*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 243 - AVS | Home Theater Discussions And Reviews
 2Likes
post #7261 of 7276 Old 04-12-2015, 05:39 PM
JChin's Avatar
Quoted: 177 Post(s)
Liked: 150
Originally Posted by pmcduie View Post
Play a 2D DTS-HD Blu-Ray and the display on the receiver shows the correct signal ( DTS-HD, "blue light"), but no sound comes out of the receiver.
If I change the Digital Audio Output -> PCM, the same 2D Blu-Ray displays MULTICH IN, and I get sound OK from the receiver.
Any ideas on why it does not get any sound when in Bitstream mode ( i.e processed by the receiver, not the Blu-Ray player).
Hi pmcduie, there were a firmware released for this receiver to correct this issue for some BD players. So check that firmware is up to date on receiver (see post #1 ) and BD Player.
JChin is offline
post #7262 of 7276 Unread 04-12-2015, 09:21 PM
pmcduie's Avatar
I suspect it would not cover this relatively new Blu-Ray player.
It is also not the easiest thing to upgrade firmware on these receivers, since they are not network connected. Unless It could be guaranteed that this would resolve the problem, I think I will live with it as it stands.
Thanks for the help anyway
pmcduie is offline
post #7263 of 7276 Unread 04-13-2015, 12:07 AM
mogorf's Avatar
Quoted: 427 Post(s)
Liked: 166
Hi, apart from the display showing DTS-HD and the "blue light" on, do you see the input indicators lit (left side of display) or not?
mogorf is online now
post #7264 of 7276 Unread 04-13-2015, 12:23 AM
80sGuy's Avatar
Quoted: 109 Post(s)
Liked: 27
First of all the 2310ci is by no means "the weak link in the chain". Newer isn't always better, but I still think the AVR-2310ci has a lot to offer. Regarding your issue, what does this say when pressing this on your remote setting?
Menu>Input Setup>Input Mode: AUTO, HDMI or EXT IN?
If possible, switch it to HDMI or AUTO.
Thanks for the quick reply.
I have cycled through them 2 or 3 times, no difference. I have checked HDMI control, and it is set to Off.
I understand the 3D issue, I have the following components:
Panasonic 3D Blu-Ray
Denon AVR-2310 receiver
Samsung 55" #D TV ( UA55H7000).
I was always expecting the receiver to be the weak link in the chain and will probably replace it in the near future with one of the newer Denon models ( e.g. AVR-X1100W). For now I can get Multi Ch IN sound , but really curious on why the Bitstream does not work.
Any way many thanks for the help.
Phil
80sGuy is offline
post #7265 of 7276 Unread 04-13-2015, 12:45 AM
pmcduie's Avatar
Looks like it has "self corrected " itself. I have just restarted the Blu-Ray, changed the Digital Output from PCM back to Bitstream, played a Blu-Ray with DTS-HD and sound can now be heard. Maybe it was the complete powering down and restarting that made the difference.
Anyway , all is now OK.
Many thanks to all of the responses on this issue, it is greatly appreciated. This and other similar AVS forums have helped me to resolve many issues over the years.
I also agree that newer is not always better, but my experiences with Denon receivers has been a continual improvement for me progressing from the following :
AVR-2808 ( now being used by my daughter in her apartment and never missed beat)
AVR-2310 (now used in a second room)
AVR-4520 ( Main home theatre setup, in 7.2 configuration, 5.2 + Front wides)- This receiver is the best by a long way, it performance for both music and home theatre has been a revelation to me. I have been a Hi-Fi enthusiast for over 30 years and this receiver provides a superlative performance on stereo music ( using Audyssey), and amazing surround sound experience using 2 sub-woofers.
I will not be changing from Denon any time soon.
Anyway once again, thanks to all for your help.
pmcduie is offline
post #7266 of 7276 Unread 04-13-2015, 01:08 AM
mogorf's Avatar
Quoted: 427 Post(s)
Liked: 166
Glad to hear your problem resolved. Enjoy your Denon(s), just like I enjoy mine!
