Denon AVR-4810CI/AVR-4810 w/ 9.3ch, Dolby PLIIz/Audyssey DSX, October 09- - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 4077 Old 07-03-2009, 06:35 AM - Thread Starter
Spizz's Avatar
Quoted: 206 Post(s)
Liked: 87
Since there is some info coming out on this Receiver I wanted to start a thread specifically for it.
On the Denon website-
http://usa.denon.com/ProductDetails/5118.asp
Owners Manual-
http://usa.denon.com/AVR-4810CI-OM-E_007.pdf
Specs-
AVR-4810 October $3,000
Next Generation 9.3 A/V Multi-Source/Zone, Network Streaming Receiver • All new DDSC-HD • Dolby TrueHD and DD+ • dts-HD Master Audio Audio decoding • Dolby PLIIz matrix decoding for Front Height effects • Audyssey DSX (Dynamic Surround Expansion) decoding for Front Height and/or Front Width channels • HDCD decoding • Features latest 32-bit Floating Analog Devices SHARC Processors • 9 channels equal power amplifier section, Multi Mono-block construction • 140 watts per channel (8 ohms, 20 – 20kHz, <0.05% THD) • Burr-Brown 24-bit, 192-kHz, PCM-1791A DACs on all 8 channels configured in differential mode • 3 Source/Zone capable, including 2 with video • 1080p Compatible HDMI 1.3a Deep Color (6/2) Repeaters, Dual outputs • Front Panel HDMI input • Fully assignable channels for biamping, Surround channels or Multi-Zone applications • Assignable +12v, 150mA triggers (2) • Assignable Ultra-Wideband (100 MHz) Component inputs (3) • Analog/HDMI Video to HDMI Scaling (1080p) featuring Anchor Bay Technologies processing (ABT-2010), with GUI overlay • Vertical Stretch for CinemaScope Screens • Digital to Analog conversion for Multi-Zone connection flexibility • Rear panel RS-232C and Ethernet ports for Crestron/AMX control communication • Ethernet port with built-in Multi-Media Command and Control functionality • Web Browser Control • Windows Vista Certified, and Windows 7 compatible • Dedicated iPod™ control port (for use with optional ASD-11R Dock, with on-screen display and remote control • DLNA Certified • Remote Access and Firmware Update/Upgrade via Internet • Internet Radio, Rhapsody and Napster • Audyssey MultEQ XT and Audyssey Pro Installer Ready, calibration microphone included • 4 Assignable digital inputs • Denon Link 4th, featuring Clock Control with HDMI • Front Panel USB Port • iPod Digital Direct USB Connectivity (Audio only) • AM/FM HD Radio tuner with auto preset FM memory (56 stations) • XM and Sirius Radio Ready • New GUI for Main Zone, with independent On Screen Display for Zone 2 • New EL learning/pre-programmed Remote Control • Detachable Power Cord • Serial IR ports • Second, Multi-Zone Remote included • Sleep Timer
- Like the new Look GUI to.
Shaping up to be another great Denon Receiver.
More info here-
http://www.avclubhouse.com/?p=1084&preview=true
Spizz is offline
post #2 of 4077 Old 07-03-2009, 09:43 AM
DreamCatcher's Avatar
Nice find........
Awesome looking receiver!
Could be the ONE..... for me
StayThristyMyFriends
DreamCatcher is offline
post #3 of 4077 Old 07-03-2009, 03:35 PM - Thread Starter
Spizz's Avatar
Quoted: 206 Post(s)
Liked: 87
Yeah I think this will be replacing my AVR-4308 that I use as a Preamp.
Spizz is offline
post #4 of 4077 Old 07-03-2009, 05:40 PM
Aphasia's Avatar
Why didnt you just pull the real specs straight from Denon's website. Its been up for a while now. Funny enough, the Denon website doesnt mention HDMI 1.4 and lists HDMI 1.3a though.
They added web-setup, 2 HDMI in, a dedicated ipod-port, and a Audyssey DSX and prologic IIz mode if you actually want to use extra speakers in the ceiling. Neither which i need. They switched from Faroudja to Anchor Bay for their deinterlacer and added a digital input jitter correction.
But they also took away WLAN, DAB-radio, an optical input and also lost some weight on the thing.
