What is benefit to buy from Authorize Reseller? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-15-2009, 07:18 PM - Thread Starter
Ladic's Avatar
I want to buy Pioneer VSX-919AH-K
I have 2 options:
Amazon $350 (Authorized Reseller)
http://www.amazon.com/Pioneer-VSX-91...=2U47SFKOHV2PQ
Newegg $330 (Not Authorized Reseller)
http://www.newegg.com/Product/Produc...82E16882117301
I can save $20 by going Newegg, but what are the benefits of buying from authorized reseller?
Ladic is offline
post #2 of 16 Old 07-15-2009, 07:25 PM
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
Main benefit is you know the warranty will be honored. Pioneer, especially their Elite line, won't honor the warranty if not bought from an authorized dealer. Too me, that's worth $20.
gene c353 is offline
post #3 of 16 Old 07-15-2009, 07:28 PM - Thread Starter
Ladic's Avatar
so if I buy from newegg and it breaks within a couple of months I would be SOL? i wouldnt be able to send it to pioneer for repair?
Ladic is offline
post #4 of 16 Old 07-15-2009, 07:32 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Just spend the extra $20. If we were talking $200 difference for this model, then you would think about it. Pioneer, and many other manufacturers won't honor warranties. Odds are it won't matter but $20 makes it an easy choice. A few hundred would be different.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #5 of 16 Old 07-15-2009, 07:35 PM
bigbare's Avatar
If it were me I would always buy from an authorized retailer/reseller. If you have ever had something break that wasn't covered due to this you would understand why you should buy from te authorized dealer.
"Sometimes you get shown the light in the strangest of places if you look at it right"
bigbare is offline
post #6 of 16 Old 07-15-2009, 07:38 PM - Thread Starter
Ladic's Avatar
Well I found it at Buy.com for $320
http://www.buy.com/prod/pioneer-vsx-...211045527.html
according to pioonerr website they are authorized dealer
http://www.pioneer-america.com/PUSA/...n+the+Internet
Ladic is offline
post #7 of 16 Old 07-15-2009, 09:07 PM
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
To answer your question, yes, Pioneer could refuse to repair your receiver if you bought it from an un-authorised dealer. When you hear "comes with manufacturers warranty" often times they mean the paper work inside the box. Doesn't mean the manufacturer will honor it. Always check the brands website (or e-mail them) to make sure they are indeed authorised.
If you must buy from an u-a dealer at least consider an extended warranty from a third party. It would be better then nothing. Hopefully.
post #8 of 16 Old 07-16-2009, 12:05 AM
WilliamZX11's Avatar
Quoted: 25 Post(s)
You sure? That's not actually being shipped from Buy.com, but from 1Stop Camera. They are not on Pioneer's list.
Personally, for $20 I'd go with an authorized dealer, but on more expensive gear, where I could save $100's, I have no trouble with unauthorized dealers. I've saved enough over the years to more than cover the cost of even a very pricey component. I've never had equipment fail under warranty anyways, except for some NAD gear quite some time ago. With that experience, having a warranty was really of no value anyways.
WilliamZX11 is offline
post #9 of 16 Old 07-16-2009, 07:46 AM
Perch33's Avatar
Seriously? Youre sweating $20? If the difference is really a issue maybe you shouldnt be buying at this point, but instead saving your money. Buy the authorized unit.
Perch33 is offline
post #10 of 16 Old 07-16-2009, 08:54 AM
Quoted: 25 Post(s)
It appears he is trying to save his money. The economy is tough right now.
post #11 of 16 Old 07-16-2009, 09:06 AM
ccotenj's Avatar
Liked: 101
2 things...
true. but time is money too, and the amount of time spent trying to save 20 dollars seems a bit excessive.
not to be cold, but if saving 20 dollars (in this particular case) is worth obsessing over, the op probably shouldn't be spending the money on an avr in the first place.
neither of those statements mean that i don't think you should be careful with your discretionary income and shop around.
- chris
ccotenj is offline
post #12 of 16 Old 07-16-2009, 10:52 AM
Jason Turk's Avatar
For $20 ths shouldn't even be a question. Specifically in regards to your question...non-authorized dealers USUALLY mean NO WARRANTY. Technically they aren't even supposed to sell them, but they do. Usually, and this is in regards to my initial comment, the difference is big (20%+ between non and authorized dealers).
FYI AVS is authorized for EVERYTHING we sell (though I don't sell Pioneer). We own the AVSForum so we cannot afford to play those kinds of games.
Jason Turk is offline
post #13 of 16 Old 07-16-2009, 04:21 PM
Quoted: 25 Post(s)
Jason, maybe you can answer a question. I've bought items from unauthorized dealers before, and on the box is a shipping label, direct from the manufacturer, or distributor to the business selling the item.
If manufacturers don't want them selling their product, why do they play these games? They obviously know it's for resale, individuals can't usually buy from distributors. Maybe they should just put a stop to it.
post #14 of 16 Old 07-16-2009, 04:28 PM
Daniel Hutnicki's Avatar
By the way, how do you know that Newegg isnt authorized. I mean, they are a big company, I am surprised they would sell something they arent authorized for
Daniel Hutnicki is offline
post #15 of 16 Old 07-16-2009, 05:07 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
While most manufacturers like Panasnoic, Sony, Samsung etc, honor warranties regardless where you bought it from, Companies like Pioneer, Denon and a few other high end audio equ. makers are not. Their warranty card will explicitly specify that no warranty service what so ever if you bought from non-authorized dealers. So, it is brand dependent. As for OP buying a Pioneer product, I don't know why he even bother asking because Pioneer will not honor any warranty if he bought from non-authorized dealer. It's not like Pioneer product never breaks.
Foxbat121 is online now
post #16 of 16 Old 07-16-2009, 06:41 PM
ccotenj's Avatar
Liked: 101
well... it IS a bit surprising... but...
a) they aren't listed on the pio website... which doesn't necessarily mean anything...
b) several people have posted on various sites that they have emailed pio asking if newegg was authorized, and told that they weren't...
but who knows...
- chris
ccotenj is offline
