** OFFICIAL ** Denon AVR-3310CI/990 Owner's Thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
Old 06-27-2010, 09:33 AM
madmatrix's Avatar
I'm debating whether to get 3310ci or 3311ci. Is there any big difference between them besides 3D/HDMI1.4a? Sound quality?
The price I saw, the best for 3310ci is $650 from Amazon golden box. The price for 3311ci will have $250 more than this price. I need justify it's worthy or not.
Thanks for your input.
Lou
madmatrix is offline
Old 06-27-2010, 11:01 AM
ice7's Avatar
Im connecting my 3310 to my Pansonic 65V10 and my 60gb fat PS3 via HDMI throughout. The issue I am having is the video displayed on the tv comes in and out intermittenly, however, the sound does not cut off. Any help on this? I have tried 3 HDMI cables and all have the same effect of video popping in and out and sound still playing. Playing XBOX360 and watching cable (all connected to 3310 via HDMI) does not have this problem. Is there a setting on the PS3 or 3310 I need to turn off or on? I have both latest updates for the two.
ice7 is offline
Old 06-27-2010, 11:09 AM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
it's not a setting issue, that's an HDMI issue. Try plugging the PS3 into a different HDMI input on the Denon (HDMI 1 and 2 are somehow different than the other inputs and may work). Also double and triple check cabling, swap cables, make sure the connections are solid, etc...
also try unplugging and power cycling all components (e.g. turn them full off for a few minutes) as sometimes giving the full HDMI chain a fresh "handshake" can clear things up.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 06-27-2010, 11:57 AM
ice7's Avatar
Thanks batpig for the feedback. I have tried the other HDMI inputs on the Denon with different cables but again same issue with the video signal popping in and out.
For whatever its worth I am using the Harmony 1100 to turn on/off my components. I never had an issue with this until recently. Just only the PS3. Im thinking maybe the ps3 has gone bad.
ice7 is offline
Old 06-27-2010, 12:03 PM
jdsmoothie's Avatar
Quoted: 12105 Post(s)
Liked: 5508
Do you get the same result if you connect the PS3 directly to the Panny? I haven't looked into the new settings, but I know the PS3 has been updated to play 3D PS3 games. Make sure that you have the correct video setting on the PS3.
jdsmoothie is offline
Old 06-27-2010, 12:05 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi ice7, maybe do a hard reset on the PS3.
JChin is offline
Old 06-27-2010, 12:10 PM
jdsmoothie's Avatar
Liked: 5508
Lou
Same post asked and answered in the 3311 thread.
Old 06-27-2010, 12:39 PM
ice7's Avatar
Yes I have tried connecting the PS3 directly to the panny and video and audio signal is fine. So that rules the ps3 being bad. Anyway going couple firmware updates back? Never had the issue until updated the latest firmware.
ice7 is offline
Old 06-27-2010, 01:11 PM
madmatrix's Avatar
Yes, hehe. Thanks jdsmoothie.
Old 06-27-2010, 04:59 PM
ArtVandalay7's Avatar
Is there a known compatibility issue between the Denon 3310CI and Sony rear-projection TV SXRD 50a2000? I had to swap out my Panasonic plasma temporarily for a service issue and I can't get a picture on the Sony using the same HDMI out line from the receiver. Nothing else has changed...I get audio from all the components but nothing shows up on the TV...when I get to the input where the HDMI cable is (tried them both), the audio hiccups temporarily...is there a handshake issue or something? Has just the HDMI out jack gone bad (seems unlikely, I also swapped out the HDMI cables with no fix)...Help please!!!
ArtVandalay7 is offline
Old 06-27-2010, 06:24 PM
luckydog2006's Avatar
Help needed on A/B Speakers and/or Zone 2 setup...
This is how I would like the setup to be:
Main 5.1 setup to be Zone1 and second room with 2 speakers as Zone2. Zone2 can be
independent from Zone1 for the source. I have a AVR-990 which supports multizone. I'm assuming that the receiver can control the volume in Zone 2.
My speakers are wired for 5.1 (using the FR, C, FL, SR, SL) plus the second room is wired to the surround back right/left connectors on the AV receiver. Is this the correct setup? The only connectors not used are the B front speakers on the receiver.
I did the B front speakers before but I don't understand how Audyssey auto-configures the Zone or B front speakers. So, after reading that to have different sources, I think I need to have the Zone2 speaker wiring wired to the surround back right/left connectors on the AV receiver. So, that's what I did above, is this correct?
luckydog2006 is offline
Old 06-27-2010, 08:07 PM
jdsmoothie's Avatar
Liked: 5508
Correct. Keep in mind that only analog sources can be sent to Zone 2 so you'll need to connect an RCA cable as well from each of the digital (HDMI, optical, coax) sources you have connected. Audyssey doesn't do anything with the Zone 2 speakers and will only set the Front "B" speakers if you're using them at the same time as the Front "A" speakers (which usually isn't the case).
Old 06-27-2010, 08:38 PM
quattroatl's Avatar
Liked: 29
When my Blu-ray player is set to bistream I am having lip sync issues with HD audio. Things are perfect when set to PCM. Is this normal? The audio quality seems more dynamic when set to bitstream.
quattroatl is offline
Old 06-27-2010, 08:42 PM
jdsmoothie's Avatar
Liked: 5508
Bitstreamed audio is maybe 3db "louder" ... nothing more.
