Marantz SR6004/SR5004 Owners' Thread - Page 58 - AVS | Home Theater Discussions And Reviews
post #1711 of 1715 Old 01-15-2015, 02:09 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 2837 Post(s)
Liked: 1944
First try swapping speakers to determine if the issue is with the speaker. If not, try resetting the microprocessor (see Owner's manual). If still no joy, then call for service.
"JD" – jd@avscience.com ; http://shop.avscience.com/; Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AV Science - We sell Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #1712 of 1715 Old 01-16-2015, 08:20 AM
mszulen's Avatar
Thanks for tip!
I'll swap the speakers and then will follow your advise:
"** Think the AVR is defective? Reset the microprocessor 4-5 times. "
ok, I've swapped the speakers - noise went to the other one, so speakers and cables are ok
Multiple resets also didn't help.
Need to contact service (might be something at the final stage of amp, since volume knob has no impact on the noise level.
mszulen is offline
post #1713 of 1715 Old Today, 10:01 AM
Liked: 0
Audio decoding question
I am jst trying to understand, and maybe setup my receiver correctly. I'm no dummy when it comes to figuring out how to setup, but decoding audio properly from a new video streaming box I go got seems to be eluding me...
My Receiver is the SR5004. I am trying to decode properly information from a Google TV streaming box. For all intensive purposes we are decoding information from a movie/TV stream that is putting out 5.1 surround. Normally with my regular cable feeds or DVD, you can tell what the audio is doing by the speakers that are illuminated on the display. (L,C,R, SR,LFE,SR). With the new streaming box, it states the feeds are 5.1, but only getting (L,R) illuminating. So I'm assuming the audio is not being decoded properly for the receiver to correctly place the streams. Everything is hooked up using HDMI cables. Is there anything I can do to get receiver to correctly decode these audio signals, or is the incoming format from these streams just not understandable by the Marantz receiver?
Jody Reed is online now
post #1714 of 1715 Old Today, 10:05 AM
MAJORAE's Avatar
I would start by ensuring the gtv is set to output 5.1 over HDMI and not down mixing to 2.0.
MAJORAE is online now
post #1715 of 1715 Old Today, 10:49 AM
Liked: 0
Well, I guess that is a good reason to not be in a hurry... That was it. I just enabled passthrough on GTV so it pushes signal through to receiver. Thanks for the sanity check MAJORAE.
Marantz Sr6004 Audio Video Receiver Black
Gear in this thread - Sr6004 by PriceGrabber.com
