How the hell does HDMI's "Auto Lip Sync" work? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Bob Pariseau
post #1 of 15 Old 07-07-2009, 01:03 AM - Thread Starter
Ghostman84's Avatar
I keep reading how HDMI 1.3b and 1.3c support "auto lip sync correction". I purchased two HDMI 1.3c cables hoping to correct the lip sync issue between my amp and Blu Ray player. It didn't seem to help, but then I set both the receiver and the player at a 30ms delay and everything seemed pretty much in sync. Is this how it works?
Ghostman84 is offline
post #2 of 15 Old 07-07-2009, 03:13 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Good question.
I can't give the full answer, I am sorry to say. I believe, at minimum, the TV would need to support HDMI lip sync. Some device has to correct for the problem, and it's not clear to me whether this is the receiver or player - and whether it matters whether the receiver is doing the audio decoding.
Something to know is that HDMI features are often optional, so HDMI 1.3 does not guarantee the feature.
Some info is here -
http://www.abccables.com/info-lip-sync.html
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 15 Old 07-07-2009, 08:02 AM
TomBonge's Avatar
The display device takes some amount of time to scale, create frames for 120hz, etc. This time is sent back to the AVR and it delays the audio by the same amount. Both the display and the AVR need to support the feature, its not enough to just buy a cable or that the display or AVR are 1.3. HDMI 1.3 does not mean the device supports all features.
TomBonge is offline
post #4 of 15 Old 07-07-2009, 08:31 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2248 Post(s)
Liked: 2818
This is an OPTIONAL feature of HDMI V1.3. Not all HDMI V1.3 devices will support it. It is something that has been way over-hyped.
The way it works is that an earlier device, which handles audio, can inquire of a later device, which DOESN'T handle audio, how much video delay the later device believes it is adding. The earlier device can then also delay the audio that much. Typically the later device is a TV and the earlier device is an Audio Video Receiver (AVR). The expectation is that the AVR is processing the audio, but NOT the video and so can't know how much video delay is being introduced except by asking.
The amount of video delay added by pretty much any TVs is a constant regardless of your settings in the TV or what you are watching. In fact the info returned by the TV when the AVR inquires is almost certainly a fixed number that's just built into its HDMI data block -- without regard to any settings you might have made in the TV. Which means you'd get just as good a result by MANUALLY setting the proper delay in your AVR -- using the simple test found on many calibration DVDs.
The real problem with this "automatic" adjustment is that it does NOT help if some even EARLIER device is screwing up, or if there is an error in the content to begin with. And in reality, these are the bulk of the problems people actually see as lip sync errors.
For example, some cable/satellite providers have been known to send out signals where the video is actually AHEAD of the audio -- i.e., as if they already applied too much audio delay before the signal was sent out. Adding additional audio delay just makes things worse. And there is no mechanism to add VIDEO delay so you are stuck.
In your case the problem appears to be a BUG in your disc player that is generating 60ms of uncorrected video delay. This should not be happening. The player SHOULD be sending out audio and video in sync for all the different types of discs it plays and for all settings.
Again, this is almost certainly a bug in the player. It is almost certainly NOT due to video delay being added by your receiver or TV. So even HDMI V1.3 doesn't anticipate that "automatic" lip-sync correction would handle it. In addition, I don't believe there are ANY HDMI V1.3 players out there which actually implement "automatic" correction -- which would require them to get video delay values from both the receiver and the TV and then add audio delay to their disc playback. This "automatic" stuff, if you find it at all, is almost certainly only going to do anything in AVRs.
And your AVR can't "automatically" correct the problem in the player because there is no way to inquire of an earlier device how much it is screwing things up. And since it's a bug in the player, even if there WAS a way to get that data, the player would probably just provide an incorrect answer!
Anyway, you appear to have a 60ms bug in your player. It happens. You are fixing that by adding 30ms delay in the player and an additional 30ms delay in your AVR. That's fine as a workaround SO LONG AS that delay value you have put into your AVR doesn't screw up any OTHER sources you are playing through that AVR, such as your cable/satellite TV.
Also keep in mind that some discs already have screwed up lip sync in the contents coming off the disc. There is no way to automatically correct for that. You have to make MANUAL adjustments disc by disc or just live with the problem on the faulty discs. To test what's really going on in your player you need to use a disc that doesn't have any such problem -- typically a calibration DVD.
The worst case is when the lip sync varies as you play the disc. This too is often due to a bug in the player. Error builds up and gets worse as you continue playing the disc. Often, pausing the disc or a brief reverse will cure the problem -- for a while.
If you conclude your player really is causing this delay, then check for a firmware update for your player.
