How much would it cost to repair a receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-27-2009, 10:30 AM - Thread Starter
ryanater's Avatar
Can someone estimate about how much would it be to repair a Onkyo NR905 receiver that won't turn on. The standby light comes on but it won't power up.
And is there any way to diagnose the problem and maybe fix it myself? I don't have a lot of experience with this sort of stuff but if it's not hard I could give it a try.
ryanater is offline
post #2 of 3 Old 07-27-2009, 10:31 AM
Bruins29's Avatar
Sure. $100
Check the fuse.
Bruins29 is offline
post #3 of 3 Old 07-27-2009, 12:44 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Isn't it still under warranty? If not the option of bringing to a good electronics shop is the only other way to get an estimate for cost. It may be something simple as a fried wire or even just loose. Have you popped the top off of it and checked for a blown fuse? That's the first thing I'd do if its out of warranty. Check Onkyo's website for repair centers close to you. If there are none, find one you can trust.
phantom52 is offline
