Denon AVR-4810CI/AVR-4810 w/ 9.3ch, Dolby PLIIz/Audyssey DSX, October 09- - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #3901 of 4077 Old 01-16-2012, 01:13 PM
semery74's Avatar
Does anyone know if there is a way to output hdmi video from 1 source to monitor1 and output a second hdmi source to monitor2 simultaneously?
semery74 is offline
post #3902 of 4077 Old 01-16-2012, 01:23 PM
jdsmoothie's Avatar
Quoted: 12376 Post(s)
Liked: 5650
Sorry, but no AVR can do that, rather you would need to add an external HDMI switch similar to the one below ...
jdsmoothie is online now
post #3903 of 4077 Old 01-16-2012, 01:51 PM
socojojo23's Avatar
Question about Denon Link: I have a Denon 3910 universal player which is DL3 and a Denon 4810 AVR which is DL4. Is the 4810 backwards compatible to the 3910 DL3?
socojojo23 is offline
post #3904 of 4077 Old 01-16-2012, 02:46 PM
batpig's Avatar
Quoted: 3585 Post(s)
Liked: 3429
Yes, the only difference is that DL4 also supports Blu-ray audio.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #3905 of 4077 Old 01-16-2012, 02:51 PM
semery74's Avatar
Thank you JD...Knew it was long shot considering the number of times I reviewed all the settings.
Has anyone come across dormant features in the 4810, like the networking feature in the 4806, that just require a key combination during power up?
semery74 is offline
post #3906 of 4077 Old 01-16-2012, 02:55 PM
socojojo23's Avatar
Thanks Batpig. You are very helpful and I have visited your web page and will be showing you my gratitude if you know what I mean. I thought I tried to set it up but could only get 2 channel audio and not Dolby 5.1. I will try again.
post #3907 of 4077 Old 01-16-2012, 03:48 PM
jdsmoothie's Avatar
Liked: 5650
Denon should be announcing the replacement for the 4810CI sometime later this summer.
post #3908 of 4077 Old 01-16-2012, 08:05 PM
Woof Woof's Avatar
Quoted: 164 Post(s)
Liked: 91
Wishlist for the 4813 (if rumors that the 58xx and A1xx are canned):
DTS Neo:X with support for 11.2 channels
Audyssey DSX with support for 11.2 channels
Audyssey LFC
Audyssey MultiEQ XT32 with CI/Pro support
along with currently supported features like DenonLink4 and DSD over HDMI/DL
And if they make a pre/pro version - Full XLR support
I'd love to see an XLR 5.1 input, XLR stereo input and XLR 11.2 output
Woof Woof is online now
post #3909 of 4077 Old 01-21-2012, 03:02 PM
Animal223's Avatar
I've noticed on my 4810 that when using the multi-channel stereo DSP setting, the surround speakers are significantly louder than the front left and right. I have done the Audyssey setup and for the standard surround modes (Dolby, DTS, etc) the balance seems fine. As I understand, multichannel stereo is supposed to be just like Stereo, with the L/R signals also going to the surround channels evenly.
Can anyone confirm for me this is how it should operate?
Animal223 is offline
post #3910 of 4077 Old 01-21-2012, 03:53 PM
batpig's Avatar
Liked: 3429
that is because of Dynamic and how it interacts (poorly) with Multich Stereo.
Multich Stereo does indeed feed the same stereo signal to the L/R surrounds, but the problem is that Dyn EQ is also BOOSTING the volume of the surrounds (that's one of the things it does) so the surrounds end up sounding louder than the fronts.
Setup Guide and FAQ
batpig is offline
post #3911 of 4077 Old 01-23-2012, 08:36 PM
Animal223's Avatar
Thanks Batpig! I turned off Dynamic EQ and the results were much better!
post #3912 of 4077 Old 01-29-2012, 02:17 PM
Mark Paquette's Avatar
Anyone know of a resource to determine a fair selling price for a 4810? I checked eBay and Audiogon, but didn't find any currently for sale.
Mark Paquette is offline
post #3913 of 4077 Old 01-29-2012, 03:05 PM
jdsmoothie's Avatar
Liked: 5650
Dakmart sells refurb units for $1730 with 1 year warranty.
http://www.dakmart.com/Receivers/c4_...duct_info.html
post #3914 of 4077 Old 01-29-2012, 08:20 PM
Thanks for the link. I'm thinking of selling mine but having a hard time determining what it should sell for. Surprised to see that there aren't many (any?) used ones available.
post #3915 of 4077 Old 01-30-2012, 06:01 AM
jdsmoothie's Avatar
Liked: 5650
Sure ... just providing you with a possible selling point. Although as it's a stellar AVR, most are generally not going to want to sell/upgrade especially as there are 3D work arounds.
Electronics Expo has an open box unit they're selling for $1849 with full 2 year warranty.
http://www.amazon.com/gp/offer-listi...condition=used
If the network card has already been replaced (or you purchased a replacement as a backup) you'll likely get a little more for it. Start it at $2000 on eBay or your local Craigslist and go from there.
post #3916 of 4077 Old 02-02-2012, 09:58 PM
thescienceman's Avatar
I'm hoping perhaps Batpig you can help me answer a few questions.
1. Why does the Denon 4810CI manual only mention speakers to 6ohm? Can I safely run ML's which are 4 ohm speakers?
2. I've got a pair of Martin Logan Theos on the way. Does bi-amping literally use two of my amps for each speaker, one for high's and one for lows; such that each speaker will be receiving 2x180w's?