--Bob
sv33688 likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #5 of 15 Old 07-07-2009, 08:06 PM - Thread Starter
Ghostman84's Avatar
Thanks so much. That's all really helpful stuff. I think the 60ms bug may be right because when I watch Blus at 60fps they seem pretty in-sync. it's only when i'm watching at 24fps that I have any noticeable sync issues. I called Sony's tech support (I have A BDP-S350 player) and they said they had never heard of that problem....then proceeded to show me where the A/V Sync adjustment was when a mere two minutes before I told him that I had already adjusted to 30ms delay. Alot of help there. He also suggested I keep the audio output set at 48mhz instead of 98mhz. To my understanding most blu-rays don't even feature 98mhz sound....would that really make a difference?
post #6 of 15 Old 04-22-2011, 11:32 AM
Mpray1983's Avatar
Hey guys I'm a relative newby When it comes to this. This is probably my 3rd system buy I consider it my first. I have a samsung un55c8000. Integra dtr 40.2. Bdc6900. Sib xl lcr, sib for Surround and a cub 2 sub all made by focal. Xbox 360 s 250gb and a comcast cable box. I am running everything into receiver thru hdmi except the Xbox to avoid game lag which goes to the tv hdmi and optical to the receiver. My 1st problem is lip sync. Every input is off and I am forced to use the manual av sync to correct it. I would think since all these devices are less than a year old and hdmi 1.4 compliant that I wouldn't have to do this and it would happen automatically. Cable is off about 40 ms and blu rays seem to vary. For instance older movies like the departed had to be cranked up to 250 ms. Tron legacy seemed to be fine. Why are my devices not speaking to each other? My second problem is I was hoping for some heavy bass. I realize only 1 8" inch downward firing sub isn't optimal but it doesn't rumble like it should. I have audyssey multeq set up and have even turned the sub trim level up 2 db after. Should I look into buying another cub 2 to match or I was looking at an hsu 15 inch sub so I can get lower than 40 hz. Any help would be much appreciated. Thanks.
Mpray1983 is offline
post #7 of 15 Old 04-22-2011, 12:27 PM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
We have found in many instances the amount of audio delay depends heavily on the source and its A/V stream. Frequently when a HD program is relayed it goes through various uplinks/downlinks which can create latency especially for the HD video.. And it can/will vary significantly between channels and sources..
So be prepared to tweak it as required as 1 setting is not universal..
Just my $0.02...
M Code is offline
post #8 of 15 Old 04-22-2011, 12:29 PM
Mpray1983's Avatar
It makes me think that auto lip sync is a False claim
post #9 of 15 Old 05-25-2014, 02:01 PM
nexsen's Avatar
"Automatic lip-sync correction (TM)" Note the Trade Mark! Trade Marks do not have to be "true". "World's Finest Chocolare (TM)" could be the world's finest chocolate but they don't have to prove it since it is a trade mark.
The way the feature is supposed to work - if a TV (sink) supports it - is that the TV during the EDID session (like plug and play for computers) will pass 2 video latency values to the source (AV Receiver). One for progressive and one for interlaced video. It should also pass 2 audio latency values if there is any audio delay already added. The AVR is supposed to subtract the audio latency from video latency for the format being passed (progressive for example) and delay the audio by that difference. So, what Bob said above is 100% correct.
If it worked perfectly as intended it would rarely result in perfect lip-sync since most content is off before the TV gets it.
But the vast majority of TV's I've had do not support it AT ALL. They don't pass any latency values! A Samsung Un55 8000 series was mentioned above. I have the 60" Series 8000 which I feel sure is almost identical and it does NOT supply any latency values. Neither do my 32" Samsungs or my Vizio's. I have an older Toshiba which "does" - so it isn't a matter of whether they are NEW or not. The Toshiba supplies 100 ms for progressive and 116 ms for interlaced but it also supplies identical audio latency values so the net is zero. An AVR receiving those values would not apply any added audio delay because the Toshiba is already delaying the audio. While that "sounds" like a good thing - Toshiba delaying the audio equal to what it thinks the video delay is - it definitely is NOT because Toshiba (on that model) does not allow the user to control that audio delay. It is fixed and can't be turned off (unless via a service menu given only to authorized techs since an error can render the TV irrepairable). It's a bad thing for a manufacturer to do and at least Samsung and Vizio (on the models I have) allow the user to control the delay to their speakers even though they don't support "auto correction". I turn all audio delays OFF on all my equipment and let a dedicated lip-sync correction box solve the problem,
Bob mentioned cases where the audio is already delayed too much (I've even seen DVD's like that) and in those cases you can often correct lip-sync by lowering the audio delay you are adding below what's needed to offset the TV's video delay. In that way you can use the TV's inherent video delay to offset the audio delay. As long as the audio delay in the source signal isn't greater than the TV's video you can. When I encounter arriving audio delay I simply lower the delay (on my Felston DD740) until it's perfect and so far I've never seen arriving audio delay above my TV's video delay. So I can correct up to 100 ms arriving audio delay as well as up to 680 ms video delay regardless of where it comes from. But back when I watched that Toshiba I could not do that since Toshiba had a fixed 100/116 ms delay applied to its speakers. I couldn't correct arriving audio delay at all. Luckily there is usually additional video delay - not audio - in the arriving signals so I am usually adding more audio delay.
nexsen is offline
post #10 of 15 Old 03-03-2015, 12:33 PM
shae's Avatar
Quoted: 72 Post(s)
What are the new HDMI 2.0 lip sync features? I can't find detailed info, and the little that I did found seems wrong compared with the HDMI 1.3a specs available online.
shae is offline
post #11 of 15 Old 09-02-2015, 11:02 AM
nexsen's Avatar
HDMI 2.0 lip-sync changes
Sorry, I didn't see your question until now.
