*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 245 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #7321 of 7333 Old 06-26-2016, 06:02 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 9739 Post(s)
Liked: 4521
Originally Posted by tpike View Post
Moved into a house with built in speakers, the one outside is really fun. Per batpigs suggestions I've got the zone 2 going via amp assign. My concern is that I've got to set the volume to it's highest setting in order to get it loud enough to hear outside. I'm using aux input in the front of my 890 and connecting my note 5 via headphone to rca. Anyone else using a similar setup? Having to turn volume to max on your receiver?
Sent from my SM-N920V using Tapatalk
You've got a much longer speaker wire run so to be expected. You may instead want to consider using an external 2CH amp via the Zone 2 pre-outs for more power.
tpike likes this.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #7322 of 7333 Old 06-26-2016, 07:59 PM
highmr's Avatar
Quoted: 51 Post(s)
Liked: 30
Did you insert a speaker selector? The house I moved in had speakers for all rooms shorted together
I've run the system (with the Monoprice speaker selector) with a 1712 using the internal amps and with a 2310ci using the preouts and a circa 1990 Sony receiver as an amp. The preout + Sony combination can get louder. Also, check that there is not a -10 dB volume limiter for zone 2. I had that on the 1712 as the default, not sure if it was on the 2310ci. On the 1712 using the internal amps I definitely had to get to about 0 for reasonable volume to zone 2.
tpike likes this.
LCR: Hsu HB-1 MK2, HC-1 MK2..........Subwoofers: Rhythmik D15SE, Hsu VTF-2 MK4
Receiver: Denon 1712CI, 2310CI........Networking: Roku 3, WDTV Live......Other: MiniDSP 2x4 RevB
Blu-Ray: Oppo BDP-80, Sony S590.....TV: Samsung PN60F8500, Panasonic TC-50PU54
Atmos/DTS-X: 5.1.4; RSL C34E speakers; receiver TBD
highmr is offline
post #7323 of 7333 Old 06-30-2016, 04:27 PM
Liked: 0
Thank you both for replying! Just to clarify, you're both implying putting an amp between my denon and the speaker?
Yes it is a pretty long pull to the outside klipsch. There's also a little volume slider on the wall to give me control closer to the speaker. I'm not positive where to look for the -10 db limiter. I have noticed that some sources have a little number on the to right of the screen that looks like db. Not sure what it stands for, frankly I've not played around to see if it's a source volume or something. Seems to fluctuate, Idk.
Lastly, no speaker selector. Currently, it's phone to headphone splitter to rca to denon and this thing built into the walls that pushes sound to speakers in the ceiling indoor. That volume is much louder and isn't running through denon. Maybe there's an amp in those speakers.
tpike is offline
post #7324 of 7333 Old 07-02-2016, 11:03 AM
80sGuy's Avatar
Quoted: 173 Post(s)
Liked: 31
FM Tuner not working, no sound at all.
All of a sudden my FM tuner stopped transmitting. It was working fine all these years, though signal can be shady at times but usually moving the antenna around will improve. I turned on the receiver yesterday and there was very little to zero signal even though I rearranged the antenna, then today it became silent, totally dead! AM radio works fine though. I've tried everything from....
- unplugging, re-plugged the antenna,
- tried a tv coaxial wire and got a split second of signal then went dead.
- tried (the classic) inserting speaker wire into the pin hole but nada...
- made sure it wasn't on Zone 2
- made sure it wasn't on EXT-IN
- re-tighten all HDMI cables
- switched between auto-tune to manual tune by pressing 'Mode' on back of remote...from here I get PURE STATIC!!!
Only thing I have not tried is do a 'factory reset' which I'm trying to avoid (due to custom settings) is probably my last option. Any thoughts? Has anyone experienced this FM tuner erratic behavior?
80sGuy is offline
post #7325 of 7333 Old 07-02-2016, 05:10 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4521
Try first doing a "soft reset" by powering off and unplugging the power cord to the AVR. If still no joy, the factory reset is the next option.
post #7326 of 7333 Old 07-05-2016, 06:06 AM
80sGuy's Avatar
Quoted: 173 Post(s)
Liked: 31
Did both resets, no go. AM works fine but FM is dead quiet in 'Auto' mode, and nothing but static on manual.
80sGuy is offline
post #7327 of 7333 Old 07-05-2016, 06:36 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4521
Sounds like the FM tuner is gone.
You may want to consider connecting an external FM radio as a work around.
post #7328 of 7333 Old 07-05-2016, 07:56 AM
80sGuy's Avatar
Quoted: 173 Post(s)
Liked: 31
Yeah, I think it is on its last breath. Funny it is all in one unit shared with AM. Next step is moving the deck out and place it near a window to see if I can catch any signal because sometimes I can get a split-second 'tuned' by painstakingly moving the antenna around, but it then dies out. If that doesn't work then I'd have to take the tuner out and see if a thorough cleaning would help.
80sGuy is offline
post #7329 of 7333 Old 07-07-2016, 04:55 AM
rjuch's Avatar
Hi Guys
I have an AVR2310, something strange happened a while ago and im not sure if there's something wrong with my AVR or if i've done something to cause the behavior. Avr functions perfectly when in CBL and Media player mode (satellite decoder and apple tv), when i either us the FM radio function or Satellite radio (network) function, audio plays fine, but i dont get any picture on my TV. Picture so i can change satellite radio stations, program memory,etc...
rjuch is offline
post #7330 of 7333 Old 07-07-2016, 07:47 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4521
Originally Posted by rjuch View Post
Hi Guys
This has been known to happen on some units which may require repair to resolve. Try doing a "soft reset" by powering off and unplugging the unit for 10 minutes.
post #7331 of 7333 Old 07-10-2016, 08:25 AM
80sGuy's Avatar
Quoted: 173 Post(s)
Liked: 31
I fixed the issue by replacing the tuner. First I tried cleaning the original unit but it was totally sealed, and did what I could by spraying Contact Cleaner but still no go so I got a used tuner and voila...now my FM is working like it should, along with AM of course. The (used) replacement part is exactly the same. Not bad for a $10 fix!
80sGuy is offline
post #7332 of 7333 Old 07-11-2016, 01:11 AM
rjuch's Avatar
Thanks, my mistake, i actually have a 2313, i assume its probably a similar issue? Tried unplugging the unit, now change...
rjuch is offline
post #7333 of 7333 Old 07-11-2016, 01:15 AM
585-645-1006
jdsmoothie's Avatar
Liked: 4521
Correct. Try doing a few microprocessor resets (p. 156 Owner's manual) in a row.
