
post #7246 of 7252 Old 11-23-2014, 07:07 AM
jtiner's Avatar
Sorry if this has been covered, but a quick thread search didn't reveal anything.... I've been experiencing distortion when playing some Netflix titles, and I'm wondering if it's the general Netflix/AVR problem that's been discussed in other threads.
The problem occurs with Dolby Digital titles (the front panel "HD" indicator is on) sourced through my Oppo BDP-103. The problem manifests itself as a kind of "slur", and isn't always immediately obvious, depending on the program material. It's hard to describe other than a slur; it sounds a bit like when a 16mm print starts slipping in the gate, sort of a modulated distortion. I always end up having to stop the stream and switch the program audio option to "stereo".
Anyway, I couldn't find a definitive list of affected receivers and didn't find anything at the Denon site so I thought I'd check here to see if anyone can confirm that the 2310 is one of the affected receivers and perhaps if there's a solution.
jtiner is offline
post #7247 of 7252 Old 11-23-2014, 07:13 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1903
The Netflix issue involves DD+ audio generally resulting in distortion from only the center speaker on all year models. It was resolved with a firmware update for the XX11 and newer models. The solution for you would be to set Netflix to Stereo and use DD PLII to simulate 5.1.
Daily 8am – 8pm EST
post #7248 of 7252 Old Today, 10:49 AM
Liked: 0
Default volume setting
Hi
Where can I set the volume default. Right now it is 50% and too loud each time I turn on.
I lower to 35%, but when I turn off and on..... it is back to 50%
thanks
dearfred is online now
post #7249 of 7252 Old Today, 11:27 AM
JChin's Avatar
Quoted: 126 Post(s)
Liked: 140
Originally Posted by dearfred View Post
Hi
thanks
Hi dearfred, Volume Control Power On Level can be found under Option Setup menu.
JChin is offline
post #7250 of 7252 Old Today, 11:55 AM
Liked: 0
Hi
thanks
post #7251 of 7252 Old Today, 12:13 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1903
The Volume Control - Power On Level (p. 33 Owner's manual) defaults to LAST volume used when unit is powered OFF. If you are using a Quick Select to power on the AVR, you'll need to resave it using the desired volume. Otherwise, you can also set the Power On Level to a specific volume.
Daily 8am – 8pm EST
post #7252 of 7252 Old Today, 12:14 PM
Liked: 0
Thanks---
Fumbling around the menu-- just didnt see the correct area
