*Official* Pioneer Elite VSX-21/23THX Owners Thread - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #3541 of 3569 Old 05-09-2015, 07:53 PM
JChin's Avatar
Quoted: 381 Post(s)
Liked: 210
Originally Posted by zedstaid View Post
I've tried switching AutoSurround to DirectStream, but it still settles on STEREO.
I've scoured the Manual and the internet for help and have come up with nothing that works. Is there a setting I've missed? I'm sure a lot of folks have hooked up their BluRay player via HDMI and have surround sound...
Hi zedstaid, check that "Speakers" are set to "A" and not "A & B".
JChin is online now
post #3542 of 3569 Old 05-11-2015, 01:45 PM
Liked: 0
Originally Posted by gene c353 View Post
Check the HDMI audio output in the BR players setup menu. Maybe it's set to PCM instead of bitstream.
Thank you gene c353 - that was the issue! I truly appreciate the time you your and your fellow forum comrades spent in helping me out.
zedstaid is offline
post #3543 of 3569 Old 05-17-2015, 12:19 PM
The Dark Knut's Avatar
3D blu ray work around for VSX 23TXH? My thread searching skills suck, sorry if this has been answered. Tried to watch 3D movie for 1st time last night using PS4 and Panasonic AE8000. Opening Disney scene starts up loud and proud, then screen goes blue with no activity. Is only solution to directly connect PS4 to projector, or does the 23TXH have a pass thru function that will work for 3D? Thanks
Repetition penetrates even the dullest of minds.
The Dark Knut is offline
post #3544 of 3569 Old 05-17-2015, 12:34 PM
gene c353's Avatar
Quoted: 156 Post(s)
Liked: 114
Not very knowledgable about 3D but I think you need an hdmi version 1.4 avr for 3D, although, I think I remember reading where the occasional older receiver will pass it through anyway. But I could be totally wrong. The 23 of course is 1.3. That's why people with 1.3 receivers buy BR players with dual HDMI outputs. One for the receiver (and TrueHD/MA) and the other for the display.
gene c353 is offline
post #3545 of 3569 Old 05-18-2015, 06:12 PM
Yardy's Avatar
The 23THX does not pass through 3D nor does it support ARC (audio return channel).
Yardy is offline
post #3546 of 3569 Old 05-19-2015, 05:44 PM
I feared as much, thanks fella's. Getting time to upgrade!
post #3547 of 3569 Old 06-24-2015, 10:46 PM
b_dogg623's Avatar
Quoted: 14 Post(s)
4 ohm stable?
I can not find any ohm settings in the 21txh/23txh menu or anything definitive in the manual concerning 4 ohm speaker usage. Can these models support 4 ohm speakers? I was hoping to power some Martin Logan's temporarily until the Atmos/DTS: X models came out. Thanks in advance for any info or user experience on this matter.
b_dogg623 is offline
post #3548 of 3569 Old 06-27-2015, 11:07 AM
Yardy's Avatar
No it does not support 4 ohm. From manual "
Guaranteed speaker impedance . . . . . . . . . . . . . 16 Ω to 8 Ω,
less than 8 Ω to 6 Ω (setting required
Means the lowest it will support is 6 ohms.
From Manual : here is how to chance impedance
press STANDBY/ON.
The display shows RESET NO .
Use TUNE +/– (or / on the remote control) to select
SPEAKER 8Ω , and then use PRESET +/– (or /
on the remote control) to select SPEAKER 8Ω or
SPEAKER 6Ω.
SPEAKER 8Ω – Use this setting if your speakers are
rated at 8 Ω or more.
SPEAKER 6Ω – Use this setting if your speakers are
rated at 6 Ω.
