does the pioneer vsx 919ah-k really run HOT? - AVS Forum | Home Theater Discussions And Reviews
Old 08-04-2009, 11:40 AM - Thread Starter
jose_shs_98's Avatar
I almost have my decision set on the pionner vsx919 but if it runs too hot I am deciding to possibly go with the Denon avr1610...Any comments for both...Which has more power? Which one is better?
jose_shs_98 is offline
Old 08-04-2009, 02:54 PM
pinkyq's Avatar
The VSX-919 runs warm/hot. Hard to describe how hot but Its much warmer than the AVR 590 (which I am also running now). The Denon "barely" generates any heat. I think the 590 would apply to the 1610.
However, if you read the threads on both models most of the experienced audiophiles do not appear worried about the heat generated by the 919 especially if you have proper ventilation.
pinkyq is offline
