Onkyo TX-NR807 Official Thread - Page 184 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5491 of 5517 Old 10-08-2014, 09:00 AM
phileelacs's Avatar
My 807 has recently stopped responding to its remote control. It happened in stages, first with the pause/play buttons, then with the volume, and now with everything. I've replaced the remote with no luck, and have just tried a new Logitech Ultimate, also with no luck. It appears that my problem is in the receiver itself, and not with the remote. Has anyone ever had this problem? Is there anything I can do to troubleshoot this myself? (I'm not a particularly technical guy.) The receiver has otherwise been trouble-free since I bought it new in 2009.
phileelacs is offline
post #5492 of 5517 Old 10-08-2014, 12:35 PM
Al Sherwood's Avatar
Quoted: 554 Post(s)
Liked: 211
Hmmmm
Interesting, how did you determine the correct code for the Harmony, are you sure that it is correct for the 807?
I don't recall ever hearing about a IR failure on the receiver end, most of the time the remote is the issue, I have to ask, did you try a fresh set of batteries in the Onkyo remote?
If you have you AVR connected to the home network you could try to access the receiver via a smart home app like Onkytroller, a free version is available on the Play Store for Android, as for iOS, not sure whats out there.
Al
Al Sherwood is offline
post #5493 of 5517 Old 10-08-2014, 12:58 PM
jenielsen's Avatar
For iOS, I've used oRemote. Great app as long as you are connected to your home network! Should work for your situation with the Remote not working. Grab and old iPod and load it up.
jenielsen is offline
post #5494 of 5517 Old 10-08-2014, 01:12 PM
Quoted: 554 Post(s)
Liked: 211
Ahh yes, I remember oRemote, if I had a iOS device I might have tried it out too...
Al
post #5495 of 5517 Old 10-08-2014, 01:37 PM
jenielsen's Avatar
He also has Android version
post #5496 of 5517 Old 10-08-2014, 08:27 PM
Quoted: 554 Post(s)
Liked: 211
Really? I can't seem to find it... please supply a link if possible.
Al
post #5497 of 5517 Old 10-08-2014, 10:47 PM
phileelacs's Avatar
Thanks for the suggestions. I connected the receiver to my network and was able to control it with the Onkyo app. I have an older unused iPhone that I'll dedicate to running the oRemote software, which looks pretty nice. Still can't get it working with an actual remote, though. (Tried new batteries, too -- fair question.) Now that I have the receiver on my network, I thought I'd try a firmware update, just in case, but I'm getting a 0-11 error, so I'll have to investigate that (according to Onkyo, that error message means it isn't establishing an internet connection).
Any other thoughts on the remote not working are appreciated. Thanks again.
post #5498 of 5517 Old 10-10-2014, 04:25 AM
jenielsen's Avatar
Al - Sorry, I mis-spoke. I was sure he had it, but I can't find it either.
post #5499 of 5517 Old 10-10-2014, 03:03 PM
Quoted: 554 Post(s)
Liked: 211
No worries, I just didn't want to miss out if it was available!
I traded emails with the devoloper early on and found that his expertise is in the Apple world, too bad he doesn't have an Android version too as he has done an excellant job of the app.
Al
post #5500 of 5517 Old 12-06-2014, 05:59 PM
kwokdog's Avatar
OK - long story short, purchased an TX-805 years ago. Was getting the blue dot artifacts. After 3rd service, Onkyo sent me an NR-807....
...which is now dead. Goes into protect mode (with things hooked up, and with everything disconnected) - standby light blinks.
I've read through these forums before and see folks manually fixing the unit. Can someone link me to the repair thread?
Also, in lieu of a repair, if I wanted to sell this thing, how much would it be worth in its current condition?
THANKS
kwokdog is offline
post #5501 of 5517 Old 12-06-2014, 06:08 PM
Quoted: 554 Post(s)
Liked: 211
THANKS
Have a look at this thread, the first post... Should get you to the right place: Onkyo acknowledges failed units and extending warrranties until 2018
Al
post #5502 of 5517 Old 12-06-2014, 08:40 PM
kwokdog's Avatar
Thank you Al. Not sure I will be covered as my symptoms are not listed when I go to sign up for the free repair. I'll try it anyways and see what happens!! Thanks
kwokdog is offline
post #5503 of 5517 Old 12-17-2014, 02:27 AM
shappy1010's Avatar
Hey guys,
I own a TX-NR807 with KEF IQ 5.1 speakers and for the most part it works fine (use it primarily for movies).