I'm glad the 4310 is out since it put the price of the 4308A down with 25%. And after looking over the differences on Denons website, it wasnt that much to think about. Especially since i needed something new now.
Aphasia is offline
post #5 of 4077 Old 07-03-2009, 05:57 PM - Thread Starter
Spizz's Avatar
Quoted: 206 Post(s)
Liked: 87
I don't see the AVR-4810 listed on the Denon US website. Got a link?
Spizz is offline
post #6 of 4077 Old 07-03-2009, 06:01 PM - Thread Starter
Spizz's Avatar
Quoted: 206 Post(s)
Liked: 87
Looking at your post again I think you may have gotten confused as this thead is about the AVR-4810 and not the AVR-4310.
Spizz is offline
post #7 of 4077 Old 07-04-2009, 10:50 AM
Aphasia's Avatar
DOH!!! My bad... and yes, thats totally what i did.
Although I could argue that the pricepoint and some of the features makes it the defacto replacement for the 4308, and since the pricepoint and placement on the Denon Website places the 4310 below the 4308 and your information the 4810 at MSRP $2999 that is plausible. But that is almost besides the point.
But another thing just hit me when you pointed out its yet another amp to come... The 4308A is rather close to the 4310CI from what i stated above... and there is differences to the 4810CI, but it makes it rather interresting of the differences between the 4810 and the 4310 is really worth an extra $1000.
Aphasia is offline
post #8 of 4077 Old 07-06-2009, 01:33 PM
Digitally challe's Avatar
Liked: 31
Spoke to Denon rep a little while ago about the 4810. I asked if, since they are upgrading the HDMI to version 1.4, will they also upgrade the USB to version 3.0. He told me no. I realize that the current specs are preliminary and tenative at best, so I will hold out hope that the USB will be version 3.0 so that I can future-proof my(hopefully) next receiver prchase.
Digitally challe is offline
post #9 of 4077 Old 07-10-2009, 10:22 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
Does it make sense to upgrade from the 4308ci to the 4810 if you already own the 4308ci? What does the 4810 do better?
kutlow is offline
post #10 of 4077 Old 07-16-2009, 12:07 PM
sterryo's Avatar
Scaling using ABT VRS - one of best available see OPPO blu-ray player for ABT advantages
Audyssey DSX with capability of have both wide and height speakers.
these two features alone make it worth the admission price IMO. It will be an upgrade from the 3808ci for me.....
sterryo is offline
post #11 of 4077 Old 07-16-2009, 07:30 PM
krik's Avatar
No THX?
krik is offline
post #12 of 4077 Old 07-17-2009, 01:17 AM
toolwarrior's Avatar
Originally Posted by krik View Post
No THX?
I agree. Denon's continued omission of THX certification and modes is a mystery in this price range.
toolwarrior is offline
post #13 of 4077 Old 07-17-2009, 06:53 AM
Speedy_80's Avatar
Is that the 4806 succesor? I don't think so ... we must wait for the picture of the inside.
Speedy_80 is offline
post #14 of 4077 Old 07-17-2009, 09:52 AM
Srgtfury's Avatar
Des anyone know if this is available in China yet? If I were to purchase there, what is the fee structure to bring it back to USA, if even possible and is there a way to get warranty service stateside?
Thank you very much
Fury
Srgtfury is offline
post #15 of 4077 Old 07-19-2009, 06:39 PM
sfaprilbob's Avatar
Has anyone heard yet what the quality or what kind of amps will be in the 4810 reciever? Thanks.
sfaprilbob is offline
post #16 of 4077 Old 07-19-2009, 07:31 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4008 Post(s)
Liked: 4068
What I do know ( from 2009 AVR spec sheet ) is the 4810 has 9 seperate amps, and the same 24 - bit / 192 - KHz DAC's as the 4310.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #17 of 4077 Old 07-23-2009, 03:50 AM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 37
Don't bother - at 480mbps, usb 2.0 is fast enough to handle way more than 5x the absolutely highest possible audio bitrates. Maximum bitrate for bluray, including the video, is 36mbps. Without some, as yet uninvented, use for all that bandwidth, merely having usb 3.0 on a receiver won't do a thing for you.
Copyright is not property, it is merely a temporary loan from the public domain.