Yardy is offline
post #3549 of 3569 Old 07-03-2015, 10:19 PM
santiclaws's Avatar
OK, feeling a bit foolish here.... How do I select an HDMI input without cycling through all of them? I know it is possible, I have my universal remote programmed to directly go to 3 out of 4 HDMI inputs without cycling. But I just got a Chromecast recently and hooked it up to the 4th HDMI input, but I can't find the discrete input button on the Pioneer remote to teach my universal remote and I can't remember how I did it the last time, since it has been a couple of years. I've scoured the manual and can't find an answer. So, how did I do it??
santiclaws is offline
post #3550 of 3569 Old 07-08-2015, 09:35 PM
sawfish's Avatar
Quoted: 145 Post(s)
Liked: 145
There does not appear to be a button on the remote for it, and HDMI 4 is not assignable to another input per the manual, which may be how you did it before. If you have a Logitech, you could ask them to make the code available. Alternatively, you could use a JP1 remote to teach your preferred learning remote. See this thread for an example involving a Panasonic TV, which while not directly applicable, points you to the right place and idea:
http://www.hifi-remote.com/forums/viewtopic.php?t=14684
You don't even need to buy a cable and get into the JP1 software to do this, though they are convenient when you have a lot of codes. The relevant codes for you are:
Input HDMI 4
dev 165
obc1 94
obc2 205
This will make sense to the JP1 experts.
sawfish is offline
post #3551 of 3569 Old 07-17-2015, 02:11 AM
Liked: 0
HDMI sound issue
This may have been covered earlier, but I could not find anything conclusive.
My issue is getting audio through using HDMI cables. I am coming out of a TIVO series 3 HD cable box, into the VSX-23TXH vis HDMI, then out of the HDMI out to my new Samsung UN55J6200AFX
Great picture.....NO sound. I tried the usual ie: factory rest, swapped cables, etc. I have seen :firmware update mentioned in the past, but no way to do that, and I don't want to waste the time or money if it is not assured to work.
Any thoughts out there? I know the AVR isn't that new, but it still should work.
Any help would be much appreciated.
cmcltd is offline
post #3552 of 3569 Old 07-27-2015, 05:37 AM
JMWhite's Avatar
Greetings,
My VSX-21THX has been working fine for several years. I have a pretty basic setup with a Panny BD player assigned to the BD HDMI input. A Cablebox/DVR assigned to the Cable/DVR HDMI input and a Sony BD assigned to the HDMI2 HDMI input.
A couple days ago, perhaps coincident with rather intense thunder/lightning in the area ALL the HDMI inputs appear to have failed (repeat All of them). The HDMI OUTPUT appears fine as I can call the VSX-21THX's Graphical User Interface on my TV, via the TV's HDMI input (Receiver and Home keys on Pioneer remote).
I can connect the a BD player directly to the TV using using existing cables whereupon it works nicely, so I don't think the cables failed.
The whole setup is protected by a surge control unit (albiet not a high end one).
I've been poking through the manual... but have not found anything particularly helpful, yet.
Any ideas ????? Help !
JWhite
JMWhite is offline
post #3553 of 3569 Old 07-31-2015, 05:31 AM
Liked: 1
I just purchased and setup a VSX23 and was looking for some clarification on settings. I am running the unit currently with only 4 speakers (L, R, SL, SR), full range to each speaker. This will change once I complete the sub I am updating. I am struggling to understand the differences between some settings so if anyone could clarify that would be good:
In surround mode:
I am having trouble determining the difference between "DIRECT" and "AUTO SURROUND". I understand the difference between "PURE DIRECT" and the others (it doesn't apply any of the EQ, standing wave correction, distance correction etc....) but I don't understand what is the difference between DIRECT and AUTO SURROUND. ie what other processing would be turned off? The sound difference with PURE DIRECT is noticeable as it does not have EQ correction but there is still a difference between DIRECT and AUTO SURROUND. I'd say that I slightly prefer the DIRECT sound but am not sure if there is anything I am missing about these two modes. I have currently tested only with an XB360 streaming Netflix 5.1 via HDMI.
For stereo use:
This one confuses me even more. PURE DIRECT and DIRECT can easily be told apart due to the difference of the EQ and S-wave correction. However, there is also AUTO mode and then just STEREO mode too. Again here I think I prefer the DIRECT mode but I can tell there is a difference between that and STEREO or AUTO. STEREO and AUTO sound very similar and may be the same. Input is a bluetooth receiver connected via RCA stereo inputs.
Thanks for any clarification anyone can offer!
