** OFFICIAL ** Denon AVR-3310CI/990 Owner's Thread - Page 72 - AVS Forum | Home Theater Discussions And Reviews
Old 08-05-2010, 03:06 PM
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Originally Posted by Plex View Post
OK, which is better and why?
1. Run wires from AVR to outside speakers ~ 100-150' away across the yard?
2. Run RCA from pre-out to another amp ~75' away, then go to the speakers?
since your question really has nothing to do with the 3310 specifically, why not post your question as a general thread in the AVR forum? You will get a much wider audience and probably are more likely to find someone who has the specific knowledge to advise you in this situation.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 08-05-2010, 09:02 PM
Plex's Avatar
Well, it does have to do with the 3310 which these connections will be hooked up to. I had posted this question on the last page but it was not answered directly, so i modifiied it on this repost. I should have include that the 3310 was the source AVR.
I'll give this a chance to run a few days if no responce I'll do as you suggested and post a general thread question.
Audyssey setup guide
Plex is offline
Old 08-06-2010, 07:22 AM
feathermerchant's Avatar
I would not recommend 1 or 2 where I live because it would be difficult to protect against lightning, etc unless buried.
If you do 2 it will offer som eprotection to your AVR. Any reason you cannot go RF?
feathermerchant is offline
Old 08-06-2010, 10:32 AM
batpig's Avatar
Liked: 3415
It really doesn't. It's a generic question about hooking up outdoor speakers and whether a super-long speaker wire run would be better/worse than a long RCA run. The specific brand or model of AVR you are hooking up to is not really relevant. The answer would be the same whether you were using the Denon 2310, 3808, 4310, 1910, or even any similar 7.1 Onkyo, Yamaha, etc. ... so why limit the audience of people who could help you?
I am aware -- that is specifically why I suggested you post a general thread, because I could see that you were going to have trouble getting a specific response given that you are limiting your audience to only people reading this particular thread.
Really, I'm trying to be helpful I would love to provide you with an answer but it's really outside the scope of my expertise.
My suspicion is that you will be perfectly fine with speaker wire -- just make sure to get outdoor-rated burial grade low voltage wire. http://www.parts-express.com/pe/show...ource=googleps
Setup Guide and FAQ
batpig is offline
Old 08-06-2010, 02:31 PM
Plex's Avatar
Ok, thanks for your input, I'll post a thread in the general area and see what shakes out there
Plex is offline
Old 08-06-2010, 02:35 PM
Plex's Avatar
Not sure what you mean by RF, RF to the other AVR or the speakers? RF to another AVR would be great if it doesn't break the bank.
Plex is offline
Old 08-06-2010, 06:21 PM
tullnd's Avatar
Originally Posted by mariob33 View Post
New fw downloaded today took about 5 minutes didnt require a reset..
So I just downloaded it. Walked away and came back after about 15 mins.
I'm ethernet connected to a 20Mb fiber connection.
Display reads:
Ether SBL 01min
Update Check OK
But it's been sitting there for about another 10 mins without changing.
edit - so I waited almost an hour, no change.
I did a power off. Rebooted, seems like it's basically working fine. Network shows it still pulling an IP and is pingable. I have it set for a static address.
When I tried to update hte firmware again, it just sat there looking for an update and finally went off that screen. I tried to remote into it via a browser...page cannot be displayed.
So almost seems like I've lost all network functionality.
Great. Did some research and this isn't uncommon across the line. Not making me feel all warm and fuzzy.
So is there a way to get this file and load it via USB or anything? Or am I totally screwed?
There is currently no display over the video.
Do I power it off and hope it just didn't issue the "restart" command correctly?
tullnd is offline
Old 08-07-2010, 03:00 AM
browser47210's Avatar
I am not 100% sure but it appears to have improved remote connectivity via the web app. I played with this a bit and it seems a bit more responsive from both pc and iPhone apps. Would be excellent if denon started providing release notes...
Downloaded the latest update. Seems to have updated without a problem in about the stated amount of time. As far as rebooting, the update does that all by itself. I have only tried the web interface. It seems a "little better", but still clunky in IMHO.
Can anyone tell me what app I need to put on my Iphone to control the 3310CI ? Thanks in advance.
browser47210 is offline
Old 08-07-2010, 03:34 AM
I see that on the Denon owners club homepage that an addendum is available for the 3310CI user's manual. I have not compared it to the Manual that came with the unit on June 10, 2010, to see what the adds are. Maybe the manuals will get better ?
One way to keep a customers loyal and returning is to have proper user instructions. I mean what good is a fighter jet, to someone who does not know how to fly ?
Old 08-07-2010, 03:39 AM
http://www.usa.denon.com/AVR-3310CI-...ndum-E_009.pdf
Quick link to the Addendum.
Old 08-07-2010, 06:29 AM
mjclifford's Avatar
Display reads:
Ether SBL 01min
Update Check OK
Welcome to the world of the bricked AVR. Tech Support recommended that I download firmware to fix another problem, it was bricked, and they said to send it back. After five weeks (they lost it for 2) I received a refurbished unit.
