Onkyo TX-NR807 Official Thread - Page 185 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #5521 of 5529 Old 05-13-2016, 05:05 PM
mm5300's Avatar
Quoted: 14 Post(s)
Originally Posted by Al Sherwood View Post
Pages 115-122 in the manual describes your options, certainly you can power a 5.1 system for the living room and 2 (stereo) speakers for the back deck.
Al, I guess I'm still a little confused on what the proper 5.1 speaker setup is. They show on pg 115-122 of the manual how to connect zone 2, but they don't show what the rear surround speakers for the 5.1 should be connected to in a situation of Zone 2. It seems like the only options for the rear surround are what would be plugged into either Zone 2 or Zone 3 if you don't have them. The other speaker options are Front L/R, Center, Front High L/R, Front Wide L/R, Surround L/R (Zone 3), Surround Back L/R (Zone 2). So what would you use other than the Front L/R & Center for the 5.1 rear speakers? I'm guessing it's one of the Zone connections, but not sure.
mm5300 is offline
post #5522 of 5529 Old 05-14-2016, 06:56 AM
Al Sherwood's Avatar
Quoted: 754 Post(s)
Liked: 277
Let me know if this helps clarify the connections.
So based on the way the TX-NR807 assigns speakers and active zones: for 5.1 surround in the living room you would use the "Surround left and right speakers" as shown in the diagram on page 115, these would be connected to the "SURR/Zone3 L" and "SURR/Zone3 R" terminals, this leaves the "SURR/Zone2 L" and "SURR/Zone2 R" terminals to power the back deck speakers (page 116).
ID:	1438106   Click image for larger version
Al
Al Sherwood is offline
post #5523 of 5529 Old 05-14-2016, 07:45 AM
mm5300's Avatar
Quoted: 14 Post(s)
Thanks. Maybe my manual is an older version or something because all I have on page 115 all I have is a huge picture of a room showing all the connections, and the only mention of surround speakers on page 116 is "Connect your Zone 2 speakers to the AV receiver’s SURR BACK/ZONE 2 L/R speaker terminals." with the below image. It never evens mentions the Surround L/R - Zone 3 connections. I appreciate the help.
Al Sherwood likes this.
mm5300 is offline
post #5524 of 5529 Old 05-14-2016, 10:27 AM
Quoted: 754 Post(s)
Liked: 277
No worries, here is a link to the manual I looked at: http://filedepot.onkyousa.com/Files/...En_webver2.pdf
Al
post #5525 of 5529 Old 07-06-2017, 01:39 PM
you28's Avatar
Quoted: 45 Post(s)
Onyx tx-nr807: how to test speakers
I have an onyx tx-nr807; it was a gift. I think i hooked it up correctly for 5.2 (the two side speakers are physically behind the couch not on the sides).
As far as I can tell no sound is playing on the subwoofer or two rear speakers (they are plugged into the side markings on the receiver).
When I run the 5.2 dts test on youtube (using the tv's web browser); when it plays the side speaker the sound comes out front.
Is there a reliable way i can test the subwoofer and two side speakers one at a time (I can't find anything in the receiver manual that shows if it is set to 5.2; and i'm not sure thx button on the receiver is compatible with dts).
Some additional information: The reciever is hooked up to the tv (oled65c7 - received today) via the optical out from the tv.
The receiver itself was a gift and this is the first time I've used it. It is an older model.
What I would like to do is tell the speaker to put out sound on one specific speaker and then test the connections et all to figure out if there is a hook up connection or problem with the wall wire.
you28 is offline
post #5526 of 5529 Old 07-08-2017, 01:49 AM
you28's Avatar
Quoted: 45 Post(s)
Ok. I figure it out - while I knew i was suppose to connect the rear speakrs to zone 3; i had connected them to zone 2 in a 5.1 configuration. I fix that and they are now working. Sub-woofer is still an issue but doesnt' appear to be an issue with the receiver.
you28 is offline
post #5527 of 5529 Old 07-08-2017, 07:59 AM
Dolus's Avatar
Quoted: 26 Post(s)
You Tube videos are only in stereo so a so called surround sound test file will only come from the front left & right speakers.
You do not connect the surround speakers to Zone 2 or Zone 3 , that is when you want speakers in another room. You connect the surround speakers to the surround speaker terminals.
As for seeing if all the speakers are working just use the receivers built in test tones.
Page 84 of the manual 2 Speaker Setup/1 Level Calibration.
You can download the user manual here https://www.google.co.uk/url?sa=t&rc...4LtQeA&cad=rjt
Onkyo TX-NR809,Sony KDL50W829 ,Virgin Media V Box HD, WDTV, PS3, Philips DVP9560, Marantz CD67, BK Monolith Plus, KEF TDM 23C,23F & 34DS, Darbee Darblet, Belkin F9G6223uk3M, Buttkicker LFE kit, IsoAcoustics L8R430 and L8R155, Mede8er 800X3D
Dolus is offline
post #5528 of 5529 Old 07-08-2017, 09:45 AM
you28's Avatar
Quoted: 45 Post(s)
I don't understand the manual sez that if I use a 5.1 setup to plug speaker 3 and 4 in right side and left side. On the back on the onxy the left side/right side has zone 3 written across them:
You can see this clearly in the picture below on the right side (the left is a bit blurry).
Also once i moved them from the spots label right/left back (which from the manual is for 7.1); they did in fact start emitting sound from the test video (played via youtube throug the tv web app). The test sound circle through each speaker one at a time so i'm pretty sure it was doing the right thing.
Perhaps i misunderstand you ?
you28 is offline
post #5529 of 5529 Old 07-08-2017, 10:29 PM
snoopygum's Avatar
Liked: 0
Page 11 of the manual shows that the Zone 3 terminals ARE the surround terminals. Also, page 84 talks about the on screen setup menus, not speaker setup.
Don't worry you got it right. The futherest outside terminals are the Surround/Zone 3 terminals.
snoopygum is offline