JWiggle is offline
post #3554 of 3569 Old 11-27-2015, 08:16 AM
djsvetljo's Avatar
Quoted: 61 Post(s)
Liked: 7
I am integrating VSX23-THX with RS232 controls and I am not able to power up from stand by. I follow directions in the attached imaged but it doesn't want to power up:
enter
100ms
enter
PO
enter
Basically, as I understand it, enter (CR) must be hit to wake up the processor and then execute the command. I tried with several enters, longer pause - nothing powers it up. Everything else works flawless.
djsvetljo is offline
post #3555 of 3569 Old 11-27-2015, 07:55 PM
djsvetljo's Avatar
Quoted: 61 Post(s)
Liked: 7
enter
100ms
enter
PO
enter
and 12 hours later I found the answer:
I was doing lower case "po" as once power, lower case works everywhere. Well, at stand by, power on command has to be upper case: enter >100ms> PO.
post #3556 of 3569 Old 12-21-2015, 04:11 PM
Liked: 0
VSX-21 THX Receiver Shuts off at high volume
I'll start by declaring that I'm a newbie when it comes to receivers/speaker/sub woofer matching. I understand the concepts at a high level, but have a hard time applying them. I've done a lot of reading and learning today, yet can't figure out what I'm doing wrong. I'll check the speakers for cross wiring or fault one by one today. However, I was wondering if anyone can provide insights on why the receiver keeps shutting down as opposed to distorting the sound at high volumes.
I have the below equipment, all running through my receiver. When I increase the volume to below -5 Dbs, the receiver shuts down immediately:
  • a VSX-21 TXH receiver.
  • an Energy Take Classic Classic 5.1 Home Theater System speakers, but I'm not using the sub.
  • a Polk Audio PSW505.
The sub woofer is running out of the Pre-Amp sub-out RCA jack. Any help and insight you can provide is much appreciated.
Rafi
Rafi Ghazarian is offline
post #3557 of 3569 Old 01-01-2016, 06:46 AM
Superman2's Avatar
Quoted: 16 Post(s)
Can't say I've had that problem before, but I think I remember reading something like this before here. Try searching the thread, but I may be wrong.
Superman2 is offline
post #3558 of 3569 Old 01-04-2016, 05:29 PM
kadinh's Avatar
I'm wanting to get some wireless headphones for my PS4, the Turtle Beach Elite 800.
The instructions say to connect the headphone dock to the PS4 through optical cable. In turn, the base sends the signal to the headphones.
I'm wondering if I can connect the optical cable from the headphone base to the optical out on the VSX-21THX and get sound from all of my sources. Also, will the receiver send audio through my surround speakers AND the headphones simultaneously?
The PS4 is connected through HDMI; the only other optical cable in the receiver now is from my TV to the optical 1 input so i can hear sound when I watch TV.
Thanks in advance guys.
iPhone 6 Plus
kadinh is offline
post #3559 of 3569 Old 01-19-2016, 02:02 PM
Liked: 0
How to I check that firmware I have an when can I get the download to update it. Thanks
Aceman2101 is offline
post #3560 of 3569 Old 02-26-2016, 09:31 AM
Ineedanewtv's Avatar
Originally Posted by ccotenj View Post
^^^<br><br><a href="http://www.pioneerfaq.info/" target="_blank">click here</a><br><br>
use at your own risk... if you brick your unit, don't expect pioneer to fix it for you...
I can't find firmware 1.054 on this page. Any advice?
Ineedanewtv is offline
post #3561 of 3569 Old 05-22-2016, 10:29 PM
Liked: 0
here is the address
pioneerfaq.info/index.php?question=Firmwares&type=AVR
bizzellk is offline
post #3562 of 3569 Old 09-19-2016, 02:48 PM
HelpfulDad's Avatar
Liked: 0
Firmware upgrades can be tricky. I've read the instructions with this upgrade and they are a little ambiguous in places. The firmware is on the site, not that hard to find, so the fact that you couldn't find it leads me to believe that you might not be that IT savvy.
