Onkyo TX-NR807 Official Thread - Page 183 - AVS Forum
 1Likes
post #5461 of 5489 Old 03-18-2014, 01:30 PM
slaw82's Avatar
Originally Posted by Al Sherwood View Post
This is from my 3007 that I just shipped off for repair, the picture was taken yesterday. I don't have a picture from the original HDMI board that came in the unit. At any rate this HDMI board was installed in May of 2012 well in advance of newer design chip being available from TI.
As I said Onkyo did release a service bulletin to their authorized depots about the voltage issue, here is the post http://www.avsforum.com/t/1170804/onkyo-tx-nr807-official-thread/5220#post_22225196
The "low voltage fix" was actually recommended by TI to prolong life of the defective chips. Here you have official documents from TI:
http://www.farnell.com/datasheets/1671329.pdf
http://processors.wiki.ti.com/images/5/5a/Premature_Aging_Presentation.pdf
Please tell me one more thing, your original and replaced HDMI board was BAHDM-0132? Do you have a photo of whole board?
slaw82 is offline
post #5462 of 5489 Old 03-19-2014, 08:05 AM
Al Sherwood's Avatar
Quoted: 26 Post(s)
Slaw, thanks for providing the links for the TI chip information, I have my fingers crossed that the 'yet to be installed' HDMI board has the revised chip, but I doubt that Onkyo would be re-manning the boards with new chips for a 4 year old receiver. The most likely scenario will be the adjustment of the voltage to 3.1 voltage to extend it's life. I will however be taking pictures when I get the unit back.
So I don't have any pictures of the original board that came in the 3007, I only have the 1st warranty replacement (that failed after 1-1/2 years). The picture is in 2 parts so I could get the best detail of the board, identifier: BCHDM-0157
Al
Al Sherwood is offline
post #5463 of 5489 Old 03-19-2014, 08:42 AM
slaw82's Avatar
Thanks for your photos, HDMI board in your machine is different than board of 807. I have a dead 807 now, i've reballed Q3001 once and it died again after 2 months. Now i have to replace that IC because another rework don't work anymore but i can't find D830K011 anywhere :/ I found new D830K013 in China but i don't know what is the difference between K011 and K013, there are no datasheets of this ICs on the net :/
slaw82 is offline
post #5464 of 5489 Old 03-19-2014, 08:55 AM
Quoted: 26 Post(s)
Have you seen this? http://www.ebay.com/itm/REPAIR-SERVICE-ONKYO-TX-NR807-HDMI-BOARD-WITH-NO-AUDIO-ISSUE-/301124440539?pt=LH_DefaultDomain_0&hash=item461c6a51db#ht_457wt_1362
Al
post #5465 of 5489 Old 03-19-2014, 08:58 AM
slaw82's Avatar
I live in Poland, that offer is not from my part of the world :D On the other side, i will not pay for repair if i can do it myself ;)
slaw82 is offline
post #5466 of 5489 Old 03-28-2014, 05:11 PM
aishoy's Avatar
I was about purchase new capacitors from parts express to repair my once again defunct HDMI no sound issue on my 807. However, after deciding to actually review the official 807 thread posts for the last year, I don't see that replacing capacitors on this model is discussed as an option at all. So forgive me if it's been discussed in the prior 170 pages of threads, but is our board suffering from an issue beyond dead capacitors - the DSP processor chip? Many other Onkyo HDMI issues on newer models are being owner-repaired by replacing the many capacitors that die from extreme heat.
I appreciate all the info posted here. I will contact Onkyo once more if it's more than just capacitors to see if I can get a 2nd HDMI replacement - this time out of warranty.
aishoy is offline
post #5467 of 5489 Old 03-28-2014, 05:49 PM
Quoted: 26 Post(s)
It is my understanding that the failure is the from an over voltage condition on the DSP Chips. Newer chips (boards) have more robust chips.
When was your board first replaced? The revisons came out in September of 2012.
Al
post #5468 of 5489 Old 03-29-2014, 08:01 AM
aishoy's Avatar
Looking at the work order now - it was replaced in March 2011. The first time it was replaced was under New Egg warranty as it was 6 months after purchase. Hopefully Onkyo will step up for me.
aishoy is offline
post #5469 of 5489 Old 03-29-2014, 09:21 AM
Quoted: 26 Post(s)
It doesn't hurt to ask Onkyo... good luck!
