Pioneer 919AH-K, 1019AH-K, H/K AVR 254 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-09-2009, 08:34 AM - Thread Starter
alijaffer's Avatar
Hi,
I'm looking to buy a new receiver and speakers.
The speakers I am looking at are the H/K HKTS15, My brother in-law has them and they sound amazing to me.
However, he has the H/K AVR 354 which is out of my price range...
So I was looking first between the Pioneer 1019AH-K and H/K AVR 254. Then in looking at the specs of the 1019, I noticed that 919 is $200 cheaper and does almost the same thing...
I figure I don't need the extra input on the 1019, the only question to me is whether or not I need the upconverter in the 1019.
I have an Xbox right now and am buying a PS3 to be used as my BlueRay player and a digital cable box that exports to HDMI.
Also, I read in some other posts the 919 has some handshaking issues ... what does that mean?
alijaffer is offline
post #2 of 4 Old 09-09-2009, 01:00 PM
Trojita's Avatar
Quoted: 29 Post(s)
If you are looking at the Pioneer with that price range, why not look at the H/K AVR 254 & 354 "refurbished" receivers on Harmon Kardon's Ebay store? These units are essentially new since the reasons they are refurbished is because H/K released these receivers with numerous problems and took the stock they produced, opened them up, and replace their components / firmware. Some people have mentioned getting the 254 on ebay for $220 and the AVR 354 probably for around $300. They also come with a warranty if you buy it off of H/K's Ebay store.
Trojita is offline
post #3 of 4 Old 09-09-2009, 01:32 PM
eteller's Avatar
I have a Pio 1014-TX the THX certified precursor to the 1019 that weighs alot more than the new plastic front models. Swapped it out with a AVR 154 last night, the HK absolutely smokes it. Wanted something more substantial than the 154 but got it on closeout for $150, could not have passed it up and it fits my needs as far as power. I'd say go for the HK.
eteller is offline
post #4 of 4 Old 09-24-2009, 11:40 PM
SoupRknowva's Avatar
Im thinking about getting a 919, but i have a couple questions. first can the 919 drive 4 ohm loads? second does it let you bi amp the front speakers using the rear surround channels? and third, does it have preouts to use with a external amp?
Pioneer PDP 5020 E-Lite modded-Emotiva ERM-1's-Epik Sentinel
SoupRknowva is offline