Old 06-27-2010, 10:36 PM
abc5's Avatar
Originally Posted by PCTools View Post
FearNoBruskies,
Good job with scoring a deal at Monprice. I just picked up some of the 24AWG HDMI Cables for $5.99 (6-Ft), and I am impressed. Kinda tells you how much Monster is pocketing on their stuff.
I am getting addicted to listening to the Internet Radio features. I have my favorites stations identified and enjoy the 256Kb download music. (Have to search for those). With all of this, who wants to listen to HD Radio?
I think HD Radio will fall on its nose. With Class B stations only allowed 500 Watts, the dispersion of these signals is poor and requires high gain antennas if you are outside the city limits.
do you like the UI for the HD Radio on the Denon or does it seem clunky at all?
abc5 is offline
Old 06-28-2010, 02:31 AM
peare's Avatar
I would exchange it, sounds like you have already done thorough troubleshooting...
Thanx batpig. It appears that there is an interference coming from the network card. I had read in this thread that there were issues in the early models with bad network cards. I wonder can mine also be one of these. When I turn it on I noticed that the noise starts as soon as it tries to connect my network, then it disappears or becomes unnoticeable (for most of the time) after a while.
peare is offline
Old 06-28-2010, 07:27 AM
jdsmoothie's Avatar
Liked: 5508
If the serial number of your 3310 begins with a "9XX", "001", or "002" it could have a bad network card. AFAIK, only those beginning with "003" or higher have the newer cards installed.
Old 06-28-2010, 11:31 AM
peare's Avatar
Thanx a lot it is 9103304288. I suppose it is the network card. Still working but interfering front left channel
peare is offline
Old 06-28-2010, 02:22 PM
Av!Pro's Avatar
Denon 3310 comes with a smaller second remote. Anyone had luck operating it from another room? I cannot - it probably needs some setup or an accessory.
Appreciate any feedback ..
Av!Pro is offline
Old 06-28-2010, 03:09 PM
batpig's Avatar
Liked: 3415
ummm.. it's infrared, it will not work in another room as IR is "line of sight" only!
in order to use it from another room, you will need to either hard-wire an IR extender (with a little infrared sensor in the 2nd room, and a wire physically running to the Denon), or get an RF (radio freq) solution (where the IR signal will be converted to RF, sent to the other RF receiver in the main room, and then converted back to IR to control the Denon).
Setup Guide and FAQ
batpig is offline
Old 06-28-2010, 03:35 PM
Av!Pro's Avatar
Thanks Batpig for your prompt response, this is what I feared. The manual says u can use it from another room so I thought it might work.
Av!Pro is offline
Old 06-28-2010, 06:29 PM
Acesn8s's Avatar
First time here so excuse my ignorance, please.
I have the ability to acquire a 3310 as a virtual throw-in with a speaker package. I know that the 2310 had HDMI problems with the OPPO BDP-80 that were solved by a firmware upgrade. Are/were there similar issues with the higher end Denon and if so, were they solved?
Michael
Acesn8s is offline
Old 06-28-2010, 08:59 PM
Plex's Avatar
Ok, I did it, I ordered the 3310 from electronis-expo and got it for a nice price [with coupon] and was told they offer a 14 day price coverage if it drops more than $10. Hoping the 4th will bring a price drop. I also hope my serial # is of the 003 class or at least one with no problems. I was minutes away from getting the 807 even with the power issue but came to find out that speaker level adjustment was a real hassel, I could not adjust each channels level on the fly, so that was the final straw, 807 out 3310 in.
Audyssey setup guide
Plex is offline
Old 06-28-2010, 09:15 PM
andrewdoan's Avatar
Thank you for the info. My new replacement 3310 ci has serial number starts with 0033....So I am safe for now. HD radio sounds real clean and no Helicopter noise for now.
Hat off to folks at 6TH ave electronics for the no hassel exchange and the pre-paid UPS label. That's what I call first class customer service.
andrewdoan is offline
Old 06-29-2010, 08:26 AM
tboo's Avatar
Is anybody else who is using their 3310/990 as a pre/pro having lip sync problems? I seem to be having it & its most noticable when watching BDs.
tboo is offline
Old 06-29-2010, 08:46 AM
quattroatl's Avatar
Liked: 29
When BD player is set to bitstream, I have lip sync issues with some discs. So the BDP is now set to PCM.
Certain movie channels on my Directv have to be set to 200ms audio delay.
Overall, I am still satisfied that I can fix any issues that have cropped up thus far.
Old 06-29-2010, 03:12 PM
jdsmoothie's Avatar
Liked: 5508
Michael
The 2010 models all had the same issue which was resolved with a firmware update.
Old 06-29-2010, 03:16 PM
jdsmoothie's Avatar
Liked: 5508
DirecTV lip sync issues can often be resolved without adjusting the Audio Delay setting:
(1) Changing to another channel and then back to the original channel
(2) Backing up the video about 5 minutes and then fast forwarding to the current time.
Old 06-29-2010, 03:50 PM
Acesn8s's Avatar
Sorry I wasn't clear. Did the 3310 have the same problem as the 2310? And if so, was there a firmware fix?
Acesn8s is offline
Old 06-29-2010, 03:53 PM
batpig's Avatar
Liked: 3415
you were clear... and so was JD. what part of "all" don't you understand
Setup Guide and FAQ
batpig is offline