Al
post #5470 of 5489 Old 04-04-2014, 10:30 PM
rickydenim's Avatar
My 807 has been working flawlessly until this week. For some reason every time I play a video file through my Oppo 103 there is no sound the first time. If I press stop, change input to something else, then back again it works again. Is this a sign my HDMI board is on the way?
rickydenim is offline
post #5471 of 5489 Old 04-05-2014, 05:13 AM
holmzy's Avatar
hello lovely people. Im from UK. I have taken a lot from this forum so its only fair I give something back. I have a 807 puchased faulty with no audio and hdmi issues, on osd etc. Its the fault everybody is having!
so basically I fixed everything! running since very early jan mainly just for audio and I was very impressed with the sound quality! so sold my high end amp and kept this :)
I cant believe people are struggling so much with this amp! there is so much info on this site it can be fixed for good.
what I did....
VIDEO FIX
replaced all caps (well (99%) in hdmi board - video work but failed after 15 minutes or so
added 1 1uf cap across 1 transistor that I suspect was causing video/osd issues - video did not fail
SOUND FIX
made a housing for the DSP chip and added heat sink - never had to reball or use heat gun. audio has never failed since
clearly a fan is a must! and has had a temp fan since all repairs made. have order a nice 200mm fan to sit on top to cool those pre-amp transistors and mosfets as they are the only main components that produce sooo much heat.
any more info let me know!
holmzy is offline
post #5472 of 5489 Old 04-05-2014, 07:21 AM
Quoted: 26 Post(s)
so basically I fixed everything! running since very early jan mainly just for audio and I was very impressed with the sound quality! so sold my high end amp and kept this smile.gif
what I did....
VIDEO FIX
SOUND FIX
Would like to see a picture or two showing the heatsink that you put on the DSP chip, It is my understanding that this issue on this chip was the input voltage, but as you mention it never hurst to keep things cool... ;-)
Al
post #5473 of 5489 Old 04-05-2014, 08:44 AM
holmzy's Avatar
input voltage? i did read abou that but thats not the issue. heat is what killed this amp. i repair tv's not amps this was first attemp. heat kills tv's and heat killed this amp. no sound, no osd, no speakers is display panel, no network the same everyone is experiencing! with this there should be no problems. I have yet to find anyone using the dsp cooling method i have used. its soooo simple cant believe no one even tried it!!
get small enough crews to fit the hole. i had to make mine slightly bigger. note i had no audio what so ever before this and no heat was used to melt solder etc
fit screws through make a small base for it to screw to add heatsink. bobs your uncle!
also added heat sink to gpu and the mosfet that burns your finger when touched! under blue heatsink.
then it got me thinking osd/hdmi still does not work properly. i decided to investigate the eakest component most affected by the superhot mosfet and found a transistor. since no guide was created for this amp to resolve the osd issues and believe me i looked, i had to do some logical guessing that the transistor just under it and right next to the gpu might be playing up. so after adding some generic 1uf 250v capacitor i got from a faulty sony psu board i resolved the issue.
you can just see it here its red.
and it goes here
i only really use this amp for stereo but after hours of use i do check to see if osd still works and yes it does.
only really got this to try and fix. my electronic skills basic. clearly without this site i would not have been able to fix this. 3 months now my amp went from paper weight to decent amp! potentially with this you can fix all models with similar hdmi board. i nearlly got my hands on a 5008 for peanuts. muhahahahahaahaha
EvilNoOne likes this.
holmzy is offline
post #5474 of 5489 Old 04-05-2014, 07:42 PM
EvilNoOne's Avatar
HI, i have a request to persons who had HDMI boards replaced in their units. Can you please take a photo or at least read markings from DSP processor (Q3001) and post it on the forum? I'm curious if Onkyo placed a newer revision of the chip on the HDMI boards they mount. If the chips are same there is highly probable that the units will fail again after 2-3years (assuming the chips are new).
I ordered a new board on thursday, should arrive in a few days, this is the second one which is broken in my 807. The first one broke after 2 1/2 years (02/2012) and the 2nd one about 2 month ago.
At the moment I help myself with the turn off/on  after "preheating" it in standby, works good till now, but the preheating time extends. I wrote to Onkyo in January, didn't get any response till now so I ordered the board myself (190€ here in Germany -.- ).
I will make Photos of both, the two old ones and the new one on arrival.
I will try to repair the old ones with the method Holmzy mentioned. Maybe it works and I will have spare parts for the Future ^^
I will also try to build in some kind of fan and heatsinks.