Some people here have brought them back from the brink of death by doing a full system reset. That's about all you can do. My sympathies.
mjclifford
mjclifford is offline
Old 08-07-2010, 08:01 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
you need no special application just open your safari browser and type in the network address (something like 192.199.199.2 you can find under network info) and it should bring you to a page which mimics loosely the 3310 menus system. You will first pick main or one of the other zones to control and presto.. The denons have software loaded which is accesible by a client browser. The best approach is to assign your 3310 a static ip address and bookmark that entry page for future access.
In search of video bliss...
mariob33 is offline
Old 08-07-2010, 08:44 AM
Thanks for the tip on Iphone control. It works for me now.
Old 08-07-2010, 09:28 AM
batpig's Avatar
Liked: 3415
make the manual better? yeah right!
the addendums are released when new features are released as upgrades, e.g. when the 3808ci got Dynamic EQ / Vol and the 3310ci got DSX.
Setup Guide and FAQ
batpig is offline
Old 08-07-2010, 10:30 PM
eireeos's Avatar
Would someone who owns a AVR990 or 3310ci be so kind as to measure the depth of the case not taking into account the front dials. I need to see if it will fit in my unit before I can even consider it. Thanks in advance. I appreciate it.
eireeos is offline
Old 08-08-2010, 05:50 AM
bch238's Avatar
The case is almost exactly 14.5" deep, which includes neither the front dials nor the rear connectors (e.g. RCA and speaker connectors).
bch238 is offline
Old 08-08-2010, 08:42 AM
eireeos's Avatar
Thank you very much bch238.
eireeos is offline
Old 08-08-2010, 11:15 AM
jr1234's Avatar
The last network card failure Denon sent me the 3311CI.
I will monitor both forums 3310 and 33111.
3311 a little diff.
jr1234 is offline
Old 08-09-2010, 12:11 PM
bch238's Avatar
I have my 3310ci wirelessly connected to my Windows 7 computer. I use Windows Media Player 11. Sharing is properly enabled, and I am able to stream from the computer. But....
The problem is that the alphabetical "search" function routinely hangs, or there is so much lag that it nearly impossible to navigate. Scrolling through 2500 artists (more than 150 Gigs) is so time consuming that popping a CD in the player is quicker.
Is the situation improved with a wired iPod dock, i.e. the ASD-11R? Anybody have any experience with this dock? Anybody have a better experience with streaming from a music server?
bch238 is offline
Old 08-09-2010, 06:54 PM
bch238's Avatar
I'm going to answer my own questions, sort of:
I switched from Media Player 11 to Tversity (free download) and the Denon search function is VERY MUCH faster. Who needs an iPod dock?
bch238 is offline
Old 08-09-2010, 06:56 PM
netorders's Avatar
Yea it is a mess. Using xbmc. Hoping for fix. iPod is good for mp3s etc. Not flac ogg or higher quality stuff. Might get new Mac mini w hdmi when refurbs are available. Expensive but it turns tv & Denon into a full blown Internet media ctr. Also rumor has a $99 apple tv is on its way. Denon solution is pricey just for iPod solution. Have fun. It just a money pit!
netorders is offline
Old 08-09-2010, 08:05 PM
luckydog2006's Avatar
Originally Posted by franksnbeans View Post
Has anyone had an issue upgrading to DSX? To accomplish this apparantly you go to the website http://usa.denon.com/SHOP/Webpage.aspx?WebpageId=2 and input the upgrade ID and serial number. This is supposed to trigger a portal where you can purchase the upgrade. When I do this it says "Your Upgrade ID is either not valid or has already been activated. Please check your information and enter the correct Upgrade ID. If you continue experiencing problems please call Customer Service at 1-201-762-6665." I called support on friday and they said they would call me back with an answer (but have not yet.) I also emailed support and they said they would get back to me (but the have not.) I also asked through the support portal and 24 hours later they responded with "Double check your Upgrade ID and make sure you copied it down correctly"!!!!!! Of course I have checked both serial number and upgrade ID 100 times!! Your stupid automated message already said that!! Im afraid after another 24 hours the next answer is going to be "make sure the unit is plugged in." Thought I would check in with the forum to see if anyone had any ideas. I have the new firmware installed and the network works fine. Either way I dont think this would cause an error with the codes and purchasing the upgrade on their website. Any input is always greatly appreciated. Thanks.