JerryW is offline
post #18 of 4077 Old 07-27-2009, 06:16 PM
jek88's Avatar
Only somewhat related but...
http://www.engadgethd.com/2009/07/27...t-month-42-fo/
These are the first hdmi 1.4 cables ive seen although only in Japan right now.
jek88 is offline
post #19 of 4077 Old 07-28-2009, 08:45 AM
Ugly1's Avatar
LOL!
Frickr Online Photo Service
I can only imagine! hahaha
Ugly1 is offline
post #20 of 4077 Old 07-28-2009, 09:36 AM
fgutterman's Avatar
How does the avr-4810ci support hdmi 1.4 using the ABT-2010?
The ABT-2010 only handles up to 1080p.
fgutterman is offline
post #21 of 4077 Old 07-28-2009, 09:41 AM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
It could still pass it. Hopefully the 4810 will pass any 1080p signal through it without touching, so anything larger that 1080p should pass right through also.
My guess is that to get certified to handle 1.4 doesn't take much more than 1.3 and they are just doing this to make the 4810 look future proof. Of course until there's some more 1.4 devices out there to test against it'll be hard to determine what 1.4 compatibility actually means.
Keith Mickunas is offline
post #22 of 4077 Old 07-28-2009, 10:45 PM
fteixeira's Avatar
Anyone know if the 4810 has enough horsepower to apply Audyssey to Dolby TrueHD and dts-HD Master Audio? This is lacking in today's processors / receivers.
fteixeira
fteixeira is offline
post #23 of 4077 Old 07-29-2009, 06:30 AM
maxl's Avatar
Quoted: 38 Post(s)
fteixeira
Are you saying that none of today's AMP can apply audyssey to DTS-HD MA? Or just denons? This is disturbing.
maxl is offline
post #24 of 4077 Old 07-29-2009, 06:41 AM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
Most can. A few cannot.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #25 of 4077 Old 07-29-2009, 06:52 AM
Quoted: 104 Post(s)
Liked: 81
What Audyssey functions can't be applied? I would hope that MultEQ is applied on them, otherwise I would think most people would rather use the lossless formats. How can you tell which receivers have these limitations?
post #26 of 4077 Old 07-29-2009, 09:02 AM
angorwatts's Avatar
One of the main implementations of 1.4 that I heard on a podcast from two of the main guys at HDMI, is that 1.4 is internet capable component, and if one component in a chain of 1.4 devices has access to the internet than all of them do, through the HDMI. That is one of the current main selling points that can actually be realized vs. 4k rez.
angorwatts is offline
post #27 of 4077 Old 07-29-2009, 09:53 AM
angorwatts's Avatar
This is from home theater review. In reference to hdmi 1.4 info:
Now your even your home network isn't safe from HDMI's unreliable, copy protected connection nightmares. Silicon Image, Inc. today introduced the SiI9387 port processor and the SiI9334 transmitter, the first semiconductor products to incorporate the latest HDMI 1.4 specification features for digital television (DTV) and home theatre applications. The new devices offer a richer, more interactive HDMI entertainment experience by enabling new connectivity applications via Ethernet, such as Silicon Image's LiquidHD technology. The SiI9387 port processor and the SiI9334 transmitter support the following HDMI 1.4 specification features: HDMI Ethernet Channel
Devices using these chips will be able to transmit and receive full duplex data at 100Mb/sec over an HDMI cable. Audio Return Channel
Drives a high quality S/PDIF signal through a single HDMI cable, simplifying connectivity in the home theatre.
post #28 of 4077 Old 08-07-2009, 12:13 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
any updates
Brian-HD is offline
post #29 of 4077 Old 08-07-2009, 12:25 PM
MarkB's Avatar
Originally Posted by Brian-HD View Post
any updates
Not much. There is this site in the UK who say that details are still very sketchy and the cost is £2,799.95 (top whack £), and I found this one in the US quoting $2,999.00 (top whack US$, I assume).
I assume also that the (£1899.00) BDP-4010UD would be released at the same time – seems a killer combination IMO.
MarkB is offline
post #30 of 4077 Old 08-08-2009, 04:45 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
Mark,
Blu ray player in the pic
Brian-HD is offline
Audyssey
