Denon AVR-4310CI vs Denon AVR 3310CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-04-2009, 08:56 AM - Thread Starter
mr_sonus's Avatar
HI All-
Quick question- I'm having a few issues with my 3310 and my salesperson offered to sell me a new 4310 for a difference of only 300 (as opposed to the 500).
Is this a good deal? Anyone out there with a 4310 can tell me what I'm really getting for the difference? I've done quite a bit of comparisons and the one thing that really stands out on the 4310 is the better gui & ipod connectivity in the front-
Anything else a 4310 owner can point out?
Thanks all
mr_sonus is offline
post #2 of 9 Old 09-04-2009, 09:09 AM
phantom52's Avatar
Quoted: 232 Post(s)
Liked: 240
Not a lot of difference. 4310 does have Audessey Multi-EQ XT, 3310 doesn't. Maybe batpig will come in with the answers you need.
phantom52 is offline
post #3 of 9 Old 09-04-2009, 09:33 AM
SelfGovern's Avatar
Before I would think of recommending anything, I'd sure like to know what the "few issues" you're having are. How else could anyone know if they are addressed in the 4310CI?
SelfGovern is offline
post #4 of 9 Old 09-04-2009, 10:02 AM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
$300 sounds reasonable; In addition to what you mentioned above, you get a beefier amp section, an extra HDMI input, Denon link (if DSD for SACD is important), and AL24 on all channels. I myself bought a 3310 but the upgrade (bear in mind I'm in Canada MSRP of the 3310 and 4310 are $1,930 and $2,700 respectively) to a 4310 would have cost me $530 ($1,470 for the 3310 versus $2,000 for the 4310 including tax).
EVT is offline
post #5 of 9 Old 09-04-2009, 11:20 AM
wlcohen's Avatar
tag
wlcohen is offline
post #6 of 9 Old 09-04-2009, 11:22 AM - Thread Starter
mr_sonus's Avatar
Great question SelfGovern.
The issues I have been having are typically around Internet Radio/Rhapsody & the flaky web interface. Firmware has also been a bit of an annoyance.
Basically what happens in Internet radio is when I sometimes select a station my TV screen flashes a few times, then I lose my picture. After that I can do one of two things- hit the NET/USB button a few times or power the unit down fully. As for Rhapsody- it works I'd say like 60% of the time. It's incredibly flaky and not the least bit stable.
mr_sonus is offline
post #7 of 9 Old 09-04-2009, 11:23 AM
winston9332's Avatar
Liked: 31
biggest true feature is audyssey dsx on the 4310.
winston9332 is offline
post #8 of 9 Old 01-03-2010, 10:33 AM
PCTools's Avatar
Do you feel this is worth the added cost of $300?
PCTools is offline
post #9 of 9 Old 01-04-2010, 02:08 PM
VTGOLFER's Avatar
The upgraded Audyssey in itself is worth the extra $300 in my opinion plus you can give DSX a try to see if you like it.
VTGOLFER is offline