But I use a HTPC and notice whenever I output to Multichannel the sound isn't right at all. Explosions are muffled, the soundtrack is not "wide" etc. 5.1 DOES work however, it just doesn't sound right. It's connected via a seperate HDMI from my PC to my amp, in windows sound panel I've set my quality to 24Bit 192Khz. It always plays on multichannel, I can't seem to get it to switch to playing DTS or DD (HD), because when I play from another media host, such as my PS3, and play DTS or Dolby Digital content the sound is perfect, nice and wide good explosions etc.
Now I've dived into some of the speaker cutover frequency documents etc...but it's a little over my head and the number of settings on the Onkyo is insane.
I did run the audyssey setup when I bought it years ago, but tweaked around with it a bit as I wasn't hearing voices probably etc.
Isn't Multichannel supposedly a lot better then DTS/DD?
Can I change the surround settings to different processing (wide cinema etc.) while playing multichannel content?
If I'm having phasing problems or need to tweak my frequency range settings, why is other content playing fine?
shappy1010 is offline
post #5504 of 5517 Old 12-17-2014, 10:22 AM
Quoted: 554 Post(s)
Liked: 211
Originally Posted by shappy1010 View Post
Hey guys,
If your DD and DTS sources from things other then your HTPC sound fine then it is not the Onkyo, it would be what you are sending from the HTPC. For example, if your sound card can put out 7 discrete analog signals this would have to be connected to the pre-ins on the Onkyo.
When you say "Multichannel sound" what exactly do you mean, if it is a sound process derived in the HTPC sound card it will not be read by the Onkyo as either DD or DTS.
So in other words, if the information from the HTPC is not encoded and detected by the Onkyo as DD or DTS you simply won't get that on the AVR.
Al
post #5505 of 5517 Old 12-19-2014, 06:07 AM
Liked: 0
welcome
I nr3007 Tx model without sound. HDMI plate and looks awful - too heated. I do not know if we can do the job to save her. The rest of the functions in the graphic works . Is it possible to change the motherboard model TX- nr3008 ?
JakubL is offline
post #5506 of 5517 Old 12-19-2014, 08:25 AM
Quoted: 554 Post(s)
Liked: 211
Originally Posted by JakubL View Post
welcome
Welcome, check out this thread, you may be eligible for a warranty repair. Onkyo acknowledges failed units and extending warrranties until 2018
Al
post #5507 of 5517 Old 12-19-2014, 08:49 AM
Liked: 0
Thanks, no serial number . I have to fix it yourself .
HDMI Motherboard BCHDM 25140157E 3007 - 0157th About the same number is also in the 3008 , 5008
JakubL is offline
post #5508 of 5517 Old 12-19-2014, 08:55 AM
Quoted: 554 Post(s)
Liked: 211
Hmmm, OK then, this is the 807 thread, you might like to ask in the 3007 thread: Onkyo 3007 Official Thread
I don't see any reason to try a 3008 or 5008 board unless they are exactly the same part number. The HDMI board you want now assuming that you plan to keep this AVR is the latest revision Onkyo has which included the new TI DSP chip that replaces the chip that failed on you original HDMI board.
Al
post #5509 of 5517 Old 12-19-2014, 10:26 AM
Liked: 0
I know it is a new system D830K013BZKB4 . I will try to replace it , but I think the HDMI board is damaged . Somebody heat up too much .
JakubL is offline
post #5510 of 5517 Old 12-23-2014, 01:54 AM
shappy1010's Avatar
PCM Multichannel is uncompressed lossless quality through HDMI. No decoding involved the sound is send directly to the appropiate channel. It's supposed to equal DTS HD. It just doesn't sound anywhere near as good on the Onkyo. I'm now trying to get bitstreaming enabled from my HTPC to my onkyo to retain format.
post #5511 of 5517 Old 12-23-2014, 07:54 AM
Quoted: 554 Post(s)
Liked: 211
Oh I know what PCM and Multichannel is, your comment left some question as to what you were doing and expected at the Onkyo end...
In the past I have bit streamed both DD and DTS from my HTPC to the Onkyo without issue, and as for PCM 'sounding better', it would depend on the mix.
