*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 246 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #7351 of 7368 Old 11-25-2016, 05:39 PM
mrpergo's Avatar
Thank You, I'll check it out
mrpergo is offline
post #7352 of 7368 Old 11-25-2016, 07:26 PM
80sGuy's Avatar
Quoted: 179 Post(s)
Liked: 34
Originally Posted by mrpergo View Post
do you think if I change the hdmi cable from the player to the receiver would help ?
It might, HDMI has a way of its own. Some cables won't even work right unless it is plugged in from one direction, meaning they are not bi-lateral and only works from 'one-way'.
80sGuy is offline
post #7353 of 7368 Old 11-26-2016, 02:10 PM
mrpergo's Avatar
Yeah I know, I was thinking of getting an active to try that.
mrpergo is offline
post #7354 of 7368 Old 12-02-2016, 11:15 AM
brettwf's Avatar
Could the problem of no sound be dust build up in the headphone jack? I've had that happen twice with my system. Fixed with compressed air.
brettwf is offline
post #7355 of 7368 Old 12-03-2016, 12:08 PM
mrpergo's Avatar
doesn't hurt to try but I get sound just not Dolby TrueHD. I found if I toggle through the audio options after I'm running the movie it will start playing the sound in TrueHD. I might just hook my sony player to this receiver to see if that solves my problem
mrpergo is offline
post #7356 of 7368 Old 12-03-2016, 03:27 PM
mrpergo's Avatar
I've decided to upgrade my projector, I have a Sanyo 720p and plan to upgrade to a BenQ HT2050 which is 1080p & 3D.
Right now I run everything through the 890 for video. I understand the 890 won't pass through the 3d is that correct ?
If that is right I have 2 choices I think, the new projector has 2 HDMI in puts so I could go direct to projector with HDMI and the blu-ray has coax audio out, so I could go to the receiver with that ?
option 2 is, I have a Denon AVR-1712 upstairs that does pass through 3d and swap the 2 receivers out.
Any thoughts people.....lol
mrpergo is offline
post #7357 of 7368 Old 12-04-2016, 04:48 AM
jdsmoothie's Avatar
Quoted: 12142 Post(s)
Liked: 5531
1. Although it will pass half 3D, it will not pass full 3D.
2. Correct, although optical can pass only standard DD/DTS audio (ie. HDMI is required to pass HD audio).
3. 1712 is a higher level model so swap it in.
jdsmoothie is online now
post #7358 of 7368 Old 12-04-2016, 05:09 AM
mrpergo's Avatar
or jd I could tell my wife there is no way around upgrading to the x4300.........LMAO
Thanks for all your time and help on here over the years
mrpergo is offline
post #7359 of 7368 Old 12-04-2016, 05:26 AM
jdsmoothie's Avatar
Liked: 5531
Oh yeh ... then it's "HELLO ATMOS/DTS:X and HEOS!!!!"
Review the HEOS website and she may end up liking the idea of wireless speakers in a few rooms in the home. Denon has continued the promo where you would get a FREE HEOS 1 (or $200 credit towards purchase of HEOS 3/5/7) with purchase of a new X4300H.
https://usa.denon.com/us/heos
post #7360 of 7368 Old 12-04-2016, 05:42 AM
mrpergo's Avatar
I have to keep finding places to put the old Denon's , I use my old 3802 in the garage with the 3800.
I'll check it out, Thank You
mrpergo is offline
post #7361 of 7368 Old 12-04-2016, 10:23 AM
mrpergo's Avatar
jdsmoothie will the 890 pass the blu-ray 1080P ?
If I have a Blu-Ray 3d player and just play blu-ray's would I be okay until I upgrade or swap the receiver ?
mrpergo is offline
post #7362 of 7368 Old 12-04-2016, 01:13 PM
jdsmoothie's Avatar
Liked: 5531
Yup.
post #7363 of 7368 Old 12-12-2016, 01:11 PM
bxconst's Avatar
Is the Tuner supposed to work over the HDMI output connection ? I can get it to work from the RCA outputs, or when the HDMI Audio Out: AMP from the speakers connected to the receiver, but if I am switching HDMI Audio Out: TV, I cannot get the audio signal from radio to go through the HDMI output ...
bxconst is offline
post #7364 of 7368 Old 12-12-2016, 01:43 PM
jdsmoothie's Avatar
Liked: 5531
Nope. Only an HDMI source audio.
post #7365 of 7368 Old 12-12-2016, 02:05 PM
bxconst's Avatar
Thank you for the quick response !
bxconst is offline
post #7366 of 7368 Old 02-12-2017, 11:29 AM
Liked: 0
I've read through multiple pages of this thread and can't seem to find someone with the same issues--some mention handshake problems, etc, but it seems that this does not apply to me. I try and turn the receiver on last, but it seems that that's not the issue when switching sources.
Issue: when switching sources, namely Nexus Player (connected via HDMI) to TV Satellite Box (No HDMI, just Optical through Opt-1), i get skipping of the audio. Usually happens, no matter what the Broadcast is. The Tuner is a DirecTV Genie with Optical and Coax Out. (I just have HDMI connected directly to the TV).
Workaround: Switch inputs on the Denon Remote, wait a few seconds until is is done switching, then switch back to TV
Any suggestions, so i don't have to do the workaround and not have the sound skipping??
pmpntl529@yahoo.com is online now
post #7367 of 7368 Old Yesterday, 02:59 AM
jdsmoothie's Avatar
Liked: 5531
Have you tried connecting the Genie (HDMI) --> AVR instead of to the TV?
The HDMI handshake work around power on sequence is normally: TV, pause 5 seconds, AVR, pause 5 seconds, source.
To keep the current configuration ....
Have you tried the other optical input? What about replacing the optical cable? Perhaps try using a coax digital cable instead of optical (use a yellow composite video cable as a suitable substitute). If still no joy, replace the Genie.
post #7368 of 7368 Old Today, 10:56 PM
Liked: 0
Thanks for the response! I'd rather not hook up the HDMI to the TV, since I'd rather have more flexibility in using the TV sound w/o AVR w/o using HDMI Control. I recently turned off HDMI control since I had plenty of issues with an input signal with no sound.
I can try switching optical inputs and/or cables. If that doesn't work, i can try COAX input.
I did notice that even sometimes turning on the AVR and Genie directly to the input from an OFF state still has audio dropouts, unless i change inputs on the AVR, then change back to TV.