I have a bit of advice for you. And, I say this sincerely to be helpful, not trying to be a smart alec. [B]Be careful[B] and maybe get some help. You might want to solicit the help of a friend who is truly knowledgeable about IT hardware. Not one of the many who claim to be knowledgeable because they can bold something on a web page or they know how to multi-select using the Ctrl key, but someone who's actually updated the firmware to something before and knows hardware.
I've upgrade firmware many times on lots of different hardware and it's always an anxious task because the penalty is a useless piece of hardware. If you aren't a little nervous about taking a file off the Internet from someone you don't know and loading it up with a procedure that wasn't from the manufacturer, take a minute and get nervous. Pioneer doesn't want you doing this for a reason, not just to be jerks.
HelpfulDad is offline
post #3563 of 3569 Old 09-19-2016, 03:04 PM
HelpfulDad's Avatar
Liked: 0
OPPO BDP95 and Multi Channel in
Here's the issue. I have 5 full range range speaker systems in a 5.0 configuration. The DAC in the Oppo is super sweet and I want to use the Multi Chan input on my VSX-23TXH, but there is this nasty little bass management issue. How can I get everything that would normally go to a subwoofer in a 5.1 configuration into the 5.0 configuration?
Oppo speaker configuration only allows for the subwoofer to be on or off. No rerouting of subwoofer signal to Front Left and Right. Because I want to stay analog in the VSX-23, there doesn't appear to be a way to get the subwoofer signal routed into the existing channels.
Any ideas? I thought maybe I could turn the subwoofer on in the Oppo and use a Y RCA cable to bring the oppo Sub and oppo L channel into the left channel on the VSX-23, then set the levels in the Oppo to get it sounding decent, but IDK. I don't think it will harm anything, but also have a healthy fear of truly oddball stuff so I don't want to burn up anything either.
I think it's just a "can't get there from here" sort of thing, but open to suggestion.
post #3564 of 3569 Old 09-19-2016, 03:10 PM
HelpfulDad's Avatar
Liked: 0
2 Channel analog input on VSX23
When using one of the two channel analog inputs, does anyone KNOW, (not think or pretty sure) if the receiver is sampling the analog then sending it back through the DAC to get analog? Or can I simply get analog input through analog preamp and analog Power amp via one of these analog inputs? I really love this receiver for all the movie decoding, iphone, when I need digital. But, I'd also like to bypass for analog for some things.
I'm asking because when I'm using one of them, even pure direct and I press "Status" it shows me fs:96khz which leads me to believe it is sampling and converting.
post #3565 of 3569 Old 02-10-2017, 06:19 PM
Liked: 0
iPhone 6 Plus
I am in a similar situation, but using Astro A40s instead. I was wondering if anyone has figured this out.
sodisacks is offline
post #3566 of 3569 Old 05-18-2017, 05:40 AM
Liked: 0
On page 45 of the user manual, it states that HDMI sources will not pass audio through the digital out on the receiver. With your PS4, you should have the option to output toslink into the receiver. This should pass along the audio so you can use your wireless headphones. You'll get Dolby Digital (AC3) over toslink and not full 7.1.
pcmantinker is offline
post #3567 of 3569 Old 08-08-2017, 09:00 AM
Nascar Dog's Avatar
Quoted: 56 Post(s)
Liked: 65
I just picked up a VSX-23TXH for $80.00
Upgraded the firmware from 1.021 to 1.054 with no issues
Before Upgrade
https://drive.google.com/open?id=0B9...HRWS3g5RmxoQ1U
After Upgrade
https://drive.google.com/open?id=0B9...m5BV1NNLWtkM1E
Thunder18 likes this.
Nascar Dog is offline
post #3568 of 3569 Old 08-08-2017, 10:25 AM
Thunder18's Avatar
Quoted: 95 Post(s)
Liked: 55
Before Upgrade
After Upgrade
Any new functionality or just bug and performance tweaks?
Sent from my LG-H918 using Tapatalk
Thunder18 is offline
post #3569 of 3569 Old 08-08-2017, 10:51 AM
Nascar Dog's Avatar
Quoted: 56 Post(s)
Liked: 65
Just bug and performance tweaks and my OCD satisfaction that I have the latest firmware installed