Does anyone did this already? Especially with the use of some internal power source for the fan?
Holmzy's method sounds very interesting, because of the heat that dissipates from the q3001 and his "mounting" with the screws and heatsink, there is no chance that it can "desolder" itself.
I know it ist not really desoldering, but with the constant change in temperature, it is most likely that the soldering begins to build cracks in the connections under the chip (just my 2cent).
Regards
P.S.:
The dealer told me the new boards should have a label on the dsp chip, but I will see what he meant when it arrives.
EvilNoOne is offline
post #5475 of 5489 Old 04-07-2014, 04:52 PM
Wildstar87's Avatar
I have started getting the center channel cutting in and out, while watching an HDMI source on Dolby/DTS setting, it is worse depending on source (seems to have failed on my HTPC channel), and also during certain parts of a DVD/Bluray, it's not intermittent per say, it is like it gets a different coding, and switches off, and is reproducible on that media. If switch to All Ch Stereo, or simulated surround, I can hear the center channel information again, BUT it isn't coming out the center channel specifically.
Is this a sign that my HDMI board is going out? I just want to make sure before I try to contact Onkyo to get a replacement board.
Also is there a FAQ somewhere about what caps and other mods to do to fix the problem on your own? I fix electronics for a living, so I wouldn't have an issue trying to do this. I'm hoping there is one somewhere and I don't have to crawl through all 183 pages of this thread to find them.
Wildstar87 is offline
post #5476 of 5489 Old 04-08-2014, 09:19 AM
Quoted: 26 Post(s)
and it goes here
Thanks for the pictures and details, I think that I will add a heat sink to the DSP chip (Q3001), as mentioned earlier, no harm in keeping it cool. The GPU chip (4th and 5th picture down?), what is the designation of this chip and or its name? I may look for this one as well in my 3007 (still waiting for it's return).
I also plan to add cooling fans to this unit, I have bought a couple of ultra quiet units that I will mount on the top... blow or suck... that is my next decision.
Al
post #5477 of 5489 Old 06-06-2014, 06:29 PM
Quoted: 26 Post(s)
This picture is yours or from internet? On picture DSP is D830K013 and NR3007 service manual says that the IC should be D830K011. Failures of the units are not Onkyos fault, TI is the one to blame. I have official TI bullettin which says that huge family of DSP processors manufactured by them has design flaw and it's the reason of premature aging of the chip. TI made corrected version of the ICs and they are on the market from 2nd quarter of 2013, they have markings D830K13 (or K11) DZKB instead of AZKB and BZKB on the previous versions. Unfortunately i can't find them to buy anywhere :/
Well, I have an update, I just got my NR3007 back with the 'new' HDMI board and thankfully a 'new' DSP chip at position Q3001! The entire board was replaced, compared to the previous board this one has a distinctive golden hue. I plan to at a minimum add two 120mm Noctura ultra quiet cooling fans on top of the AVR, and possibly a heat sink to the diminutive Q3001 that forms the heart of the video and sound circuitry in these AVR's.
The first picture is a close up of the DSP chip and the last two pictures show the board itself... according to what was quoted above this is the corrected version made available by TI to manufactures to replaced the flawed DSP that these AVR's originally came with.
BTW, Extreme Kudos to Jose and Onkyo for the excellent customer service and support for an issue beyond their control, very much appreciated!
Al
post #5478 of 5489 Old 06-09-2014, 12:41 AM
slaw82's Avatar
Hi,
your new Q3001 is K013DZKB so according to TI's bullettin that's the new, corrected version of the chip so it should work forever now :) It seems your receiver has been repaired for good ;)
slaw82 is offline
post #5479 of 5489 Old 06-09-2014, 10:01 AM
Quoted: 26 Post(s)
Hi,
your new Q3001 is K013DZKB so according to TI's bullettin that's the new, corrected version of the chip so it should work forever now smile.gif It seems your receiver has been repaired for good wink.gif
I sure hope that you are right about lasting forever! I really like the sound and features of this AVR and it will be used for a good long time to come
But as an added precaution I have placed a fan on top for additonal cooling, these units do run hot as we all know and additional cooling can't be a bad thing. With a single 120mm fan placed directly over the right side rear, the resulting effect was amazing, normally the top of the case is hot to the touch within literally minutes of turning on the unit, after 1-1/2 hours of running (with fan in place), the top was almost cool to the touch. when the AVR gets placed in my equipment rack it will have a dedicated fan system in place to draw filtered air through the receiver at all times when running.