Be well.
post #7267 of 7276 Unread 04-14-2015, 11:52 AM
gamecock's Avatar
I wish I could get a avr to last that long . I keep flipping from denon to pioneer as their digital input boards die around month 30
gamecock is offline
post #7268 of 7276 Unread 04-14-2015, 11:57 AM
80sGuy's Avatar
Quoted: 109 Post(s)
Liked: 27
I hope not. Mine has been over 48 months and still working nicely.
80sGuy is offline
post #7269 of 7276 Unread 04-14-2015, 11:58 AM
mogorf's Avatar
Quoted: 427 Post(s)
Liked: 166
Are you running the avr 24/7? Do you have proper ventillation around the avr? These factors can greatly influence the life-time of the avrs or certain components inside.
post #7270 of 7276 Unread 04-14-2015, 12:06 PM
gamecock's Avatar
It can't put my finger on it, but no they aren't 24x7. I was concern about heat at one time and put a temperature control fan in cabinet. However when the pioneer sc55 went in and ran so cool , I got rid of that setup in one of my 'cleanup ' projects.
My latest theory is static electricity frying via speaker or hdmi inputs
gamecock is offline
post #7271 of 7276 Unread 04-14-2015, 12:34 PM
mogorf's Avatar
Quoted: 427 Post(s)
Liked: 166
Actually my fear would not be static electricity but the cabinet witout a cooling fan!!! Maybe worth to reconsider the "cleanup project" again. Just thinkin' out loud.
post #7272 of 7276 Unread 04-14-2015, 01:25 PM
80sGuy's Avatar
Quoted: 109 Post(s)
Liked: 27
You guys are making me nervous. Mine is filled in the slot and seemed to run adequately cool compared to another harman/kardon on the same space.
80sGuy is offline
post #7273 of 7276 Unread 04-14-2015, 02:19 PM
mogorf's Avatar
Quoted: 427 Post(s)
Liked: 166
I think you are good to go as long as it runs cool on the top (read: luke warm+).
On a special note, I like the color tone of your woodwork! Please see my setup (link in my sig). Quite similar, but left side completely open.
BTW, a bit of dusting seems due. I do the dusting (top and underneath) once a week on the weekend. Another enemy of our electronics.
post #7274 of 7276 Unread 04-14-2015, 04:13 PM
80sGuy's Avatar
Quoted: 109 Post(s)
Liked: 27
Oh, yours is MUCH nicer! You've got the 'wall of sound' compared to what I have. But I agree, beautiful wood-work! Talk about dust, I didn't realize it until I put the flash on. Thinking about getting something darker to blend in with the whole ensemble but when I think about the dusts...forget it! By the way, cooling on that part seemed alright since I cut and expanded the wiring hole.
80sGuy is offline
post #7275 of 7276 Unread Yesterday, 06:36 PM
Liked: 0
Can someone please help?
Hello all, I hope I am posting this in the correct place. My dilemma, I am attempting to run 2 Infinity IL-60's on a denon 2310ci receiver. I just completed R.A.B.O.S with not much difference after testing 3 times and adjusting back of speakers twice. I then tried to run the audyssey setup and it says ambient noise too loud or level too low. I assure you it isn't the ambient noise. I have the speakers hooked up via Y connector off of the receiver pre-out to sub in on both speakers and speaker wire from front A on receiver to speaker terminals on back of speaker. Can someone tell me what postion switches need to be in? Switches are (Sub input, speaker or line) (Low pass filter, on or off) (Bass optimization system, on or off ) I am stumped and a little ignorant to all the bells and whistles of this receiver.
66shovelhd is online now
post #7276 of 7276 Unread Today, 04:54 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3575 Post(s)
Liked: 2144
Sub input - line
Low Pass Filter - Off
Bass Optimization - If this is referring to the RABOS EQ you did, then ON, although you may not notice much difference if OFF
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