You need to fax+email the info in first. I called their number afterwards to check if they received it, and they confirmed receiving the fax. I received the authorization via email two days later (if you did not receive any confirmation, you just need to call them to confirm again), and I was able to perform the DSX upgrade when it connected to the server and authenticated my AVR990. Everything worked fine with the DSX upgrade.
luckydog2006 is offline
Old 08-10-2010, 02:42 AM
mjclifford's Avatar
I experienced the same problem after my first unit was returned with a new network card. Search did not work at all; the system would lock up every time, forcing a power reset. After several weeks in the shop, Denon swapped out for a refurbished unit. Total time in the shop: Seven weeks.
mjclifford
Old 08-10-2010, 05:27 AM
bch238's Avatar
mjclifford
Tversity (replacing WMP 11) has solved all my problems, and it literally took 30 minutes to download (free) and set up. My library was immediately, if only partially, available as it began to populate Tversity, and the entire library is now available after completely loading overnight. If I rip a CD in iTunes, it automatically loads into the Tversity library within 12 hours, or nearly immediately if I force a refresh of the library. Navigation on the 3310ci is literally 1000% faster and very usable. The alphabetical search is still a little slow, but I can zip through the menu a page at a time, whereas before this was very clunky with WMP 11.
While I am sure that some experienced actual hardware failure, my experience makes me wonder how many unwittingly attribute problems to the 3310ci where blame should be on the network and/or media server software. I know I was at that point. Denon should have devoted more pages in the manual to this topic, for sure.
bch238 is offline
Old 08-10-2010, 06:52 AM
Nikonowski's Avatar
Quoted: 61 Post(s)
Hi Guys,
I just got the AVR 990 and I need help setting it up - I upgraded from AVR 998. What differences if any should I be aware of and how I set it up especially in video scaling department. Are there any seetings that some of you had posted already perhaps. I am going to be running Satelite DVR , PS3 and upconverting DVD player OPPO into this AVR.
I know that I have to setup Audyssey as well ...
Any tips would be appreciated!
Nikonowski
Nikonowski is offline
Old 08-10-2010, 06:58 AM
Originally Posted by Nikonowski View Post
Hi Guys,
Nikonowski
There is no easy way. Just trial and error. The Denon manuals s**k, and even though there are lots of other documented help, its not great. But with a bit of trial and error and piecing together the info, you should be able to get it all working to the way you want.
Old 08-10-2010, 08:53 AM
Nikonowski's Avatar
Quoted: 61 Post(s)
Thanks luckydog ... I know it is trial and error but I need to start somewhere so any point of reference would be appreciated
As I said I had my avr 988 pretty much setup the way I wanted along with Bravia XBR TV but now just by changing receiver everything seems to be off especially HD picture I did not think that just changing receivers would do that as I had my TV calibrated before. Now the HD channels look different not as bright not as contrasty - totally different , I am so dissapointed so far with this new AVR. I though it was a bit better.
Perhaps all can be saved with appropiate settings - so any help would be appreciated. Perhaps someone has the very similar setup ?
I have not tried the PS3 Blu ray yet - that's next. Is video processor really better in this AVR versus my old one AVR 988 ?
Thanks ,
Nikonowski
Old 08-10-2010, 10:16 AM
batpig's Avatar
Liked: 3415
honestly, it isn't that much different from your 988. if you are comfortable with your old model's menus not that much has changed beyond the additional video processing and networking options, and the feature additions of Audyssey Dynamic EQ / Volume.
read through my website for descriptions of some new settings (hdmi video processing, and Audyssey stuff especially).
there is absolutely no reason you should have seen a change in the HDMI picture quality. by default, your new model does not do ANY video processing on HDMI sources, just like your old receiver. you have to specifically enable HDMI video processing.. and, even then, it should not be changing brightness, contrast, color, etc. it's just a scaling solution (unless you go activate the picture tweaks under "video adjust").
basically, your video problems are NOT the AVR... something else has changed, most likely the picture mode on your TV are you using the same HDMI input on the TV as before?
Setup Guide and FAQ
batpig is offline
Old 08-10-2010, 03:08 PM
Hi Nikonowski,
I agree with batpig's response. My HDMI picture sources are unchanged to my plasma. I don't want the AVR990 to manipulate any high-def video signals from my HDMI sources e.g. Bluray, PS3, and HD cable. I only want the AVR990 to manipulate the SD signals only.
Old 08-10-2010, 08:30 PM
Nikonowski's Avatar
Quoted: 61 Post(s)
Hi Nikonowski,
Thanks to both of you luckdog and batpig - so are you suggesting that I do i/p scaling off for HDMI and leave it on just for SD/analog sources ?
I swear that I did not change my TV modes - I had them setup for over 2 years :Standard for HDTV watching and Custom for PS3 Bluray. Once I disconnected the old reciver and put the new one in - the picture for the two mentioned modes is totally off and different . It looks like I have to start playing settings again from scratch. This is not cool at all. We all have gotten used to the colors etc with old modes.
Also, is it true that AVR 990 is using Anchor Bay processor found in Divo Edge ? If so I don't see a huge improvement ??? Is there another AVR from Denon that I should consider instead of AVR 990 ? The reason I switched from teh old one, was the following features:
- networking
- dynamic EQ and volume
- Anchor Bay Video processing i.e. I can now force output HD TV to 1080p/24
I have 28 days to solve my issue or I will return the 990. Is the AVR 991 a better AVR ?
Thanks so much for your help.
Nikonowski