Al
post #5512 of 5517 Old 01-18-2015, 05:07 PM
effdbee's Avatar
Quoted: 13 Post(s)
Just upgraded my 807 to a TX-NR1030. Main reasons were the 1030 will run all 11 speakers (with an external amp) as well as throughput the Blu Ray 3D HDMI signal. I was happy with the 807, now I'm elated with my 1030. Sounds fantastic. The 1030 seems to run cooler than the 807Sound seems crisper but maybe that's my imagination. Setup seems easier to get it to sound good than the 807 was 3-4 years ago, maybe it's just I know what Im doing now. Sold the perfect 807 to a friend for $200, happy not to risk a gun battle in a craigslist deal gone bad. Bu-Bye.
effdbee is offline
post #5513 of 5517 Old 10-22-2015, 03:12 PM
msp203's Avatar
My NR-807 has been repaired once already (2012) and is now having sound issues again. When first turning the unit on I have to power the unit off and on several times to get the sound to work. I'm debating sending it in for another repair or just taking the rebate offer towards a new receiver.
msp203 is offline
post #5514 of 5517 Old 12-14-2015, 08:38 PM
Liked: 0
Onkyo tx-nr 807 warrantie
Skickat från min SM-G900F via Tapatalk
ohmen63 is offline
post #5515 of 5517 Old 12-29-2015, 02:38 PM
Liked: 0
Question Tx-nr807
My 807 developed sporadic, very short sound drop outs (almost non-noticeable, but the speaker icons flickering accordingly) somewhen in October 2015. The unit was purchased 04/13/2010 and has hitherto worked flawlessly, although the Remote Control once needed a replacement because the volume buttons stopped working. After I contacted the regional Onkyo service center, I was told that I could send the receiver in for repair, covered by extended warranty. About a month later, the Ethernet port failed suddenly and completely. So I sent the receiver to the service center, for $25 shipping.
I got it back just before Xmas. No written statement whatsoever included, but a sticker on top of the device that indicates a repair number. I hooked all of my speakers back up and connected everything, and then proceeded to power up the Onkyo. Aaaaand....
No sound! It's even worse now than before the repair. There is absolutely no sound coming from the device anymore, and the speaker icons wont even light up, whereas this problem was only very sporadic/intermittent before. Interestingly though, the network port is fully functional again, so clearly something had been done. My guess is, they reflowed the DTS DSP in question. But somehow, for some reason, the repair didn't even hold for the duration of the trip from the service center back to my home.
After calling them up and speaking to the techie who repaired it, she said that she fixed the DSP chip and that it's been working on the test bench for her. She told me to read out the DSP firmware versions and DSP2 came up with ??? ????, so she concluded that the very chip she fixed must have failed again. She said that they would provide me with a return slip so I could send it back again, but this time for free and that they will decide on replacement HDMI board or replacement receiver.
I'm still waiting for the return slip as of today and have just left them a note, asking what happened.
niston is offline
post #5516 of 5517 Old 01-19-2016, 01:38 PM
Liked: 0
Quick update: I've since sent my Receiver back to the Onkyo Service Center for yet another repair attempt and I've got mail from them just now.
I am, quite honestly, shocked!
Now they are telling me that "other Parts" have failed, which are "not covered by the Onkyo Customer Care Program" and that they cannot repair my Receiver, because -furthermore- the required spare Parts are no longer available. Errr.....
Instead of fixing my 807, what they do is, they offer me a replacement Receiver TX-RZ800. For $800!
I can't help but feel like I'm being a little eff'd over here!
I've only got two reasonable explanations for this:
1) They botched the repair attempt, destroyed my property in the process and are now trying not only to cover it up, but try to extract a further $800 for a replacement device from me.
2) The device was damaged in transit, on it's first trip from the Service Center back to my home.
I've asked them to clarify, but I honestly don't expect much of an useful answer since the Service Center is just a subcontractor anyways. Does someone know how to contact the upper echelon of Onkyo Customer Care? I'm in Switzerland.
niston is offline
post #5517 of 5517 Unread Today, 05:51 PM
tylerh's Avatar
I'm trying to get my brother's 807 set up correctly(he had it in storage for 3 years which may be why it's still working).He has a Panny BR player,a Dish 722 receiver and a Roku box.Each is connected via hdmi and the 807 is connected via hdmi to the tv.He has a 5.1 speaker setup.The BR is fine-the display shows DTs or DD correctly.We get no sound at all from the Roku even though we get sound hooked directly to the tv.The 722 shows on the front display panel like the picture below-I cannot get it into DD no matter what.I've tried different inputs with no difference.Any ideas?Thanks
tylerh is online now