The HDMI 2.0 specification adds another "optional" lip-sync correction feature to overcome deficiencies in the 1.3a automatic lip-sync correction scheme. As mentioned earlier the 1.3a - 1.4 scheme only allows the TV (sink) to tell the source (AVR for example) two fixed audio delays needed to offset interlaced or non-interlaced (progressive) video. Since almost everything is progressive today you might as well say "one fixed audio delay" will always be passed during the EDID session at start-up or after a hot-sync. That is, "if" the TV supports the auto lip-sync correction feature which has always been optional and most major brands ( Samsung and Vizio for example) don't support it.
The big problem with that scheme is that video processing delays vary due to resolution and frame rate differences and not just interlaced status. The current scheme ignores those differences which can cause delays almost as large as interlace status.
HDMI 2.0's new "dynamic" lip-sync correction feature would allow (if any TV manufacturer supports it) the TV to send latency values any time it wanted to and not just during the EDID session. I understand it will use the CEC communication channell normally intended for remote control signals so a TV "could theoretically send" a different delay request for every combination of resolution, frame rate and interlace status. The operative word there is "theoretically" since it is hard to imagine manufacturers who don't even support the current 1.3 - 1.4 two value scheme doing that. Of course the AVR needed to provide the delay will also have to be HDMI 2.0 "and" choose to support the new "optional" dynamic scheme.
And of course all of this "auto" correction stuff can do is offset the TV's video delay. I find lip-sync error in the signals "before" the TV gets them (which changes between programs) to be the largest problem and the only way to correct that is through manual adjustment while viewing that particular content. My DD740 allows me to do that at the press of a button as I watch and of course that corrects all lip-sync error no mater where it comes from. That's what the TV manufacturers should focus on - put a delay like the Felston that adjusts in at least one ms increments without menus overlaying the screen - "inside the TV" and give up on auto correction in my opinion. External devices like my Felston DD740 and the Alchemy2 and Primare delay boxes all do this (adjust in 1 ms steps) without disturbing the image of the lips you are trying to sync the sound with but many TV's and Av receivers that offer a delay defeat its utility by plastering menus over the screen and incrementing the delay in huge steps (like 10 or 20 ms) and not having enough total delay to offset the video delay in HD sets. Some 4K TV's need over 225 ms and I've seen Av receivers with as little as 80 ms total delay. You need at least 340 ms to be safe in my opinion.
nexsen is offline
post #12 of 15 Old 09-03-2015, 01:12 PM
shae's Avatar
Quoted: 72 Post(s)
Originally Posted by nexsen View Post
It would definitely be nice if HDMI devices (TVs, receivers...) reported their latency every time a setting change affected latency. But yeah, even doing it properly in initial EDID report would be progress, it seems.
It's been a while since I read the sync parts in the HDMI spec. Is it still called "lip sync" instead of just A/V sync?
shae is offline
post #13 of 15 Old 09-03-2015, 02:01 PM
nexsen's Avatar
I don't have access to the actual spec but all references to it I've seen refer to the new enhanced feature as "dynamic auto lip-sync correction". One of the main problems is A/V sync doesn't seem to be important to these manufacturers. They probably don't even "know" what their video processing delay is for each format (each combination of resolution, frame rate and interlace status). And the problem with these optional specs is that you never know what your manufacturer has chosen to do until after you've bought the TV. Try finding out "before" you buy whether a TV supports the current auto correction scheme. And when the new 2.0 feature is out a manufacturere could support it but only send new delay values for changes in interlaced status (as done now in EDID) and totally ignore latency changes due to different frame rates and resolutions. As far as I know there's nothing in the spec directly addressing "when' the TV should send latency changes". They could claim to support this feature and only send the same two values in the current scheme and since progressive formats are almost universal we're talking about "one" latency value being sent by CEC instead of EDID. What I'm saying is that there might be no difference at all if the manufacturers don't take it upon themselves to send multiple latency values when formats change.
nexsen is offline
post #14 of 15 Old 09-09-2015, 11:31 AM
shae's Avatar
Quoted: 72 Post(s)
Without the specs it's difficult to know how it's supposed to work.
It would be trivial for a manufacturer to measure the latency in all modes.
The problem of knowing the technical specs of a TV is true not only in this, but many or most technical aspects. Without good reviews it's impossible to know anything, and sadly even good reviews are missing details.
shae is offline
post #15 of 15 Old 09-09-2015, 01:36 PM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
Considering that 85% of the HDMI AV components are not certified through a central validation testing lab each brand/product can/will work differently..
No wonder features such as CEC & ARC are so incompatible...
Not even counting the multiple HDMI handshake issues..
Just my $0.02....
M Code is offline