3. If anyone is familiar with the Martin Logan (ML) Theos, that manual suggests against "active bi-amping" but it's ok for "passive bi-ampling". So, what the heck is passive bi-amping and two, is this ok to do with this recveiver? I've not heard anyone at AV stores say not too.
4. I'm confused as heck with what terminals to use from the receiver if indeed I can bi-amp the speakers.
Thanks in advance for any feedback/help you all can provide.
Grateful,
Dan
thescienceman is offline
post #3917 of 4077 Old 02-03-2012, 08:47 AM
jdsmoothie's Avatar
Liked: 5650
1. Yes. Although the AVR is only designed for 6Ω-16Ω speakers, you should be able to easily run 4Ω speakers at average level volume (-20db) without issue. If it shuts down as you approach 0db, then simply set the Volume Limit to -10db.
2. No. Passive bi-amping (feature used on AVRs) serves no real benefit, in either additional power or better audio fidelity. If you want more power to the ML, the get a 250W+ external amp and connect it to the 4810CI FL/FR preouts.
3. See #2.
4. See #2.
post #3918 of 4077 Old 02-03-2012, 05:15 PM
Thank you jdsmoothie.
I did some additional research today too and came to the conclusion that indeed i had to go with an external amp. I purchased the acurus A2005 amp.
http://www.acurusav.com/acurus%20product%20page.html
post #3919 of 4077 Old 02-13-2012, 09:43 AM
Woof Woof's Avatar
Quoted: 164 Post(s)
Liked: 91
Something weird happened on the smaller remote today.
The Zone4 LED was lit and stayed lit. Changing the Zone selection to other zones would light the other LEDs but the Z4 light stayed on. And eventually the LEDs on the other zones would power off. Leaving the Z4 LED to remain lit.
And obviously I couldn't use the remote to control the volume in my main zone as well.
Any help?
post #3920 of 4077 Old 02-13-2012, 11:01 AM
batpig's Avatar
Liked: 3429
did you try taking the batteries out for a few minutes to see if the remote will "reset" and clear out the gremlins?
Setup Guide and FAQ
batpig is offline
post #3921 of 4077 Old 02-13-2012, 07:25 PM
Woof Woof's Avatar
Quoted: 164 Post(s)
Liked: 91
I took it out for a few minutes but the Z4 light still came on. Have taken it out overnight.
Is it a low battery indication?
post #3922 of 4077 Old 02-14-2012, 11:24 AM
batpig's Avatar
Liked: 3429
sorry I'm at a loss! never seen that one before.... have you tried just replacing the batteries? seems easier than asking on the internet
Setup Guide and FAQ
batpig is offline
post #3923 of 4077 Old 02-15-2012, 08:50 AM
Woof Woof's Avatar
Quoted: 164 Post(s)
Liked: 91
I think the remote went into "program mode"
Not sure why. I put in the original batteries and now Z4 is off
But my remote no longer works (it's the wrong ID) because it's in default
I had to switch the remote ID to an alternate mode because my IR emitter from my 3D projector interfered with the remote.
post #3924 of 4077 Old 02-29-2012, 04:09 AM
danieljoseph's Avatar
For some strange reason, everytime I switch on the AVR or when a new disc is loaded or a change in the menu this message props up:
Dial.norm
Offsett -4db
What does this mean?
danieljoseph is offline
post #3925 of 4077 Old 02-29-2012, 06:20 AM
jdsmoothie's Avatar
Liked: 5650
This is the "Dialog Normalization" factor embedded in Dolby Digital tracks and therefore not something that can be adjusted (see p. 96 in your Owner's manual for more info).
post #3926 of 4077 Old 04-03-2012, 10:07 AM
CiaranAnthony's Avatar
Anyone interested in selling their AVR4810CI? Preferably someone in the north east, so I could pick it up and avoid shipping charges and risks.
CiaranAnthony is offline
post #3927 of 4077 Old 04-04-2012, 10:48 AM
HaleMoana's Avatar
My arm could be twisted. What were you thinking? Send me a pm. I live in the western burbs of Philly but I travel all throughout NJ and could possibly meet if it were to be convenient. Pm me with an offer. It's only about a year old. Maybe year and a half
Currently in the "Design" Phase of my new Theater build
He who buys cheap, buys twice
HaleMoana is offline
post #3928 of 4077 Old 04-08-2012, 08:41 PM
sfaprilbob's Avatar
Hi, I have my 4810 set up using Audyssey. I have the Mythos STS tower speakers as front speakers.How can I get more sound/treble out of these great speakers while still using Audyssey set to on?
I currently have EQ-on,Dynamic Volume-on,DSX-on.
sfaprilbob is offline
post #3929 of 4077 Old 04-09-2012, 04:22 AM
jdsmoothie's Avatar
Liked: 5650
Dyn Vol should really only be used for late night or TV viewing. Try setting it to OFF. Also, if you have a dedicated sub, set the front mains to SMALL with 60hz or 80hz crossovers.
post #3930 of 4077 Old 04-09-2012, 08:25 AM
SoundofMind's Avatar
Liked: 166
Originally Posted by sfaprilbob View Post
...How can I get more sound/treble out of these great speakers while still using Audyssey set to on?I currently have EQ-on,Dynamic Volume-on,DSX-on.Thanks.
In addition to jd's comment about turning DVol off, you can also try the Audyssey Flat curve (press the EQ button). It does not have the hi freq roll-off of the Std reference curve and thus sounds brighter.
Yes, I still like playing with Dalis.
SoundofMind is offline
Audyssey
