Yamaha V3900 w Am10 Bose speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-19-2009, 03:41 AM - Thread Starter
HSD
HSD's Avatar
I am planning to buy the AM10 BOSE speakers, and the seller was suggesting that Yamaha v3900 will suit my requirements which is
1. Connect to my media Gate 800HD to watch my stored videos, music etc and
2. be able to stream audio-video wirelessly in another room to a Samusing TV....?? am not sure how-perhaps using some sort of LED IR remote??
3. be able to play all fomrats that are playable by MEDIA GATE 800HD
4. Be able to connect to the network to play any internet videos/music-either wirelessly or thro ethernet?? Am not sure if wireless will work well
5. Has a USB connection facility
Does anyone know of any other reciever which has these features and is better in terms of cost -this one is apparently AUD3000
Any guidance by someone who knows the features and has used it -knows if I am on the right path selecting this reciever or should I check out something comparable?
HSD is offline
post #2 of 4 Old 08-19-2009, 05:53 AM
Danielson99's Avatar
Quoted: 86 Post(s)
Liked: 72
I think you're going down the wrong path with both the receiver and the speakers. Bose are usually very overpriced for what you get. I would suggest a budget and list the components you'll be using and tell us what your goal is. Then people could give you a good recommendation that will give you a far better bang for your buck.
Danielson99 is offline
post #3 of 4 Old 08-19-2009, 06:12 AM - Thread Starter
HSD
HSD's Avatar
I thought I mentioned the features I am looking for
Basically I have a MediaGate media player w 1TB disk that stores all my videos and music.
I want to make sure that the speakers and reciever will be able to connect to the MediaGate wirelessly (or through ethernet/usb connection)to stream audio/video to another TV in another room
1. Connect to my MediaGate 800HD to watch my stored videos, music etc -should be DLNA compliant
2. be able to stream audio-video wirelessly in another room to a Samusng TV....?? am not sure how-perhaps using some sort of LED IR remote??
3. be able to play all formats that are playable by MEDIA GATE 800HD-mkv and wmv files, youtube downloads etc
5. Should have a USB port
Hope I have explained it well enough?
People on this firum say one shld spend 75% on speakers and 25% on reciever-but am not sure if all those who talk about $1000 for a reciever-actually have got a speaker system which costs $3k+?
HSD is offline
post #4 of 4 Old 08-19-2009, 04:28 PM - Thread Starter
HSD
HSD's Avatar
BTW my budget for both speakers and Reciever is around 2K
HSD is offline