Onkyo has been very helpful to me through this problem, and as you mentioned earlier in the thread, the defect in the HDMI board was caused by a TI chip not Onkyo.
Al
post #5480 of 5489 Old 06-10-2014, 03:08 PM
anadigi's Avatar
I have mine fixed last year.
I very rarely use it as I bought another AV before I sent to repair.
I have just opened up the cover and the chip is D830K013DZB3 but not 4!
May be 400Mhz is not for NR807.
anadigi is offline
post #5481 of 5489 Old 06-11-2014, 12:57 AM
slaw82's Avatar
Yes, KB4 does not work in 807, receiver does power on and all the functions work but there is no sound from the speakers and headphones :/ Problem is that there's no way to buy KB3 chips, only KB4 are available :/
slaw82 is offline
post #5482 of 5489 Old 06-17-2014, 08:01 PM
berzo84's Avatar
Originally Posted by jenielsen View Post
berzo84 - Keep the faith. Given all of the other owners in this thread who have had Onkyo step up and take ownership of the issues with the 807, I would say your chances are very good. My guess would be that it doesn't matter if it's US or Austrailian support, Onkyo knows about the issues and should probably help out. I would reference the fact that you have read about many other owners having theirs fixed out of warranty for the issues that plagued the unit. Good Luck and let us know how it goes.
Just had a call from my local repair center. Onkyo have agreed to cover the HDMI board under a warranty extension. I have to pay for the labor of the unit which is $132. I am more than happy with the outcome. Thanks for all of the info i got from the other members of this forum, it has helped a heap.
berzo84 is offline
post #5483 of 5489 Old 07-29-2014, 07:06 PM
rothe's Avatar
E-bay seller audiovideo410 bad repairs
I have, and I took the bait! Just to help others find this post via Google, the E-bay seller is "audiovideo410" out of Garden Grove, CA.
After the first repair, in February of this year, the repaired board worked fine for about six weeks. That's two weeks past the seller's 30-day warranty. He was good enough to extend his warranty to one free repair, which was in mid-April. That repair worked fine until early July, and now the receiver has failed just like it did before any of this. No amount of pre-heating seems to help.
After this second failure, I went back to the E-bay seller's feedback rankings and I now see two complaints stating that the repaired board worked for either four or six weeks, and then failed just as it did prior to any repairs.
Bottom line is that this particular E-bay seller can't seem to properly repair these boards. Avoid!
James Rothe
Monmouth County, NJ
(37 miles due S of the ESB)
My Own OTA HDTV Experience: http://www.jimrothe.com/hdtv_ota/
rothe is offline
post #5484 of 5489 Old 07-30-2014, 07:09 AM
Quoted: 26 Post(s)
Sorry to hear that this repair option turned out to be a dud...
Al
post #5485 of 5489 Old 08-19-2014, 11:58 AM
S7V7N's Avatar
I bought my Receiver back in '09 (HT-RC180) & this past week I had my first problems with Audio not coming on at start up. My receiver is obviously out of warranty.
I considered using the Ebay guy to fix the problem, but had heard that his fix may only be temporary & when I asked him about what he replaces exactly he failed to respond. So that was a red flag for me.
I contacted Onkyo & was told that they would perform service on the unit free of charge. They even mail out a prepaid shipping box!
If you are having a problem with one of these units made '09-'12 & are having audio or network connection issues then I would highly recommend simply contacting Onkyo Parts & Service Dept. (201) 785-2600 & see if they will repair yours as well. Don't bother sending an email, because I never got a response & after 2 weeks I just called & was directed to the proper channel.
You can probably just go to the below link & bypass customer service altogether. Hope this helps.
http://www.onkyousa.com/Support/service_info.php
Onkyo USA Support Information
08/19/2014 Loss of Audio/Network Connection Customer Care Program
As part of our commitment to quality and customer service we have determined that a limited number of Onkyo Brand receivers manufactured between 2009 and 2012 may experience loss of audio or loss of network connection. This malfunction has been traced back to a defective network chip.
We deeply regret any frustration or inconvenience this situation may have caused.
To address the problem and help people who may have an impacted receiver, Onkyo is launching a special Customer Care Program to remedy this issue for those receivers that may be affected by this loss of audio/network connection issue. This program has three steps:
1. Verify if your Onkyo receiver is impacted
2. Decide how you prefer to address the issue
3. Send us your receiver in a prepaid box and label that we will provide at no cost to you
As part of this program we are also extending our standard limited warranty period to cover this issue for affected receivers through December 31, 2018. All other terms, conditions and limitations of the original limited warranty shall continue to apply for the duration of the original standard limited warranty.
