Official Harman Kardon AVR 1600/2600/3600 owner's thread - Page 100 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #2971 of 2975 Old 02-14-2017, 12:06 PM
spec1alk's Avatar
Quoted: 22 Post(s)
Originally Posted by Carlos E. Helfer View Post
Hi,
I'm experincing an issue when I connect my apple tv (4th generation) into my HDMI 1 port and I can only stream 480p even though I set manually to 1080p into apple's tv settings. My playstation connected to the HDMI 5 streams 1080p normally. Have you guys noticed or heard anything like that?
You could try setting it to bypass video. I do this for my Blu-ray player, but you do lose the menu overlays. The only one I really miss is the volume on the screen.
spec1alk is offline
post #2972 of 2975 Old 02-14-2017, 12:08 PM
spec1alk's Avatar
Quoted: 22 Post(s)
Originally Posted by spec1alk View Post
I had a thought this evening, could I burn them to DVD and play them on my blu-ray player connected to AVR via HDMI? Is there a high resolution format I could burn to the DVD for this?
So I have been playing around with burning DVD-Audio disc's using lplex. So far this seems to work, and my HK AVR3600 reports 96khz audio coming from the player. I have configured my blu-ray player to bitstream audio over HDMI.
PTAaron likes this.
spec1alk is offline
post #2973 of 2975 Old 03-20-2017, 06:18 PM
Stryker7314's Avatar
Moved my 3600 from pc audio duty to living room surround receiver and now I don't have audio in bypass mode, any ideas what it could be? I looked at a ton of settings, and couldn't figure it out. Works fine without bypassing, but I like using bypass so the video has no processing at all.
Stryker7314 is offline
post #2974 of 2975 Old 07-19-2017, 03:58 PM
spec1alk's Avatar
Quoted: 22 Post(s)
Does anyone know if I can pass-thru 4K video if I have the HDMI pass-thru enabled?
spec1alk is offline
post #2975 of 2975 Old 07-19-2017, 04:54 PM
gp-se's Avatar
Quoted: 89 Post(s)
Liked: 68
will not work.
the HDMI controller is not HDCP 2.2 Compatible.
gp-se is offline
