Bottom Line - Yamaha RX-V665 or Onkyo TX-SR607 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-01-2009, 03:48 PM - Thread Starter
JaysonL's Avatar
I pairing with Orbs in a 5.1 setup. My room is 14x18. Thanks for input
JaysonL is offline
post #2 of 12 Old 07-01-2009, 03:49 PM - Thread Starter
JaysonL's Avatar
I will be using multiroom with another pair of Orbs.
Thanks again in advance for input.
JaysonL is offline
post #3 of 12 Old 07-01-2009, 04:16 PM
rdgrimes's Avatar
Quoted: 2017 Post(s)
Liked: 1351
It would be useful if you state what requirements you have. Based on what you have provided, any AVR with zone-2 capability will suffice. Be aware that zone-2 function requires 2-ch analog audio input from the source you intend to use.
rdgrimes is offline
post #4 of 12 Old 07-01-2009, 04:52 PM
SkiSmuggs's Avatar
I've had both Yamaha and Onkyo. I find Audyssey superior to YPAO for home theater.
SkiSmuggs is offline
post #5 of 12 Old 07-01-2009, 09:51 PM - Thread Starter
JaysonL's Avatar
my main requirements are a 5.1 receiver with HDMI switching (min 4 inputs) and analog video up conversion with multiroom for under $500. I also expect decoding of most flavors. Im not looking to break the bank with THX certified and my room is all set for 5.1 so 7.1 or 7.2 would be fine for the future but wouldn't be useful right now.
JaysonL is offline
post #6 of 12 Old 07-02-2009, 10:44 AM - Thread Starter
JaysonL's Avatar
I have an audio guy I trust steering me to the Yamaha but he does not own either of these receivers so I had hoped that someone in the know could give me some info.
Thanks again for your input
JaysonL is offline
post #7 of 12 Old 07-02-2009, 11:17 AM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
Just of out curiosity, what analog devices will you be connecting to this receiver?
Afro GT
afrogt is offline
post #8 of 12 Old 07-02-2009, 11:33 AM
tcfish19's Avatar
I have the Onkyo 607 and a Yamaha RX-Z7. For your application and budget go with the Onkyo. Only issue is it runs HOT!!! Sound is excellent for Movies. No reason to believe that any other receiver in the price range would sound any better.
I think Onkyo has the budget receiver nailed and there is no use fighting it right now.
Upgrayedd. Which he spells thusly, with two D's, as he says, "for a double dose of this pimping".
tcfish19 is offline
post #9 of 12 Old 07-02-2009, 11:36 AM
WilliamZX11's Avatar
Quoted: 25 Post(s)
From my experience with Onkyo and Yamaha, I would go with the Yamaha. I wouldn't even consider the Onkyo.
WilliamZX11 is offline
post #10 of 12 Old 07-02-2009, 11:52 AM
tcfish19's Avatar
Used to think that myself. Then I purchased one b/c I couldn't ignore the value for what you get and wasn't real thrilled with Yamaha's latest budget receivers. After 2 months living with the 607 I have zero complaints.
Time will tell as I've never had an issue with any of my Yamaha receivers and had some of those for 10yrs.
tcfish19 is offline
post #11 of 12 Old 07-02-2009, 12:03 PM
Marpenothi's Avatar
The two receivers are going to cost essentially the same. The Yamah will give you pre-outs (allows you to hook up your receiver to an external amp), but it sounds like you have no need for that. The Audyssey on the Onkyo is a very impressive technology, and I think it will drastically improve your audio experience. For the same price, and because you are not looking to upgrade to anything much more powerful in the future, I would go with the Onkyo.
Marpenothi is offline
post #12 of 12 Old 07-02-2009, 01:27 PM - Thread Starter
JaysonL's Avatar
I will have a Wii, a line level turntable and a CD player (that does not have digi out) and an apple airport
JaysonL is offline