Importantly, please note that the loss of audio/network connection issue will not result in harm to any connected components or speakers since the issue is contained to a single element within the affected receivers.
To determine if your receiver is eligible under this Customer Care Program please click here
Loss of Audio/Network Connection Customer Care Program for US and Canada customers
We thank you for your loyalty!
Onkyo again apologizes for any inconvenience this may cause and will provide this repair as expeditiously as possible.
joe221 likes this.
S7V7N is offline
post #5486 of 5489 Old 08-21-2014, 09:02 AM
TreyWingbat's Avatar
I have an Onkyo 807 receiver, and for some reason now, one of the HDMI inputs is only allowing an analog signal, so I cannot use HDMI with it. I tried pressing the “monitor out” button to switch it to HDMI, but it doesn’t switch. Same thing if I go into the setup menu.
I did have my HDMI board replaced already due to the other audio issues mentioned in this thread.
Is there a way to revert it back to HDMI for this input, without having to do a factory reset?
TreyWingbat is offline
post #5487 of 5489 Old 08-29-2014, 12:47 PM
rothe's Avatar
Onkyo TX-NR807 Goodwill Repair
I just received my Onkyo TX-NR807 back after a goodwill/out-of-warranty/FREE(!) service by Onkyo's factory service center. They apparently replaced the HDMI board with a another one. I can't tell if the replacement is brand new or refurbished, but it is apparently a different one. See my attached pics of the board that I sent them, and the one that I got back. Note that what I sent them was repaired previously - twice! (see my earlier posts) - by a third party repair service.
Consistent with the post by S7V7N, above, I went to the Onkyo USA web site, registered my product, and then contacted Onkyo support through the same web site. FWIW, when I registered, I took a guess at the purchase date and entered "gift" under the retailer name, as this unit was a hand-me-down and I don't have any receipts or other documentation for it. Regardless, after that initial contact on August 4, I heard back from Onkyo support on August 10, and was told that a box and a pre-paid shipping label would be sent to me. That arrived on August 19, I sent the unit out on August 20, and it arrived at an Illinois service center on August 22, and I just got the repaired unit back in New Jersey on August 29. So it took less than a month from initial contact via Onkyo's web site, and exactly ten days to repair the unit including the round-trip shipping. That's not bad.
I haven't hooked it up yet - that will be tonight's project, so I'll report back later on with additional comments.
James Rothe
Monmouth County, NJ
rothe is offline
post #5488 of 5489 Old 08-29-2014, 01:18 PM
Quoted: 26 Post(s)
Most definitely a replaced HDMI board as evidenced by the chip with the 'New' label and U written in it. see the attached photo of the chip on the replacement board for my 3007.
Al
post #5489 of 5489 Old 08-30-2014, 04:16 PM
rothe's Avatar
Just a follow up from yesterday's post: everything seems to be working exactly the way it's supposed to. Yay! Finally! I have a receiver that works, and works well!
I did discover one minor design flaw (feature?!) when I reconnected my gear. I use an old laptop as a home-theater PC extender, and that system outputs 1920x1080p, 60hz with 24-bit color via HDMI. When I initially hooked the laptop to the DVD/BD connector (HDMI1), the output to my TV defaulted to 30-bit color, even though the Onkyo was showing a 24-bit input. Unfortunately, my TV (a cheap Seiki SC402GS) apparently doesn't accept 30-bit color, and switches into a very small amount of overscan when presented with such a signal. You can over-ride the overscan by going into the Seiki's service menu (menu-0-0-0-0), but the over-ride doesn't stick, so you have to do this after every power cycle.
Well, it turns out that the Onkyo only puts out 30-bit color when fed a signal via the DVD/BD (HDMI1) connector. When I switched the laptop to the VCR/DVR (HDMI2) connector, the output dropped down to 24-bit color and the TV no longer switched to overscan. Go figure!
So I wanted to put that one out to the forum for the sake of some poor soul who stumbles on the same overscan problem, perhaps with another Seiki, or perhaps with some other set altogether.
Anyway, it all works fine now. I'm going to go watch a movie! Ciao!
James Rothe
Monmouth County, NJ
rothe is offline
User Tag List
